1 minute ago, Ferdinand said:
Aren’t you supposed to be on holiday in Lubricious, with your Truss left at home?
Resting around the pool ‘thinking’ before my Tai Chi session ( yang style apparently) . Tbh a day never goes by ( even on holiday ) without me thinking about the build ...
7 minutes ago, pocster said:
I can’t do heights
But you can manage 30,000 feet as long as it's in First Class?
5 minutes ago, pocster said:
I read it was best to avoid the roof due to the associated cost and hassle ( I can’t do heights ) !
Is there a maximum length the air intake/out can be ? Or is it simply as short as possible???
I could pull two tiles and put these vents in quicker than you could get the core drill out to do the first hole....
If the intake / exhaust are going to be more than 1-2m then they need to be properly insulated.
Oh I don’t suspect it’s a problem for a skilled man like you . But erm , heights - on a roof ?????????
If I attempted it would result in a post topic titled “I fell off my roof “
On 02/07/2019 at 13:15, pocster said:
Not 1 truss the same distance apart .
You may want to consider cross battening under the trusses with 25 x 50 or 38 x 50 at 400 ctrs for your plasterboard and your electrics.
Should've bought a secondhand scaffold tower...
/gloat
Edited by Ferdinand
He'll buy a new one.
8 minutes ago, Ferdinand said:
Can't he make a glass one?
Like Versailles Hall of Mirrors but flat and not mirrors?
Nah, he'll see right through that idea.
/gloat
Or a good run of Kwikstage
The trusses as they are shouldn’t have plasterboard screwed to them ???
So can the mvhr vents go thru roof tiles? Do they have to be on sane elevation to prevent being unbalanced like Jeremy said his can be
Yes they can, and yes they need to be on the same side.
And did I read right in that the shorter these intake/extract intake pipes the less need for lagging/insulating? Note @pocster has a warm roof type setup but i'm asking for future reference
Yep I do have a warm roof so I am hoping length of in/out pipes is less critical.
Oops - I’ve accidentally attached something! ?
Nope - insulate them properly all times as it’s about condensation risk. Also worth tilting them down slightly toward the outside so they self drain.
Is it correct that this is to do with condensation on the outside of the ducts, not the inside. as in winter the runs to and from the external terminals will be cooler than the indoor temperature?
Yes.  The problem is that the humidity inside the house may well be higher than that outside, so the cold duct may attract condensation on the outside surface.
Right !
Have decided mvhr vents will be through the roof - much simpler as i’ll Get someone else to do it ?
Still can’t work out how to board this and have good access to mvhr unit and header tank . Assume placing the tank specifically over the wall stud as it gets more support . Guess I just go for it and see what happens .
Got a couple of nice Timloc vents that have the
required flow rate that I can let you have for a reasonable price ... ?
Thanks but my vents have been ordered with the mvhr and kit.
