NSS Posted October 21, 2020 Posted October 21, 2020 I can't be the first buildhubber fed up with a dusty garage floor, so what have you used to seal/paint/screed/tile it, would you recommend it, and how much did it cost?
Dreadnaught Posted October 21, 2020 Posted October 21, 2020 (edited) I recall that @Jeremy Harris used PVA glue on his insulated concrete raft, presumably diluted. Edited October 21, 2020 by Dreadnaught
Gav_P Posted October 21, 2020 Posted October 21, 2020 1 minute ago, Dreadnaught said: I recall that @Jeremy Harris used PVA glue on his insulated concrete raft, presumably diluted. Yup. Diluted Pva is great for sealing concrete floor. Done it in 2 houses. Then painted one afterwards.
NSS Posted October 21, 2020 Author Posted October 21, 2020 Okay, to expand, our floor is a rougher than i'd like it to be tamped finish. Ideally I'd like something that will not just seal it but help to fill some of the depressions, but strong enough to take vehicles moving in and out without cracking/lifting. Have been looking at 'high-build' epoxy paint as it's a lot cheaper than some of the alternatives, but wonder about the durability.
Dreadnaught Posted October 21, 2020 Posted October 21, 2020 8 minutes ago, Gav_P said: Done it in 2 houses. At the risk of hijacking @NSS's thread, what dilution factor do you recommend? (My concrete raft is being poured in a month or so.)
Gav_P Posted October 21, 2020 Posted October 21, 2020 11 minutes ago, Dreadnaught said: At the risk of hijacking @NSS's thread, what dilution factor do you recommend? (My concrete raft is being poured in a month or so.) I have no professional knowledge so couldn’t recommend anything. However, I just used a fairly weak solution of about 4:1... I chose this as 3:1 is the recommendation for bare plaster walls, so figured a little less would be about right. 1
Onoff Posted October 21, 2020 Posted October 21, 2020 If you're going to tile the floor later don't use PVA. Use SBR. If water gets under the tiles it'll soften the PVA and the tiles can lift. 1
Alexphd1 Posted October 21, 2020 Posted October 21, 2020 Watching this thread, planning to tile the garage but haven't ruled out a 2 part epoxy paint as a cheaper and quicker solution.
PeterW Posted October 21, 2020 Posted October 21, 2020 Plan to use this - same compressive strength as C25 concrete. Can be used as a wearing course. https://www.setcrete.co.uk/product/high-performance/ Probably got 16sqm to do at 8mm average so will need about 10 bags.
NSS Posted October 22, 2020 Author Posted October 22, 2020 2 hours ago, PeterW said: @NSS what area have you got to cover ..?? About 33m2
Nickfromwales Posted October 22, 2020 Posted October 22, 2020 8 hours ago, PeterW said: Can be used as a wearing course. And if you put a vehicle in there, wear it will. IMO you won’t beat a good 2-part paint, but you cannot go “cheap”. Chuck a cheapo diamond grinding disk onto a 4” grinder and knock the tips off anything projecting ( significantly ) and away to go. Serious hardiness will be achieved when you apply a refresher coat later down the line and the layers build up.
jack Posted October 22, 2020 Posted October 22, 2020 I used a high-build epoxy paint product. Can recommend the guys at Promain - excellent advice. If you're going to spend a lot on epoxy (and it's way more expensive than regular floor paint), you need to make sure you get the prep right. We had really bad spalling in places, so I rented a floor grinder. It was very expensive due to the amount of wear I put on the diamond pads, and that was without taking it all the way back to perfectly smooth. I doubt I'd take that approach if I were doing it again. I really liked the idea of one of the epoxy self-levelling products to build up a thicker coat, but it was expensive, and I was worried about having to mix and lay it while keeping a wet edge (etc). Given how much the grinding cost, however, I think it might actually have been cheaper to go this way, and the result would almost certainly have been better. While the high build product I used did iron out the finer imperfections, it doesn't really do much for deeper marks. You can still clearly see tamp marks in places where I wasn't able to grind them completely off, for example. 2
Onoff Posted October 22, 2020 Posted October 22, 2020 I painted my garage floor with single pack paint. It hadn't been painted since it was laid and luckily had no oil staining etc. I knocked off all the laitance with a cup brush on a grinder then vacuumed it with the shop vac...then vacuumed it again. A messy, dusty job but we'll worth the effort. I had a fair bit of various shades of grey floor paint, some bought, some full, some half and scored off sites, all different makes. All went into an old 5gal brewing barrel and got mixed with a stick. Applied with a cheap plastic broom. Done 10 years ago probably and all good. 1
Nestor Posted October 23, 2020 Posted October 23, 2020 On 21/10/2020 at 23:41, PeterW said: Plan to use this - same compressive strength as C25 concrete. Can be used as a wearing course. https://www.setcrete.co.uk/product/high-performance/ Probably got 16sqm to do at 8mm average so will need about 10 bags. Hi Pete, Can you let us know how you get on with this product. Is a wearing course mean suitable as a final floor covering, foot traffic only. I might do a test and add some small stones to then grind back. Also do you know of an additive to change the colour of the product, maybe a grout?
PeterW Posted October 23, 2020 Posted October 23, 2020 31 minutes ago, JamesP said: Can you let us know how you get on with this product. Is a wearing course mean suitable as a final floor covering, foot traffic only. Has a 28 day strength of 25N/mm so is identical to C25 concrete at 5mm deep. I think it will take a car no issue as it will bond to the concrete sub base. 1
