For a change I was kidding! :) Sacrilege to cut that walnut! Got the offcuts from when I tapered the bath sides:
2017-01-31_09-33-54
Not sure if the mills are still going tbh. None of its mine but this is the lathe I have access too. Take your life in your hands sort of thing:
2017-01-31_09-23-23
7 hours ago, Construction Channel said:
we haven't got time for that, There is procrastination to be discussed xD
Curse @daiking for that! :)
Couldn't resist....
5 equi spaced,  6mm holes starting 50mm from the end. Mitre bonded one end cap on. Foamed the bottom hole then when it started coming out of the second hole up foamed into that and so on. Then lightly clamped a bit of ply on without compressing anything:
20170203_212956
20170203_213012
Frankly I'm surprised about all the fuss over insulation levels of this cill. By the time @Onoff has finished this bathroom global warming should have negated any need for controlling heat loss :D
Oh hang on, I might have got that wrong: http://www.telegraph.co.uk/news/earth/environment/climatechange/12098431/Global-warming-delays-next-ice-age-by-50000-years.html
Perhaps you should consider triple glazing? It would be awful to be cold when it's finished! B|
I shouldn't laugh.....
But ?
And he falls at the last post!
It WAS all going so well too.....
Got the window in. Old one out no problems despite the carp Erbauer sabre saw blades. In and wedged level. Foamed and allowed to go off a bit. FRAME fixings in.
20170204_133638
20170204_145543
Putting the glass in and beading from the inside and the big ones in fine. But putting the fanlight in I made what I guess is the rookie mistake and put the long sides in first. Consequently it's a bitch trying to get the short bits in now. Just no "flex" in them.
Is there an easy way of removing the beads without damaging them?
2017-02-04_04-39-40
(On the plus side it's much warmer in there now though that might be psychological!)
Cheers
short answer is no,
best way i found is with a wallpaper scraper or a pair of them, and hammer it into the joint, don't twist it, just work your way down until you have a gap all the way down then gently twist it at one of the ends,
drop of Wd40 might help but i have never tired that,
If anyone else does know an easier (less likely to do any damage) way i am all ears.
34 minutes ago, Construction Channel said:
short answer is no,
Piece of pi$$ and then some.....seriously!
Slightly blunt chisel in this gap, bevel down. Give it a tap. Doesn't damage the frame and it just "lifts" out. Surprised me as I was expecting it would eff it up:
2017-02-04_05-32-09
Forget trying to lever from the rubber edge.
Edited by Onoff
28 minutes ago, Construction Channel said:
it is easier when you haven't got them all in :ph34r:.
Happy days though, Whats next on the list?
Before I tried the chisel method I'd called my nephew (it was him who put me onto the window supplier in the first place and he's done some of his own). No answer so I went for it. I'd just got all the beads in when he turned up. I asked him if he'd had to take beads out again and he said yes by it was a complete bitch, you end up damaging them etc. He was as surprised as me when I showed him.
Bit of rendering tomorrow though I might get some UPVC beads to butt up to and mitre bond them on.
Wife's saying "It's warmer already!". Good sign.
Back in the bathroom I guess. Got to order a wall hung wc when we can agree.
Visiting big bro in hospital sometime. Slipped on his drive and managed to separate his thigh muscle from his kneecap! :( Went last night but he was in theatre. 8-12 weeks in plaster and the same for physio etc.
Edited by Onoff
20 hours ago, Onoff said:
Couldn't resist....
20170203_212956
20170203_213012
I missed this earlier, but I did something similar when filling some alloy tubes with can foam, and it's a trick that may be worth passing on here.  The tubes I wanted to fill were 1" diameter 16g wall and just over 5m long (sorry for the mixture of units, but alloy tubes are often sold in imperial diameter and wall thickness but metric length...........).  I got a bit of cheap 8mm PVC clear flexible pipe and found that it was a nice tight push fit on to my foam gun nozzle.  I didn't block either end of the tube I was filling, but started from the centre, by having just over 2.5m of pipe on the gun.
The technique was to squirt (slowly!) whilst pulling the pipe out.  Having done this from the centre to one end, I did the same from the other end.  It worked a treat.  What I found didn't work was to try and fill the tube from one end, moving the gun back the whole 5m+.  I tried it, made a mess, had to throw the bit of flexible pipe away and clean out the tube, before using the "centre out" method.
I can't see why this shouldn't work for filling things like cills, as if you go slowly, pulling the pipe out as you go, there's very little risk of a pressure build up.
No distortion on the sill whatsoever. Down to the clamping whilst curing I'm sure.
One screw up I made with foam which I regret was to foam fill my 100x100mm steel gate posts. They condensate on the outside.
