Russell griffiths Posted December 14, 2020 Posted December 14, 2020 Suck the paint up in a straw and blow it back out, altering your amount of puff to change the spray pattern. Works a treat, have used this ol trick to get me out of loads of situations. ?? 2
daiking Posted December 14, 2020 Posted December 14, 2020 just (expletive deleted)ing paint it. You really won't notice it up there. 1
Pocster Posted December 14, 2020 Author Posted December 14, 2020 On 14/12/2020 at 16:07, daiking said: just (expletive deleted)ing paint it. You really won't notice it up there. Expand It will stick out like a sore thumb if I just paint it - as it will show texture if I’m not careful
daiking Posted December 14, 2020 Posted December 14, 2020 On 14/12/2020 at 16:10, pocster said: It will stick out like a sore thumb if I just paint it - as it will show texture if I’m not careful Expand be careful then. 1
Pocster Posted December 14, 2020 Author Posted December 14, 2020 (edited) Just spoke to paint manufacturer . They reckon if I sand it back super gently and use a fine roller with a watery coat first ( and leave to dry ) - then go over it again I should be ok...... So ordered just a tester pot as that should be enough.... Edited December 14, 2020 by pocster
joe90 Posted December 14, 2020 Posted December 14, 2020 On 14/12/2020 at 16:43, pocster said: Just spoke to paint manufacturer . They reckon if I sand it back super gently and use a fine roller . Expand That’s what I fecking said ?♂️. 3
Pocster Posted December 14, 2020 Author Posted December 14, 2020 On 14/12/2020 at 16:51, joe90 said: That’s what I fecking said ?♂️. Expand You did ! Gold star for you ! ⭐️
Pocster Posted December 14, 2020 Author Posted December 14, 2020 @Gav_P shhhhhh - ( whispers ) go and read Zooties threads . You’ll need paracetamol then for sure ... shhhhhh ?
Gav_P Posted December 14, 2020 Posted December 14, 2020 On 14/12/2020 at 17:48, pocster said: @Gav_P shhhhhh - ( whispers ) go and read Zooties threads . You’ll need paracetamol then for sure ... shhhhhh ? Expand No fecking way I’m heading down that rabbit hole again! 2
Pocster Posted December 15, 2020 Author Posted December 15, 2020 Couldn’t sand this no matter how gentle - it just ‘pulls’ it loose . So a very weak pva mix to stick the edges down . Sample pot of exact matching paint ordered .
PeterW Posted December 15, 2020 Posted December 15, 2020 Sounds like the paint hasn’t bonded correctly to the underlying plaster. What was the first coat..??
SteamyTea Posted December 15, 2020 Posted December 15, 2020 (edited) Lightly sand the surface of the paint above the damage. Use some filler to create a new 'paint thickness' below the damage. Lightly sand and then paint. If you really don't want to see the difference, there are some wrist exercises that make you go blind, similar to sanding. Edited December 15, 2020 by SteamyTea 1
Pocster Posted December 15, 2020 Author Posted December 15, 2020 On 15/12/2020 at 11:27, PeterW said: Sounds like the paint hasn’t bonded correctly to the underlying plaster. What was the first coat..?? Expand It hasn’t Peter Though I did a first watery coat using the same paint . Speaking to the company they suggest next time to use a watered down emulsion first . He said this as it is would not be an issue assuming I don’t stick a piece of sellotape on it and pull it off .
PeterW Posted December 15, 2020 Posted December 15, 2020 If you want it to look the same as the sprayed area then buy an airbrush kit - not expensive. 1
Pocster Posted December 15, 2020 Author Posted December 15, 2020 On 15/12/2020 at 11:59, PeterW said: If you want it to look the same as the sprayed area then buy an airbrush kit - not expensive. Expand I did quickly look at cheap ones - but they all get mixed or terrible reviews . Any you suggest ???
SteamyTea Posted December 15, 2020 Posted December 15, 2020 You could get one of these. Then send it to me as I want to know if it is any good. https://www.screwfix.com/p/erbauer-erb561srg-700w-electric-hvlp-spray-gun-220-240v/11628 1
Pocster Posted December 15, 2020 Author Posted December 15, 2020 On 15/12/2020 at 12:50, SteamyTea said: You could get one of these. Then send it to me as I want to know if it is any good. https://www.screwfix.com/p/erbauer-erb561srg-700w-electric-hvlp-spray-gun-220-240v/11628 Expand Might be worth a punt. £45 quid to apply 45pence of paint. Still it's this or setup the spray BEAST!
Pocster Posted December 15, 2020 Author Posted December 15, 2020 On 15/12/2020 at 15:26, pocster said: Might be worth a punt. £45 quid to apply 45pence of paint. Still it's this or setup the spray BEAST! Expand Ordered. If it's crap I'll send it on to you @SteamyTea
joe90 Posted December 15, 2020 Posted December 15, 2020 On 14/12/2020 at 16:43, pocster said: Just spoke to paint manufacturer . They reckon if I sand it back super gently and use a fine roller with a watery coat first ( and leave to dry ) - then go over it again I should be ok...... Expand Surely worth a try before spending even more money, can’t do any harm! 1
Pocster Posted December 15, 2020 Author Posted December 15, 2020 On 15/12/2020 at 15:35, joe90 said: Surely worth a try before spending even more money, can’t do any harm! Expand Too fecking late mate!. I'm not convinced any roller won't leave a texture. Anyway - new toy on the way! 1
SteamyTea Posted December 15, 2020 Posted December 15, 2020 On 15/12/2020 at 15:35, pocster said: Ordered. If it's crap I'll send it on to you @SteamyTea Expand Good man. The kind of thing you are spraying is similar to the small things I need to do. 1
Pocster Posted December 15, 2020 Author Posted December 15, 2020 On 15/12/2020 at 15:42, SteamyTea said: Good man. The kind of thing you are spraying is similar to the small things I need to do. Expand I’ll test it for you . If it’s good you can have it for 90 quid
Pocster Posted December 17, 2020 Author Posted December 17, 2020 @SteamyTea your Xmas pressie has arrived
SteamyTea Posted December 17, 2020 Posted December 17, 2020 On 17/12/2020 at 15:45, pocster said: Xmas pressie has arrived Expand Let me know how you get on with it. I have some small, "St. Ives", picture frames I want to spay up. Not sure when I will be passing, was going to see my Mother, but think she is now in Tier 3, so may have to rethink plans for my 2 weeks off.
Pocster Posted December 17, 2020 Author Posted December 17, 2020 On 17/12/2020 at 15:58, SteamyTea said: Let me know how you get on with it. I have some small, "St. Ives", picture frames I want to spay up. Not sure when I will be passing, was going to see my Mother, but think she is now in Tier 3, so may have to rethink plans for my 2 weeks off. Expand Sure - I’ll let you know how it is . btw you aren’t really getting it ! ??
