Russdl Posted Wednesday at 22:55 Posted Wednesday at 22:55 Wouldn’t one of the problems be insufficient parking space? You’ve not mentioned that.
torre Posted Thursday at 08:15 Posted Thursday at 08:15 (edited) 10 hours ago, Bluebaron said: overbearing and cramped So you didn't directly address the first reason for refusal and made only a minor change to somewhat address the second? It sounds like you had misgivings about the consultant's approach and maybe should have trusted your instincts - what did they submit that was likely to change the decision? Because on the face of it, the planners were almost bound to refuse again. If the consultant addressed this up front and suggested you'd need to go to appeal to keep the original design then your course is surely set that way, but otherwise they so far haven't demonstrated much understanding of the local planners or how to address the reasons for refusal and I'd be tempted to scale down a bit in a fresh application as it'll be quicker and lower risk. E.g. Make the garage into a smaller extra room but with the width reduced a bit and set back to still allow parking by the tree, look to utilise the loft space, perhaps accept going to 3 bed. You may help retain the value of the original property too by making it's new neighbour less overbearing. Edited Thursday at 08:15 by torre more clarity
Bluebaron Posted Thursday at 13:06 Posted Thursday at 13:06 (edited) 14 hours ago, Russdl said: Wouldn’t one of the problems be insufficient parking space? You’ve not mentioned that. no highways had no objections and planner noted that scheme was acceptable. 4 hours ago, torre said: So you didn't directly address the first reason for refusal and made only a minor change to somewhat address the second? It sounds like you had misgivings about the consultant's approach and maybe should have trusted your instincts - what did they submit that was likely to change the decision? Because on the face of it, the planners were almost bound to refuse again. If the consultant addressed this up front and suggested you'd need to go to appeal to keep the original design then your course is surely set that way, but otherwise they so far haven't demonstrated much understanding of the local planners or how to address the reasons for refusal and I'd be tempted to scale down a bit in a fresh application as it'll be quicker and lower risk. E.g. Make the garage into a smaller extra room but with the width reduced a bit and set back to still allow parking by the tree, look to utilise the loft space, perhaps accept going to 3 bed. You may help retain the value of the original property too by making it's new neighbour less overbearing. yes that's correct. I queried what amendments i should make (primarily make it smaller) and in his professional opinion by amending the plot size we could skirt the 'cramped' comment. 'Overbearing' is subjective and the design is such that any change would look out of character and odd in the street scene. As such apart from some changes to the driveway/internal we basically resubmitted the same thing. I did mention appealing the original decision but we had a few technical issue around trees/RPA's so they needed addressing. i'm speaking with both the local planning officer and the consultant tomorrow to discuss options. Edited Thursday at 13:07 by Bluebaron
Bluebaron Posted Thursday at 13:35 Posted Thursday at 13:35 What really grates is the report mentions “ prominent corner plot” at multiple times .This plot is the end of a cul-de-sac. 🤷🏻♂️
Nestor Posted Thursday at 14:03 Posted Thursday at 14:03 Did you purchase the property in September 2024 with the sole purpose of building on the corner plot? You are taking full advantage of the plot size so not surprised with some push back. Another attempt with the planning consultant should get you your result.
Bluebaron Posted Thursday at 14:54 Posted Thursday at 14:54 50 minutes ago, Nestor said: Did you purchase the property in September 2024 with the sole purpose of building on the corner plot? You are taking full advantage of the plot size so not surprised with some push back. Another attempt with the planning consultant should get you your result. Not really it was an after thought after I realised the land registry was incorrect and I owned more land than originally thought.
ProDave Posted Thursday at 14:57 Posted Thursday at 14:57 1 hour ago, Bluebaron said: Looking at that aerial view I see another detached house on the other side of the road. Was that also built after the original houses on the side garden? How does that one opposite compare in size and bulk to what you are proposing? It looks to me only slightly wider than the original semi detached houses with a single storey garage. If you submitted something like that, and it was still refused, you would have very good grounds to appeal. Just because you have used a planning consultant to get this far, an appeal can be done yourself for virtually no cost if you are just appealing a refused application.
Bluebaron Posted Thursday at 16:30 Posted Thursday at 16:30 The house opposite was actually original although they have planning for a two storey (set back) side extension. I was attempting to mirror the street scene with my original proposal.