Over the years I've found that it's the fast-cure foams that seem to create the most pressure.  I filled some flotation chambers in a GRP boat decades ago and managed to put bulges in the hull!
I was filling these tubes (which were the gunwales for an experimental "no wood" rowing boat) really just to prevent them getting water inside.  If anyone's inetrested I wrote the design and build up in an article in Watercraft magazine a few years ago, and there's some details of the design and build on this forum thread: http://uk-hbbr-forum.967333.n3.nabble.com/The-quot-Aerowherry-quot-a-lightweight-rowing-boat-was-going-to-be-a-canoe-td2424625.html  Here's a photo of me rowing her up the Hamble to the pub:
The potential issue as I see it with slow withdrawal is that the foam goes pretty firm within an hour or so, but can carry on expanding for up to 12 hrs, so the deep expansion can create a lot of internal pressures leading to bulging.   This is why I suggested a similar method working from the centre out, but doing it in multiple fills so that each fill is no more than a few inches, which expands out to around 6 or so.
When I fitted my MDF cills I CT1'd them onto fixing battens, then after the CT1 had gone off, I used your withdrawal method to lay back-to-front lines of foam in the voids between the battens on a foam-to-gap ratio of roughly 1:2 and left this to go off.  The foam then expanded to pretty much fill the under cill void.  I then went back the next day and did any infill needed and this time I got some overflow.  This I cut off another day later when it was truly hardened and the cills as solid as a rock.
That's a good point about continuing to expand, but you can usually mitigate it by spraying water in first.  I think that the reason the cure continues for so long in a sealed space is that single pack PUs are moisture curing, and so cure from the outside face inwards, with atmospheric moisture as the effective curing agent.  If you spray water into the cavity first, you provide the moisture needed to achieve a full cure in the centre far more quickly, and so reduce, or eliminate, the on-going expansion problem.  A bit of water sprayed in also helps with adhesion to some materials, I've noticed.
Another thing I found out with some PU foams (the two part, fast cure stuff) is that they tend to shrink back a bit after they've cured.  I've had this happen when filling large voids, but not seen it with the single pack can foam, so I'm guessing the different cure method doesn't cause post-cure shrinkage.  ST probably knows more about this, as I think he worked with foams professionally at one time.
I need to get some UPVC trim to mitre bond on and render up to. Found a short, random length in the back of the old stable that matches some of the other windows (a line of holes in it for some reason). Measures nom 15x13mm.
20170205_140040
20170205_140104
20170205_140113
eBay to the rescue:
http://m.ebay.co.uk/itm/uPVC-Window-Finishing-Architrave-Trims-Plastic-PVC-4-x-1120mm-Lengths-/371424653872?var=640503198825&hash=item567aa27230%3Am%3Am5xcIc9bXTRM14UOYZWBkmg&_trkparms=pageci%3A5902c002-ebb1-11e6-ac6c-74dbd18094f7%7Cparentrq%3A0eba196015a0a5e0b8851677ffa27f9e%7Ciid%3A8&varId=640503198825
5 hours ago, Nickfromwales said:
Beware of some glues and sprays as not all are for upvc ;)
Some go horribly yellow after being sprayed with the activator so chose well for the finishing / makeup work.
Where does No Nonsense mitre bond rank then?
('Cos that's all I've got).
Is she impulsive?  I should say so! She tries but WTF is the point? :(
I fitted the window and suggested I remove the old sill to line and seal the reveal. I come home and she's glossed everything! The sill which I pushed back a bit is letting a gale through! I gently mentioned it and got "Can't you fill it?"
Mind you she's convinced you'll suffocate with MVHR!
The problem I have is trying to, very delicately, explain that her work is total crap, and that when she's gone I'll have to undo it, clean it off and do it again.  It has led to some sticky moments.  The best example was oiling the doors in the new house.  There was me thinking that if I rub them down, wipe them over with some white spirit, so they are ready to oil, I can give her a pot of oil and a decent brush, put some newspaper down under the doors and just explain gently that the oil needs to be worked in pretty well, to do a small area at a time, make sure there's an even coat all over the door and to try and brush with the grain.
What did we end up with? A dozen doors that I had to clean off with white spirit after she'd gone, around £50 of wasted Osmo oil and a couple of days of my time wasted re-doing them all.  Sadly, she noticed.  She looked at what she thought was her handiwork a few days later, said she was surprised the doors looked as nice as they did, then asked me outright if I'd re-done them all.  I couldn't lie, but I did have a day or two of the "silent treatment" afterwards.  The problem is you can't win in a situation like that, unless you're the sort of person that can look at something not properly done for years afterwards and not let it bother you (I can't.............).
Edited by JSHarris
