CC45 Posted December 10, 2019 Posted December 10, 2019 I've finally got sick of groping for the light switch in our garage - so I thought I'd put a switch on the door and connect that up to a small led - like a plinth light, that would shine down from the ceiling illuminating the switch when the door is opened. Not keen on buying a pack of 10 + 1 extra transformer just to use 2 lights (got 2 switches to illuminate) so has anyone got a different solution? cheers. cc
Carrerahill Posted December 10, 2019 Posted December 10, 2019 (edited) Buy a LED bulkhead like this: https://asdlighting.com/products/centro-range/centro-circo/ or https://asdlighting.com/products/clarity-range/clarity-portrait-plain/ Get the model with built in presence detection, they consume less than 16/8W depending on model - walk into garage this product comes on, probably bright enough for simple tasks or getting something out of garage, set it to run for a minute or something or even less when no motion is detected - job done. Edited December 10, 2019 by Carrerahill 1
Onoff Posted December 10, 2019 Posted December 10, 2019 How about a solar power one where the panel and lamp are separate? This sort of thing. Mount panel outside and light inside: https://www.wish.com/m/c/5d79c1b6c6c19574ffe28255? 1
Mr Punter Posted December 11, 2019 Posted December 11, 2019 I have LED strips and they run off a rechargeable Makita 18V battery stepped down to 12V via a buck converter. Lovely and bright. 1
CC45 Posted December 11, 2019 Author Posted December 11, 2019 I was just looking for something to shire a small pool of light onto the switch... @Mr Punter that looks very tidy - something to aim for I guess.
Temp Posted December 12, 2019 Posted December 12, 2019 Someone just make a switch with a neon built in?
Temp Posted December 12, 2019 Posted December 12, 2019 Yes of course they do. Perhaps rewire one of these so the neon is always on.... https://www.google.com/search?q=light+switch+with+neon+indicator&oq=light+switch+with+neon&aqs=chrome.1.69i57j0l3.10671j0j8&client=tablet-android-pega&sourceid=chrome-mobile&ie=UTF-8#scso=_lIzxXa7wDsif1fAP0vqCgAc64:0.5.5.5&sbfbu=0&pi=light switch with neon indicator
JFDIY Posted December 12, 2019 Posted December 12, 2019 (edited) Click Grid do a neon module to put next to your switches in the same faceplate. On my garage that only has access from the outside, I have external pir operated outside lights with a bulkhead light above the internal light switches, so when you approach in the dark the inside is partly illuminated on arrival. Also you can tell from inside when the outside lights have been activated. Edited December 12, 2019 by JFDIY
Onoff Posted December 12, 2019 Posted December 12, 2019 11 hours ago, CC45 said: I was just looking for something to shire a small pool of light onto the switch... Put some luminous tape on or around the switch. https://www.ebay.co.uk/itm/Self-Adhesive-Light-Tape-3M-Luminous-Safety-Warning-Stickers-Warning-Stickers/293132451757?
Markblox Posted December 12, 2019 Posted December 12, 2019 MK do a waterproof sw that has a neon. It can be wire to be always on.
dpmiller Posted December 12, 2019 Posted December 12, 2019 https://cpc.farnell.com/crabtree/7009/seeklight-each/dp/PL11861?mckv=siCEoANsv_dc|pcrid|224681503328|kword||match||plid||slid||product|PL11861|pgrid|47203068935|ptaid|pla-823944588639|&CMP=KNC-GUK-CPC-SHOPPING&gclid=EAIaIQobChMImu6t4L6w5gIVjbTtCh1n3QJ2EAQYBCABEgJ6O_D_BwE 1
AliG Posted December 12, 2019 Posted December 12, 2019 Instead of putting a switch on the door why don't you just wire a PIR between the lights and the switch, leave the switch on and the lights will go off and on automatically when you go into the garage.
CC45 Posted December 12, 2019 Author Posted December 12, 2019 21 hours ago, Temp said: Yes of course they do. Perhaps rewire one of these so the neon is always on.... https://www.google.com/search?q=light+switch+with+neon+indicator&oq=light+switch+with+neon&aqs=chrome.1.69i57j0l3.10671j0j8&client=tablet-android-pega&sourceid=chrome-mobile&ie=UTF-8#scso=_lIzxXa7wDsif1fAP0vqCgAc64:0.5.5.5&sbfbu=0&pi=light switch with neon indicator this looks like the ticket to me. good work @Temp