Nestor Posted Thursday at 17:06 Posted Thursday at 17:06 (edited) 2 hours ago, Bluebaron said: Not really it was an after thought after I realised the land registry was incorrect and I owned more land than originally thought. That was a bonus. Your proposal (Double fronted) and the corner home opposite yours, you can understand the comments cramped and overbearing. Difficult design to compromise if wanting the double frontage. You will get there. Edited Thursday at 17:07 by Nestor
ProDave Posted Thursday at 17:15 Posted Thursday at 17:15 If you really want the double fronted, make the left hand half above the garage set back a little with a stepped roof line, making it look right from the start like a subservient extension on the side (probably like has been approved for the house opposite) 1
Nestor Posted Thursday at 17:26 Posted Thursday at 17:26 9 minutes ago, ProDave said: If you really want the double fronted, make the left hand half above the garage set back a little with a stepped roof line, making it look right from the start like a subservient extension on the side (probably like has been approved for the house opposite) Good point and I would switch the garage to the right hand side to create more visual space to no 35. Worth doing a few visuals.
Bluebaron Posted Thursday at 17:29 Posted Thursday at 17:29 I have been attempting to replicate similar properties that have had extensions like this.
Nestor Posted Thursday at 18:41 Posted Thursday at 18:41 This was your second refusal? Some random grabs from a quick search, 2 have a front facing gable which are probably not suitable and 2 hipped with garage on right hand side. Looking at past planning applications, your neighbours have planning for only single storey extensions, the only 2 storey application was refused in 2006.
Nestor Posted Friday at 00:41 Posted Friday at 00:41 (edited) Enclosed are the drawings of the application for a 2 storey extension at no 33 back in 2006. Was refused. You have also had 11 objection letters from your neighbours. Also the removal of 2 mature oak trees prior to planning does not go down well with the locals. Not sure your planning consultant is listening. Good luck. Edited Friday at 01:03 by Nestor
Bluebaron Posted Friday at 09:07 Posted Friday at 09:07 thanks for the input everyone. does anyone think the case officer was correct in stating this was a "prominent corner plot", as i think this will be the main basis of my appeal.
ProDave Posted Friday at 09:11 Posted Friday at 09:11 With even fairly simple extensions like the post above being refused, I have to ask, are you in a conservation area?
Bluebaron Posted Friday at 09:23 Posted Friday at 09:23 12 minutes ago, ProDave said: With even fairly simple extensions like the post above being refused, I have to ask, are you in a conservation area? No
Nestor Posted Friday at 10:35 Posted Friday at 10:35 1 hour ago, Bluebaron said: thanks for the input everyone. does anyone think the case officer was correct in stating this was a "prominent corner plot", as i think this will be the main basis of my appeal. It is all subjective but I would not call this " a prominent corner plot" even though the case officer seems to be on your side. It is overbearing and cramped. All are semis with a driveway between except number 42 with a separate garage at the rear. You have had 19 letters of objection. Upset the Arboricultural Officer and Natural England. No property in the street has had a two storey extension built. All single storey wraparound. Look at no 33 for ideas, looks like garage with a mono pitch roof or imagine no 42 with an attached garage.
torre Posted Friday at 10:39 Posted Friday at 10:39 1 hour ago, Bluebaron said: does anyone think the case officer was correct in stating this was a "prominent corner plot" On the face if it, no - "tucked away around the corner of a quiet cul de sac" sounds more appropriate, but if your street is the main walking route used by people to visit the park or whatever at the top of your aerial view then yes it would be prominent and a large house there might seem overbearing.
Nestor Posted Saturday at 22:46 Posted Saturday at 22:46 54 minutes ago, ETC said: Just a few thoughts….. Progress, Option 1. Huge improvement. Great to see a contemporary new build design instead of rehashing the existing vernacular. Personally, it is a tricky site with minimal parking for both properties, I think a 3 bed with attached garage would be acceptable.
Oz07 Posted yesterday at 08:58 Posted yesterday at 08:58 11 hours ago, ETC said: Just a few thoughts….. "That valleys gonna give me problems down the line"? 1
torre Posted yesterday at 09:11 Posted yesterday at 09:11 10 hours ago, Nestor said: Great to see a contemporary new build design instead of rehashing the existing vernacular. I agree, but if you thought 19 objections last time was a lot, this will probably stir up more and open up other possible grounds for refusal (not in keeping with the area)
Nestor Posted yesterday at 10:23 Posted yesterday at 10:23 1 hour ago, torre said: I agree, but if you thought 19 objections last time was a lot, this will probably stir up more and open up other possible grounds for refusal (not in keeping with the area) I. agree, you agree. It was really a comment on @ETC contributions. Addressing overbearing and cramped should get this passed. 11 hours ago, Nestor said: Personally, it is a tricky site with minimal parking for both properties, I think a 3 bed with attached garage would be acceptable. 1
