Disabled WC Dimensions
SCOTT_Scott
Hi
I am developing a project and i need to provide Acc. WC I understand that in Northern Ireland BC tech Booklet R the Acc. WC has to be a min size of 2200*1500.
Do wall tiles and finishes have an impact on this dimension, or is the measurement taken when the room is studded out?
Thanks In Advance
Scott
I don't know about NI regs but in England it would be the internal dimensions after tiling. Here there are also minimum distances between basin and wall (eg so a wheel chair can get from a door, past the basin to the WC).
2 hours ago, SCOTT_Scott said:
Hi
Thanks In Advance
Scott
Surely the measurement will be taken when the room is finished?
If I am in a wheelchair I cannot turn around inside the depth of the tiles ? .
Unless it is Star Trek and I am slightly out of Phase with my bathroom, but then the shower won't work either as it will go straight through me.
Aside: I blogged an accessible bathroom project, which may be helpful.
On commercial buildings the drawings for framing are always 2000x2000
On the private houses I normally build 2000 deep x 1800 minimum
I’ve only experience of building in England
I would have thought a wheel chair
loo and door opening wouldn’t vary much
door size --there is a minimimum ,  1000mm?I remember that from doing our disabled loo in garage when we split it ito 3 units .
there is or was ,in Scotland, a half way house which is sometimes allowed depending on BC man and the  building you are working with
It is called an ambulant toilet-- it can be samller .
I was allowed that in my showroom unit.
yet for my workshop /customer reception  where there will never be any wheelchair mechanics  I had to have full disabled,
you begin to wonder when it will be a requirement for a new build to have a disabled loo or at least an ambulant one ,we already have to have ramps and as most houses will have more than one --then i can see ground floor one could be a target  for them to be made compliant,even if its just size  tostart with so it can be converted  infutre if need  arises  to make stay at home social care a bigger possibility ,certainly worth considering if designing your new forever home
that and enough space for a lift shaft  in future,which can be storage space till then
floor plan  --check this out
https://www.moreability.co.uk/help-advice/2018/08/disabled-toilet-size
Edited by scottishjohn
  • 2 weeks later...
I think a lot of people confuse "accessible sanitary facilities" with being fully wheelchair compliant, myself included when I first started reading the regs. If I now understand it correctly this allows for those of limited mobility full comfortable access, although I think it does talk about wheelchair access?
These facilities need to have one on each floor and space for a shower on the principal living floor, or is it just principal living floor? Hence new builds now having a massive WC downstairs that often feels unproportional.
I did find a Glasgow CC document that sums up fully wheelchair compliant living standards.
