ProDave Posted December 4, 2016 Share Posted December 4, 2016 I need to buy a tool. I know they exist, but not knowing what the correct name is, I can't seem to find one. It's ever so simple. I want an 8mm hex socket, but instead of it having a square female drive (to be used e.g with a ratchet) I need it to have a male hex drive so I can use it with a cordless screwdriver to run in coach bolts that have a hex head. I can't seem to find one. but that's because I don't know what they are called (hex drive socket didn't get me very far) It would be great if CPC had them as I am about to place an order from CPC. But the bext I have found from CPC is this http://cpc.farnell.com/hilka-tools/37955003/socket-adaptor-set-3pc/dp/TL17207?ost=tl17207&selectedCategoryId=&categoryNameResp=All%2BCategories&searchView=table&iscrfnonsku=false which would do what I want in conjunction with a standard square drive socket, but I really want the dedicated tool, hex drive to 8mm socket. Link to comment Share on other sites More sharing options...
Guest Alphonsox Posted December 4, 2016 Share Posted December 4, 2016 Something like this ? https://www.amazon.co.uk/Sourcingmap-a11030800ux0455-Magnetic-Driver-Spanner/dp/B0052WCMNY or this ? https://www.amazon.co.uk/Toolzone-8Pc-Shank-Drivers-5-11mm/dp/B002NH3XMK/ref=pd_lpo_60_tr_t_3?_encoding=UTF8&psc=1&refRID=NJEY96S4XWH7Z7FSFAKS Link to comment Share on other sites More sharing options...
Tennentslager Posted December 4, 2016 Share Posted December 4, 2016 Screwfix http://www.screwfix.com/p/erbauer-impact-hex-nut-driver-8mm/5169d?_requestid=464170 Link to comment Share on other sites More sharing options...
Onoff Posted December 4, 2016 Share Posted December 4, 2016 (edited) Do you mean these Dave? I can stick a couple in the post if you want tomorrow. Came with "Timbalock/fast/fix..." screws years ago when I was buying them in bulk and one came in each box: Tbh. you buying at Toolstation might be cheaper than the postage but I don't mind, let me know: http://www.toolstation.com/shop/p24949?table=no Edited December 4, 2016 by Onoff Link to comment Share on other sites More sharing options...
Ferdinand Posted December 4, 2016 Share Posted December 4, 2016 If you buy the right box of hex headed fencing screws from Wickes you get one in the box. Link to comment Share on other sites More sharing options...
Construction Channel Posted December 4, 2016 Share Posted December 4, 2016 If you haven't already got a set, i would recommend getting the adaptors you linked in the OP, I very rarely do anything up by hand since i bought mine I searched 8mm and got there eventually http://cpc.farnell.com/silverline/277866/magnetic-nut-driver-8mm/dp/TL17319 1 Link to comment Share on other sites More sharing options...
Onoff Posted December 4, 2016 Share Posted December 4, 2016 A tougher driver at CPC: http://cpc.farnell.com/dewalt/dt7430-qz/cleanable-nutsetter-8mm/dp/TL18339?ost=8mm+hex&selectedCategoryId=&categoryId=700000008548&searchView=table&iscrfnonsku=false Link to comment Share on other sites More sharing options...
ProDave Posted December 4, 2016 Author Share Posted December 4, 2016 25 minutes ago, Construction Channel said: If you haven't already got a set, i would recommend getting the adaptors you linked in the OP, I very rarely do anything up by hand since i bought mine I searched 8mm and got there eventually http://cpc.farnell.com/silverline/277866/magnetic-nut-driver-8mm/dp/TL17319 As I said in the OP, it was knowing what to call it. It's obvious that it's not am 8mm hex drive socket, but it's a magnetic nut runner. Why didn't I think of that? I will order one of those and one of the socket adaptor sets so I can do other sizes with a standard socket. P.S you might have noticed CPC's website search tool is not the best. 1 Link to comment Share on other sites More sharing options...
Steptoe Posted December 4, 2016 Share Posted December 4, 2016 CPC s website search tool is dire, to put it mildly, I use the catalogue, then look up the part number on website usually. Link to comment Share on other sites More sharing options...
PeterW Posted December 4, 2016 Share Posted December 4, 2016 I search CPC using the google search bar - much easier ...!! Link to comment Share on other sites More sharing options...
ProDave Posted December 4, 2016 Author Share Posted December 4, 2016 2 hours ago, Steptoe said: CPC s website search tool is dire, to put it mildly, I use the catalogue, then look up the part number on website usually. When you do that, try adding the 2 digit suffix to the order code from the latest weekly offers flyer. A surprising number of items that are not in the weekly offers do appear to be discounted if you care to try. 1 Link to comment Share on other sites More sharing options...
Steptoe Posted December 5, 2016 Share Posted December 5, 2016 4 hours ago, ProDave said: When you do that, try adding the 2 digit suffix to the order code from the latest weekly offers flyer. A surprising number of items that are not in the weekly offers do appear to be discounted if you care to try. Yep, I do that with everything, they usually have maybe 2 or 3 codes running at any one time, I try them all, Link to comment Share on other sites More sharing options...
jack Posted December 5, 2016 Share Posted December 5, 2016 16 hours ago, Steptoe said: CPC s website search tool is dire, to put it mildly, I use the catalogue, then look up the part number on website usually. Amen to that. I thought I was going made recently when I tried to buy an extension reel. The one that was in the catalogue just didn't come up in any word-based searches, and I could only get to it by using the part number. Crazy. Link to comment Share on other sites More sharing options...
