Russdl Posted June 1, 2020 Posted June 1, 2020 We have two completely plain door blanks that will be pocket doors and we want to get them sprayed because my thoughts are that sprayed doors will look better than hand painted. Trouble is I can't find anyone locally who will do it so, the questions are: 1. Will spraying give a superior finish on a featureless door blank? 2. If not, what will? 3. Who can do it in the Salisbury area? Standing by...
dpmiller Posted June 1, 2020 Posted June 1, 2020 Most car bodyshops will also do interior bits like this, and there are plenty of guys doing kitchen door respray/ refurbs. 1
Russdl Posted June 1, 2020 Author Posted June 1, 2020 @dpmiller I've tried the car body shops, no one can/will in the local area. 8 minutes ago, dpmiller said: kitchen door respray/ refurbs I'll try Googling that phrase, see where it gets me. Ta.
Russell griffiths Posted June 1, 2020 Posted June 1, 2020 Tbh just two doors will cost a fair bit, as they will need to set up for your type of paint and then clean the gun after. Have you tried a good roller. I used an acrylic eggshell on my doors and got a good finish from a roller, light sanding between coats.
ToughButterCup Posted June 1, 2020 Posted June 1, 2020 Here's a really good breakdown of how to both spray and roll at sensible prices. Top bloke is Peter Millard, top bloke. 1
Russdl Posted June 1, 2020 Author Posted June 1, 2020 44 minutes ago, Russell griffiths said: Have you tried a good roller. No. I'm convinced I'd screw it up! @AnonymousBosch I'll take a look and perhaps be able to delete my comment above.
joe90 Posted June 1, 2020 Posted June 1, 2020 Well painting is a pet hate of mine (which is why I paid a local decorator to paint my new build) however, on my last job before retiring I could not find someone to paint a door blank but was told to use a gloss roller (small foam thing), I was amazed, really good finish after light sanding between coats (I would still rather pay someone tho ?).
Nick1c Posted June 1, 2020 Posted June 1, 2020 A mate used Owatrol paint conditioner & raved about the finish he got.
Russdl Posted June 1, 2020 Author Posted June 1, 2020 @joe90 after seeing the videos that @AnonymousBosch linked I’m tentatively thinking of giving it a go with said foam rollers, the blanks have been cut down a little bit so I’ve got 4 off cuts to hone my skills on before I go for the big one. @Nick1c thanks, absolutely no idea what Owatrol is I’ll have a look-see ?
Nick1c Posted June 1, 2020 Posted June 1, 2020 Me neither, but apparently it does what it says on the tin! https://www.owatroldirect.co.uk/product/floetrol/ 1
joe90 Posted June 1, 2020 Posted June 1, 2020 Yes, my decorator mentioned paint conditioner as good for better results. ?
Russdl Posted June 1, 2020 Author Posted June 1, 2020 @Nick1c interesting, thanks. How much more do I have to learn before this project is complete? Sadly I’m a bit like Homer Simpson, every time I learn something new my brain has to dump something to make room for it. 1
Russdl Posted June 15, 2020 Author Posted June 15, 2020 I had a look at the videos as recommended by The Shapeshifter er, I mean @ToughButterCup and they were very informative, but as predicted my results are far from ideal. It's a plywood faced door blank which I have sanded, primed, filled, sanded, undercoated, sanded, undercoated and have now applied one coat of topcoat with a high density foam roller. Whilst at first glance it looks ok, on closer examination it's clearly painted plywood. Does anyone know if the paint conditioner as mentioned by @Nick1c will cause the paint to fill all the very minor imperfections in the plywood and give a finish as smooth as a babies bum?
PeterW Posted June 15, 2020 Posted June 15, 2020 39 minutes ago, Russdl said: I had a look at the videos as recommended by The Shapeshifter er, I mean @ToughButterCup and they were very informative, but as predicted my results are far from ideal. It's a plywood faced door blank which I have sanded, primed, filled, sanded, undercoated, sanded, undercoated and have now applied one coat of topcoat with a high density foam roller. Whilst at first glance it looks ok, on closer examination it's clearly painted plywood. Does anyone know if the paint conditioner as mentioned by @Nick1c will cause the paint to fill all the very minor imperfections in the plywood and give a finish as smooth as a babies bum? What was the last grade paper you used to sand it..? The only way I have got rid of woodgrain is to use car filler and then 400 grade wet and dry paper - takes ages but it is the only thing that works unless you use high build primer and a decent gloss of two or three coats.
Russdl Posted June 15, 2020 Author Posted June 15, 2020 @PeterW Ah. 120 grit, so there’s part of my problem then.
PeterW Posted June 15, 2020 Posted June 15, 2020 Yep you will be digging the filler from the wood grain. Also helps if you can work the door perfectly flat as it lets the paint settle.
Russdl Posted June 15, 2020 Author Posted June 15, 2020 @PeterW excellent, I’m doing one thing right. The door is perfectly flat (and definitely not looking like a sprayed door yet).
