Russdl Posted Wednesday at 22:55 Posted Wednesday at 22:55 Wouldn’t one of the problems be insufficient parking space? You’ve not mentioned that.
torre Posted 18 hours ago Posted 18 hours ago (edited) 10 hours ago, Bluebaron said: overbearing and cramped So you didn't directly address the first reason for refusal and made only a minor change to somewhat address the second? It sounds like you had misgivings about the consultant's approach and maybe should have trusted your instincts - what did they submit that was likely to change the decision? Because on the face of it, the planners were almost bound to refuse again. If the consultant addressed this up front and suggested you'd need to go to appeal to keep the original design then your course is surely set that way, but otherwise they so far haven't demonstrated much understanding of the local planners or how to address the reasons for refusal and I'd be tempted to scale down a bit in a fresh application as it'll be quicker and lower risk. E.g. Make the garage into a smaller extra room but with the width reduced a bit and set back to still allow parking by the tree, look to utilise the loft space, perhaps accept going to 3 bed. You may help retain the value of the original property too by making it's new neighbour less overbearing. Edited 18 hours ago by torre more clarity
Bluebaron Posted 13 hours ago Posted 13 hours ago (edited) 14 hours ago, Russdl said: Wouldn’t one of the problems be insufficient parking space? You’ve not mentioned that. no highways had no objections and planner noted that scheme was acceptable. 4 hours ago, torre said: So you didn't directly address the first reason for refusal and made only a minor change to somewhat address the second? It sounds like you had misgivings about the consultant's approach and maybe should have trusted your instincts - what did they submit that was likely to change the decision? Because on the face of it, the planners were almost bound to refuse again. If the consultant addressed this up front and suggested you'd need to go to appeal to keep the original design then your course is surely set that way, but otherwise they so far haven't demonstrated much understanding of the local planners or how to address the reasons for refusal and I'd be tempted to scale down a bit in a fresh application as it'll be quicker and lower risk. E.g. Make the garage into a smaller extra room but with the width reduced a bit and set back to still allow parking by the tree, look to utilise the loft space, perhaps accept going to 3 bed. You may help retain the value of the original property too by making it's new neighbour less overbearing. yes that's correct. I queried what amendments i should make (primarily make it smaller) and in his professional opinion by amending the plot size we could skirt the 'cramped' comment. 'Overbearing' is subjective and the design is such that any change would look out of character and odd in the street scene. As such apart from some changes to the driveway/internal we basically resubmitted the same thing. I did mention appealing the original decision but we had a few technical issue around trees/RPA's so they needed addressing. i'm speaking with both the local planning officer and the consultant tomorrow to discuss options. Edited 13 hours ago by Bluebaron
Bluebaron Posted 13 hours ago Posted 13 hours ago What really grates is the report mentions “ prominent corner plot” at multiple times .This plot is the end of a cul-de-sac. 🤷🏻♂️
Nestor Posted 13 hours ago Posted 13 hours ago Did you purchase the property in September 2024 with the sole purpose of building on the corner plot? You are taking full advantage of the plot size so not surprised with some push back. Another attempt with the planning consultant should get you your result.
Bluebaron Posted 12 hours ago Posted 12 hours ago 50 minutes ago, Nestor said: Did you purchase the property in September 2024 with the sole purpose of building on the corner plot? You are taking full advantage of the plot size so not surprised with some push back. Another attempt with the planning consultant should get you your result. Not really it was an after thought after I realised the land registry was incorrect and I owned more land than originally thought.
ProDave Posted 12 hours ago Posted 12 hours ago 1 hour ago, Bluebaron said: Looking at that aerial view I see another detached house on the other side of the road. Was that also built after the original houses on the side garden? How does that one opposite compare in size and bulk to what you are proposing? It looks to me only slightly wider than the original semi detached houses with a single storey garage. If you submitted something like that, and it was still refused, you would have very good grounds to appeal. Just because you have used a planning consultant to get this far, an appeal can be done yourself for virtually no cost if you are just appealing a refused application.
Bluebaron Posted 10 hours ago Posted 10 hours ago The house opposite was actually original although they have planning for a two storey (set back) side extension. I was attempting to mirror the street scene with my original proposal.
Nestor Posted 9 hours ago Posted 9 hours ago (edited) 2 hours ago, Bluebaron said: Not really it was an after thought after I realised the land registry was incorrect and I owned more land than originally thought. That was a bonus. Your proposal (Double fronted) and the corner home opposite yours, you can understand the comments cramped and overbearing. Difficult design to compromise if wanting the double frontage. You will get there. Edited 9 hours ago by Nestor
ProDave Posted 9 hours ago Posted 9 hours ago If you really want the double fronted, make the left hand half above the garage set back a little with a stepped roof line, making it look right from the start like a subservient extension on the side (probably like has been approved for the house opposite) 1
Nestor Posted 9 hours ago Posted 9 hours ago 9 minutes ago, ProDave said: If you really want the double fronted, make the left hand half above the garage set back a little with a stepped roof line, making it look right from the start like a subservient extension on the side (probably like has been approved for the house opposite) Good point and I would switch the garage to the right hand side to create more visual space to no 35. Worth doing a few visuals.
Bluebaron Posted 9 hours ago Posted 9 hours ago I have been attempting to replicate similar properties that have had extensions like this.
Nestor Posted 8 hours ago Posted 8 hours ago This was your second refusal? Some random grabs from a quick search, 2 have a front facing gable which are probably not suitable and 2 hipped with garage on right hand side. Looking at past planning applications, your neighbours have planning for only single storey extensions, the only 2 storey application was refused in 2006.
Nestor Posted 2 hours ago Posted 2 hours ago (edited) Enclosed are the drawings of the application for a 2 storey extension at no 33 back in 2006. Was refused. You have also had 11 objection letters from your neighbours. Also the removal of 2 mature oak trees prior to planning does not go down well with the locals. Not sure your planning consultant is listening. Good luck. Edited 2 hours ago by Nestor
