Alexphd1 Posted November 21, 2020 Posted November 21, 2020 What options have i got for sealing up a internal (fire) door between the garage and house to cut draught.
ProDave Posted November 21, 2020 Posted November 21, 2020 4 minutes ago, Alexphd1 said: What options have i got for sealing up a internal (fire) door between the garage and house to cut draught. draught proof strip around the frame? The reality is if the rest of the house is air tight and sealed you won't get much draught. In a well sealed house you can open one door or one window and you won't get a draught.
Alexphd1 Posted November 21, 2020 Author Posted November 21, 2020 Was hoping for a bit more than that as that's what we have on existing house and it's not great (hadn't considered the air tight side) Would a self closing hinge with a strong closing pull help create a better seal?
nod Posted November 21, 2020 Posted November 21, 2020 Could be worth looking at the garage outer door doors
Alexphd1 Posted November 21, 2020 Author Posted November 21, 2020 Do you mean the the garage door for the car, we have a lot of air vents in there so sealing the big door is s bit pointless plus there is a log gasification boiler in there (need ventilation for combustion).
joth Posted November 21, 2020 Posted November 21, 2020 Have a look at https://forum.buildhub.org.uk/topic/12813-passive-standard-house-integral-garage/
wozza Posted November 22, 2020 Posted November 22, 2020 Our door to the attached garage is a plain white upvc fire door - it looks good and seals very well - I believe its what they fit as front doors in blocks of flats.
Russell griffiths Posted November 22, 2020 Posted November 22, 2020 1 minute ago, wozza said: Our door to the attached garage is a plain white upvc fire door - it looks good and seals very well - I believe its what they fit as front doors in blocks of flats. Do you have a make or link please.
wozza Posted November 22, 2020 Posted November 22, 2020 It was fitted in 2010, I have since moved it to its new location - I will look tomorrow.
wozza Posted November 24, 2020 Posted November 24, 2020 On 22/11/2020 at 18:52, Russell griffiths said: Do you have a make or link please. Sorry, I have looked all over the door - I cant find any details on it. 1
vfrdave Posted December 10, 2020 Posted December 10, 2020 Bat wing seals like these maybe in the frame https://www.firesealsdirect.co.uk/passive-fire-protection/intumescent-seals/lorient-is1212-batwing-acoustic-and-smoke-seal-10-x-10-x-2100mm-white/?gclid=CjwKCAiAq8f-BRBtEiwAGr3DgYdZAqsDsgCYGJ2YYzrVbXMlU1YXMmwmStMxsA6F_PxajtDhOx-vyxoCw-MQAvD_BwE And drop seal in the door https://www.lorientuk.com/products/architectural-seals/drop-seals I must caveat with I haven't used either yet. 1
