Fixing Sole Plate to Concrete Blockwork Foundation
Drew1000
1 hour ago, Drew1000 said:
Hi
Looking for some advice on best bolts/screws/anchors to fix sole plate to blockwork.  What is the industry standard used these days.  Thanks in advance of any advice
Regards
Is this for a DIY build or are you writing a spec ..? I would let the TF contractor decide otherwise.
MBC used something like these https://www.orbitalfasteners.co.uk/products/8mm-x-110-express-anchor-steel-zinc-plated  as you just need to hold the timber against the concrete, drill through both and hammer this home - there is no additional fixing and the timber goes where it is supposed to - quite quick way of working.
They're pretty sturdy as I saw when one needed to be removed - did not come out of the concrete.
  • Like 2
28 minutes ago, Drew1000 said:
Forgot to ask what the recommended distance between fixes was, assume 600mm
We just went every 600-1000mm, straightening as you go.  Just have someone at the end looking down the length.
  • 9 months later...
Expanding sleeve anchors as long as you are not getting close to the edge of the blocks, otherwise chemical anchors (threaded rod set into resin) as these bond tightly to the concrete without causing spalling or cracking etc.
