ToughButterCup Posted June 25, 2019 Posted June 25, 2019 'Fit a digital electric shower my boy, and the world will be yours...' Has He got a point?
MikeSharp01 Posted June 25, 2019 Posted June 25, 2019 Not sure what the point of Satan is - what do you get that you don't get with a more traditional sounding 'thermostatic' shower unit other than being a bit poorer. 1
ToughButterCup Posted June 25, 2019 Author Posted June 25, 2019 Being dry while you switch on and set the temperature....
ProDave Posted June 25, 2019 Posted June 25, 2019 ...... And there is more to go wrong. If you must go electric I would always go Triton for value for money and reliability. But No 1 choice would not be electric, but decent thermostatic mixer from decent WW tank.
Onoff Posted June 25, 2019 Posted June 25, 2019 12 minutes ago, AnonymousBosch said: Being dry while you switch on and set the temperature.... Just put the mixer to one side. 1
ProDave Posted June 25, 2019 Posted June 25, 2019 15 minutes ago, Onoff said: Just put the mixer to one side. Simple. 1
Onoff Posted June 25, 2019 Posted June 25, 2019 Everyone loves the controls to one side here. Same as @ProDave's:
Pete Posted June 25, 2019 Posted June 25, 2019 34 minutes ago, ProDave said: Simple. Is that a rail on one side and overhead/diverted on the other?
ProDave Posted June 25, 2019 Posted June 25, 2019 2 minutes ago, Pete said: Is that a rail on one side and overhead/diverted on the other? Yes, middle knob is temperature. Top knob is flow to the overhead rainfall shower head, bottom knob is flow to the shower head on the riser rail. You can have both together if you want.
Onoff Posted June 25, 2019 Posted June 25, 2019 Hudson Reed mixer valve (as per mine / Dave's) in action, short video. Mine's off a shower pump btw:
Ferdinand Posted June 26, 2019 Posted June 26, 2019 Remember Bathstore 60-80% off currently. https://www.bathstore.com/products/bathstore-sale/massive-stock-clearance And if you are shopping for showers, there are two more of those soak.com liquidation auctions happening. First starts closing at about lunchtime. https://www.bidspotter.co.uk/en-gb/auction-catalogues/timed/william-george-auctions/catalogue-id-wi412604?searchTerm=mixer+valve&whereToSearch=%2Fen-gb%2Fauction-catalogues%2Ftimed%2Fwilliam-george-auctions%2Fcatalogue-id-wi412604 https://www.bidspotter.co.uk/en-gb/auction-catalogues/timed/william-george-auctions/catalogue-id-wi412605?searchTerm=mixer&whereToSearch=%2Fen-gb%2Fauction-catalogues%2Ftimed%2Fwilliam-george-auctions%2Fcatalogue-id-wi412605
ToughButterCup Posted June 26, 2019 Author Posted June 26, 2019 10 hours ago, ProDave said: ...... And there is more to go wrong. [...] Depends on your perspective. And budget. An electric shower is cheaper and simpler overall. And as for 10 hours ago, MikeSharp01 said: Not sure what the point of Satan is [...] @Nickfromwales with customary understatement, referred to electric showers as ' ... spawn of the Devil ...'
Onoff Posted June 26, 2019 Posted June 26, 2019 Why mix water and lots of amps if you can avoid it? A simple bar mixer is the simplest and easiest to maintain / replace if it goes wrong as everything is external to the tiles. With my concealed mixer type first I've to prise off the back plate that has a horseshoe bead of silicone between the back and the tiles. That done I have access to the cartridges etc with box spanners inc a 46mm one (meant for a Landrover I think). If however any of the x4 15mm compression joints, 8 if you include the male 1/2" BSP into the mixer body should ever leak, then its smash a tile out time!
ragg987 Posted June 26, 2019 Posted June 26, 2019 I fitted one in our old house. It had 3 pre-programmed settings for temp and flow, so I set it cooler and slower and wife very hot and full power. You can also preset the max allowed flow and temperature. Beeps when warm water flows after switch on. Maintains set temperature very well. Loved it until the day it died, just outside the warranty.
