October 22, 20205 yr Sorry I'm a bit late to this party @newhome, has been a bloody long day.... The rubber seals work well, but do NOT overtighten them Less is more here. Do not try to fully tighten one up before starting the other on the thread, so basically they need to be hand-tightened one turn at a time alternating sides until you cannot turn them by hand any more. Pinch them up with those grips / adjustable spanner, and when it becomes an effort to swing the spanner you are done. The spanner will not chew the chrome up as badly as the grips will. You can pinch it up as described and go turn on the water, see if it's 'all good in da hood', and if not just pinch and repeat until happy ( switch the water off each time so you're not fighting the tide ). Just turn the stopcock until you hear water flowing vs opening it fully for testing so if the shit hits the fan you have only allowed a trickle rate for damage limitation. Not much to go wrong here ( lol ) so should be job done and back on the Voddy's by noon
October 22, 20205 yr I tend to put a small smear of Vaseline on rubber washers to let them slide up tight and not “grab” the rubber.
October 23, 20205 yr 12 hours ago, joe90 said: I tend to put a small smear of Vaseline on rubber washers to let them slide up tight and not “grab” the rubber. Double edged sword, as most rubber seals need the friction to stop the washer from slipping, rolling up, and falling into the centre bore of the fitting. I never put anything on a rubber seal ? Edited October 23, 20205 yr by Nickfromwales
October 23, 20205 yr Author All done ? (well it’s not leaking which I guess is a good sign ....) Had more trouble fitting the end controls than the bar itself. I couldn’t fit the trim bits as there wasn’t enough pipe exposed to screw it into with those fitted but I guess I can get some flatter ones later if I want to. Managed to do it easily with the gripper and a cloth. Will try it out properly later and see if it’s working ok. Thanks for all the help! Just one more question - do I need to turn the stopcock on until it doesn’t turn anymore? I’ve turned it on a lot but not as far as it will go.
October 23, 20205 yr 11 minutes ago, newhome said: All done ? (well it’s not leaking which I guess is a good sign ....) Had more trouble fitting the end controls than the bar itself. I couldn’t fit the trim bits as there wasn’t enough pipe exposed to screw it into with those fitted but I guess I can get some flatter ones later if I want to. Managed to do it easily with the gripper and a cloth. Will try it out properly later and see if it’s working ok. Thanks for all the help! Just one more question - do I need to turn the stopcock on until it doesn’t turn anymore? I’ve turned it on a lot but not as far as it will go. Open fully then close half a turn or so.
October 23, 20205 yr A bit surprised to see a fibre washer used, it's normally a rubber washer used there.
October 23, 20205 yr Author The original would have been around 2010 I think. The replacement maybe a year or two later than that.
October 23, 20205 yr 4 hours ago, newhome said: All done ? (well it’s not leaking which I guess is a good sign ....) well done, we shall soon be asking you how to mend things!,!!!
October 23, 20205 yr Author 1 hour ago, joe90 said: well done, we shall soon be asking you how to mend things!,!!! God I doubt it! I’m bloody hopeless at anything practical. I’ll stick to reading VAT tribunal reports and the like lol.
October 23, 20205 yr 2 minutes ago, newhome said: I’m bloody hopeless at anything practical. well, I beg to differ, you did this didn’t you, small beginnings eh?
October 23, 20205 yr Author 37 minutes ago, joe90 said: well, I beg to differ, you did this didn’t you, small beginnings eh? Well there are a few more plumbing jobs that need to be done, although not urgent things leaking water, so maybe I’ll pluck up the courage to do some of them now .... ! I’ve used the shower to check it out and it all seems good although it’s fiercer than the old one. Not sure why that is.
October 23, 20205 yr 1 minute ago, newhome said: it’s fiercer than the old one. Not sure why that is. No two shower mixers are the same, also the old one may have “crud” In it.
October 23, 20205 yr 3 hours ago, newhome said: Well there are a few more plumbing jobs that need to be done, although not urgent things leaking water, so maybe I’ll pluck up the courage to do some of them now .... ! I’ve used the shower to check it out and it all seems good although it’s fiercer than the old one. Not sure why that is. Perhaps lack of crud. (I'm the stereo speaker.)
October 24, 20205 yr Original one was a cheapo-sack-o-shit, new one is a tidy Triton, hence the better flow rate. Adjust the shower head itself maybe for a spray vs jet ? The heads usually rotate to change settings ( the actual head where the water sprays from. 15 hours ago, newhome said: I’m bloody hopeless at anything practical. Above triumph says otherwise
October 26, 20205 yr Author On 24/10/2020 at 11:14, Nickfromwales said: Adjust the shower head itself maybe for a spray vs jet ? I quite like a fierce one ?. Onto the next job. Is changing a tower shower something I could do myself? Or is that a whole different ballgame? The thermostat is screwed and there are no spare parts for it. So I need a new one (a decent one as it’s for my en-suite).
October 26, 20205 yr Send a photo as it may be worth working out where the pipework may come into it as that will be the problem.
October 26, 20205 yr Author 21 minutes ago, PeterW said: Send a photo as it may be worth working out where the pipework may come into it as that will be the problem. It’s this one https://www.victorianplumbing.co.uk/triton-shower-tower-unichrome-thermostatic
October 26, 20205 yr Easy enough if you’re doing a like for like swap, but really it’s a 4 hands or 2 people job. The pipe connections will be fixed poking out of the wall facing up. Then the unit has its own supplied flexis which simply screw on ( 1/2” bsp ) and then the shower, most likely will have side fixings ( screw / Allen head ) and the shower prob hooks onto a top bracket ( which you can’t see ) and then gets held in place by said fixings. They’re fitted a bit like hanging a picture, so gravity bracket to free you up, and then fixings to keep it steady. Edited October 26, 20205 yr by Nickfromwales
October 26, 20205 yr Author 3 minutes ago, Nickfromwales said: Easy enough if you’re doing a like for like swap, Thanks. It can’t be like for like as it’s discontinued which is why I can’t just get a new thermostat. What I need is something that doesn’t need any ‘real’ plumbing and will be big enough to cover any existing holes in the tiles. If such a thing exists.
October 26, 20205 yr 21 minutes ago, newhome said: Thanks. It can’t be like for like as it’s discontinued which is why I can’t just get a new thermostat. What I need is something that doesn’t need any ‘real’ plumbing and will be big enough to cover any existing holes in the tiles. If such a thing exists. They’re all much of a muchness. You may have to remove that one to see what you’re up against. Then ask manufacturers for the schematic of the new one to see if there will be any conflict. If so....voddy up, hammer out ?
October 26, 20205 yr Author 10 minutes ago, Nickfromwales said: You may have to remove that one to see what you’re up against. How do I go about that then? Does the cover lift off somehow?
