September 2, 20206 yr Hi, I have read on a few sites that to achieve the best possible efficiency, it is best to keep the intake and exhaust duct length below 1.5m. Depending on the location of the unit, it may not always be possible so I was just curious...how much impact it would really have, if the length was over this 1.5m recommendation. Thank you Edited September 2, 20206 yr by NickK
September 2, 20206 yr Low impact, up to 3m after that you should increase the size of the duct to the next size up, 200 to 250mm for the whole length
September 2, 20206 yr I'd focus more on the straightness of runs rather than the length, and making sure they are well insulated.
November 15, 20205 yr This seems like a bit of a contradiction, if the minimum recommended distance between Intake and Exhaust is 3m, how do you keep the distance to 1.5m. Unless fitted in the roof, one pipe will need two 90 degree turns to exit building and be far enough away from other pipe.
November 15, 20205 yr Mine are about 2m apart on the North outside wall fed by about 1.5m flexible pipes and insulated. Edited November 15, 20205 yr by joe90
November 15, 20205 yr 1 hour ago, Nick Laslett said: Unless fitted in the roof, one pipe will need two 90 degree turns to exit building and be far enough away from other pipe. IIRC our outside vents are 3.5m apart so our pipework is 5m for one vent and 1.5m for the other. I used 45 degree bends to reduce restriction of air flow.
November 15, 20205 yr 1 hour ago, Nick Laslett said: This seems like a bit of a contradiction, if the minimum recommended distance between Intake and Exhaust is 3m, how do you keep the distance to 1.5m. Unless fitted in the roof, one pipe will need two 90 degree turns to exit building and be far enough away from other pipe. Correct. That’s not a problem at all.
November 15, 20205 yr 23 minutes ago, PeterStarck said: IIRC our outside vents are 3.5m apart so our pipework is 5m for one vent and 1.5m for the other. I used 45 degree bends to reduce restriction of air flow. Most decent 90o bends are 2x 45’s back to back in one piece.
November 15, 20205 yr 28 minutes ago, Nickfromwales said: Most decent 90o bends are 2x 45’s back to back in one piece. I prefer the ones that are 4 x 22.5's myself.
November 15, 20205 yr 3 hours ago, PeterStarck said: IIRC our outside vents are 3.5m apart so our pipework is 5m for one vent and 1.5m for the other. I used 45 degree bends to reduce restriction of air flow. Thank you Peter. Is the 1.5m pipe the intake?
November 15, 20205 yr 15 minutes ago, Nick Laslett said: Thank you Peter. Is the 1.5m pipe the intake? No it's the exhaust. I thought because the exhaust is more likely to have condensation in it I would want it to drain quickly. The ducting slopes down to the outside vents and I've used 45 degree bends spaced apart.
November 15, 20205 yr Initially I did not insulate my two outside connections and it was the intake that formed condensation on the outside. Cold incoming air in a warm roof. I insulated both to make sure.
November 15, 20205 yr Author Hello, From what I’m researched the reason to keep the lengths short was mainly to maximise summer bypass but then it depends on each projects specifics.
November 15, 20205 yr If the intake and the unit itself are properly insulated then it doesn’t matter too much how long the intake / extracts are. It’s more important to keep them large diameter and straight as possible.
November 15, 20205 yr I have done some calcs on this and given the other drops (pressure) in the system, it appears acceptable to have a few meters of pipe on that side. The following is for my nominal flow of 132m3 and ~5m of pipe. I allowed for 4 bends (1-2 to form a U after leaving the unit upwards, 3 to turn horizontal on the floor and 4 to hit the cowling). Tony is right though, if the runs get longer you may need to go up a step on diameter. By comparison, a 15m 75mm double run with one bend along the way to a bathroom extracting 45m3/h will have around 40Pa drop. This is excluding the pressure drops in the pipe, mufflers, bends and the distribution box. P.S. These are all my own calculations. Edited November 15, 20205 yr by Levo
