Any recommendations?
Been looking online and for around 300 can get a very small kitchen set.
I'm going to butcher this to suit our temporary needs ( 'temporary' means I reckon maybe a year with it )
I'll buy the appliances we want e.g. cooker, hob etc. and just wack them in.
12 minutes ago, GaryM said:
Aldi single induction hob £35, brilliant, I prefer to our Siemens £1000 hob.  I think Lidl does them too
Thanks. The appliances aren't the issue it's cheap units/fronts/worktop .
All going to end up in the skip at some point....
1 minute ago, PeterW said:
Howdens will do you a full 9 unit kitchen for £400 so got to be your cheapest option.
You sure?
That presumably means doors/handles/hinges etc. etc. extra???
ok, I presume you haven't got an existing Kitchen your removing to butcher?
Just a thought, why don't you phone local kitchen fitters to find out if they have any old kitchens they are removing you can have?
WHY will it end up in the skip?
Why not just buy less of the units of your final kitchen for now = no waste?
Or buy the units that will make up your utility room, and use them as a kitchen for now?
We knew we were eventually having granite worktops so we bought the kitchen units and a cheap laminate worktop.  We left that worktop a bit over length for the kitchen and used it, and then later it got moved to the utility room.
You are indeed correct!
Visiting Howdens tomorrow!
TBH I'd probably stick it on eBay for £100 buyer collects ( and dismantles )
We have no utility room.
I'm special. My house is special
Just watch Howdens for worktop lengths. Less than 3m it’s about £15/m, go over and it jumps to double that for the same stuff.
I'm going to build my temp kitchen in the middle of the under ground dungeon deliberately to keep away from walls as they aren't complete. Also I don't want to move the temp kitchen.
To make it stronger I can bolt the units together. I was thinking about a 'false' wall behind them to mount the wall units on. But I can't fix to the floor due to UFH - ct1 a wooden supporting structure to the screed?????
If you have a Howdens account keep an eye on their special offers, they often sell off end of line left over units or worktops really cheap. Just having a look back and they have had odd kitchen units for as little as £10 and 3M worktops for £30.  All very much branch dependent I would think.
Tomorrow I'll go and open an account. I'm sure on the spot some extra 'deals' will appear!
Some people have got more money than plumbing skills!
Does it have an oyster knife?
(Update: I see it has a spaghetti-fingers, but I'm on Cornish Oysters this week. What's the Trangia about?)
2 minutes ago, TonyT said:
Get a couple of trestles and plywood and cut a sink out and sit a microwave on it.
Make another and there is the prep space.
Going to do that aswell . Remember I need some SWMBO kudos !
