Stones Posted December 11, 2019 Share Posted December 11, 2019 I recently found that our potable DHW expansion vessel was full of water. I swapped it out with a direct replacement and all is now well with our system. On undertaking an autopsy of the defective expansion vessel, I found that the bladder had failed / split. Clearly it had been split for some time as the water that came out of the vessel was rust coloured. Whilst I can easily source a replacement bladder, fit and recharge the vessel to have as an off the shelf spare, I'm wondering whether this is worthwhile or advisable given that there has been some corrosion within the vessel (to produce the rust coloured water)? The vessel is in otherwise great condition. Thoughts? Link to comment Share on other sites More sharing options...
PeterW Posted December 11, 2019 Share Posted December 11, 2019 Yes can be done - check this list https://www.altecnic.co.uk/domestic/solar/vessel/156/ Link to comment Share on other sites More sharing options...
JFDIY Posted December 11, 2019 Share Posted December 11, 2019 I guess it depends if it makes any financial sense, and do you have a use for it? If it's going to sit as a spare for 'one day' then by the time you need it the chances are it's life will be limited due to age, and you've got to store it in the meantime. Link to comment Share on other sites More sharing options...
ProDave Posted December 11, 2019 Share Posted December 11, 2019 Interesting. I had one that failed, that I kept for years, wanting to so a post mortem, but could find no way to open it to get at the bladder short of cutting it in half with an angle grinder, which would make it rather hard to put back together. 1 Link to comment Share on other sites More sharing options...
PeterW Posted December 11, 2019 Share Posted December 11, 2019 4 or 6 bolts round the rim but make sure it’s definitely depressurised as the bladders can fly quite a distance ...... according to what a friend told me .. ? :cough: 2 Link to comment Share on other sites More sharing options...
dpmiller Posted December 12, 2019 Share Posted December 12, 2019 Is there any issue with using a potable vessel (replaceable bladder) on a heating system? Link to comment Share on other sites More sharing options...
PeterW Posted December 12, 2019 Share Posted December 12, 2019 2 minutes ago, dpmiller said: Is there any issue with using a potable vessel (replaceable bladder) on a heating system? no as they tend to just be epoxy lined steel shells with food grade EDPM bladders. It’s the other way you don’t want to do it. Link to comment Share on other sites More sharing options...
Nickfromwales Posted December 12, 2019 Share Posted December 12, 2019 Just bin the thing. If it went anywhere near prematurely it’s probably down to continuously rubbing against a surface imperfection on the inside of the vessel. Move on and don’t waste time / money, they’re just too cheap to buy / replace. 1 Link to comment Share on other sites More sharing options...
Stones Posted December 12, 2019 Author Share Posted December 12, 2019 10 hours ago, PeterW said: 4 or 6 bolts round the rim That's what mine is like, a flange bolted to the body compressing the bladder in position. 29 minutes ago, Nickfromwales said: Just bin the thing. If it went anywhere near prematurely it’s probably down to continuously rubbing against a surface imperfection on the inside of the vessel. Move on and don’t waste time / money, they’re just too cheap to buy / replace. Fair point. Link to comment Share on other sites More sharing options...
Stones Posted December 12, 2019 Author Share Posted December 12, 2019 Any suggestions what I could do with the vessel body if I'm not going to refurb it for its original purpose? It's a 24 litre. Link to comment Share on other sites More sharing options...
PeterW Posted December 12, 2019 Share Posted December 12, 2019 2 minutes ago, Stones said: Any suggestions what I could do with the vessel body if I'm not going to refurb it for its original purpose? It's a 24 litre. Post it to @Onoff to add to his pile of tat useful items for future projects.... 2 1 Link to comment Share on other sites More sharing options...
scottishjohn Posted December 12, 2019 Share Posted December 12, 2019 3 hours ago, Stones said: Any suggestions what I could do with the vessel body if I'm not going to refurb it for its original purpose? It's a 24 litre. If its vertical one with legs --a plant pot Link to comment Share on other sites More sharing options...
