Depends how you have insulated it. A skirt would keep them warm, assuming no side draughts. /metaphor If you have cross flow then you probably have to suck it up. Gable walls into the attic may lose more heat by conduction, as the ground is warm.
Slander ! Libel ! It was only last week that I bought an 18mm sheet of MDF at B&Q for £19.50 (reduced to £19.36 by B&Q Trade Discount). (*) The nice man on the saw cut it into 11 slices of 3, 4 or 5 inches for me, to make radiator shelves (to prevent Tenants drying washing on radiators) and door liners. F * I shall treat myself to one two-finger KitKat with that.
A quick EPC question to which I cannot find an answer. What would be an EPC value for a typical "building regs minimum" newbuild property? I did however find numbers for how EPC values have changed over the last 20 years. Right direction, more still to do. Source: https://www.gov.uk/government/uploads/system/uploads/attachment_data/file/627688/Potential_stock_improvements_Report_2015-16.pdf
Can we go all Georgian, and tax bifold doors?
I ran across this post from @SimonH from 2008 over on GBF this morning: http://www.greenbuildingforum.co.uk/newforum/comments.php?DiscussionID=994 What are the big factors and impacts now? The context is that my Little Brown Bungalow renovation for rental of a 1966 3-bed semi bungalow will be given an EPC value of about 76 in the C band. I have done everything to a good standard, including underfloor insulation of 100mm rockwool + 25mm PIR, but not EWI (so walls are still filled cavity ~= 0.55 U-value) and 2G not 3G. The tenants energy bills are likely to be under £500 per year. But I see from Stroma that adding relatively little PV solar would bring it up to a B or even an A, which is a little bizarre. Ferdinand
Retired Feminist Roofer: too delicious
Ferdinand replied to ToughButterCup's topic in Roofing, Tiling & Slating
(Keeps quiet about the subtle double-entendre). -
Highish for a developer house ie better than average eg ufh, an ensuite, and all double bedrooms in the 4 bed. I need to get the gumf as it is quite close. The detailed planing ref, including specs etc, is here: https://www2.ashfield.gov.uk/cfusion/Planning/plan_view_docs.cfm?reference=V/2017/0534 There is an earlier Outline. The site backs onto allotments and has a few mature trees, so it will be pleasant. Given that *this* is the site as of 9am this morning, there is scope for negotiating changes: F
What about a rotating one on the roof (or at a low level) as part of a weathercock for new Builds? Could have a modern version of the Sisyphus myth with @Onoff making his bathroom in cut-out sheeting .
New cul-de-sac development near me with highish spec finish, including .. wood burning stoves. http://www.broadleafclose.co.uk/
The technique is to talk to the EST helpline, and ask for your local organisation involved. 0300 123 1234 There may be some wrinkles around new build vs conversion, occupation etc. You need to check. For rentals iirc I have to have a tenant in situ before I can get it done, but once you ask them it is an inspection then install within a few days. They work quickly, so if eg you have gables that are walled off that you want insulating then make them accessible before the survey. When I had the Little Red House I just mentioned on the other thread done, they were in and out within 20 minutes. I last had one of these at this time in 2016. Given that your building is idiosyncratic, I am not sure how it will pan out. If you can update us with your experience that would be great. F
This is mainly for @Crofter, depending on how Wee the new Hoose actually is - put here in case anyone else finds it. In England, detached buildings under 50sqm are exempt from having an EPC done. https://www.gov.uk/energy-performance-certificate-commercial-property/exemptions If it is also so in Scotland, that could save you a little money and hassle - if you are under 50sqm and so minded. I have one under 50sqm - the detached 48sqm cottage my dad was born in, which is now a rental. I have the EPC number up to 51, and the half of it which has been drylined since about 1984 (25mm eps) was ignored by the EPC man, but that is about the limit of what is achievable practically. When push comes to shove in 2026 I will rely on the exemption rather than make a "too expensive to upgrade it" argument. Ferdinand
Before I did my latest but one we did an Osb pathway / platform to the boiler under the top layer to help gas engineers, and insulated the pipes up there. Also what is your current insulation level? Under 100mm ( or if you reduce it) and you can probably get it done free. Guess where the rockwool under the floor of the LBB came from.
Since when did Tories do "fashion" ?
So quite an effective filter for the outside environment then .
Have not seen that one, but beds with sheds will not get widespread post-approval, unless they are if a decent quality. Plenty of regs can be used to close them down, and the issue is too high profile to fiddle imo. There would be hell to pay. He did promise to plant 2 million trees in London, but that seems to have evaporated.
Credit Unions
Ferdinand replied to ToughButterCup's topic in P2P lending, Crowd Funding and Alternate Sources
Edited. -
Credit Unions
Here is the Association of British Credit Unions Ltd (ABCUL) "How to set up a CU" page: http://www.abcul.org/credit-unions/setting-up-a-credit-union -
Credit Unions
I am a member of our Nottingham CU, which operates County-wide. When I sold my big building site one of the things I tucked away in my head was to at some point in the next decade try and create a local initiative for this CU, since at present we are a town of 50k people with no local offline Credit Union facilities, and I know that Provident Financial have something like half a dozen full and part time doorstep lending reps in the town, each with hundreds of clients. The demand is driven by "I need money this afternoon" type needs. One interesting thing about CUs is that they can lend perhaps 20-25x the amount of capital they have received, if it is the right sort of capital (basically: unencumbered capital which is not removable savings). The ABCuL CU trade body is very good to talk to. One of the things I was exploring was to make a capital loan of a smallish (compared to the money we spend on building houses) amount to the County-wide Credit Union, and help them provide facilities via a local community organisation leveraging off that capital. But another is that the trend for the last 15-20(?) years is to CUs offering bank-like services, and consolidating. That was driven That suggests that a small, niche CU may be against the trend (why?). OTOH it may be that a tiny CU with a very focused common bond and specifically offering only simple services (eg not online current accounts) to keep the operation lean could be a good complementary new trend. Another way could be to find an existing CU with a broad Common Bond that we could all join (eg if there were one for Co-op members - unfortunately there isn't), and create a Special Interest Group. I do not see us really wanting to provide large amounts of organisation infrastructure as overheads would be too great, which is why I have been jabbering about piggybacking on other people, or using a very lean organisation. Just my musings. Further musing: could we work with Ecology BS? Ferdinand -
If you missed it, @Grosey used them to finance his build. One thing that could make Folk2Folk suitable for a "Pilot" is that they can - I *think* - take ISA transfers in. From the investor side even though unregulated it is quite well protected because they secure on a property at a less than 50% exposure ratio. It also mitigates one aspect of the F2F model, because I think your money sits on its bottom doing nothing until a loan request comes in. OTOH, getting into a newbuild a year or more earlier could save 10s of £k where the loan costs could be <£5k. But for many people there are cheaper options available than Folk2Folk, such as mortgages or zero interest cards or maybe even the best personal loans (eg banks currently down to ~3.0%). At F2F you will be paying around 6% plus fees, so the flexibility has to be worth it. But that is also less than half the interest rate of bridging finance, and you get more flexibility. I wonder if there would be scope to ask for a slightly lower rate of interest, if both sides requested it.
Never found anything in Milton Keynes for the blasted trees. Except when I revisited the Futurehome 2000 estate, which I went to first time round with dad.
I think that depends what you are funding. If it is the funding of an entire build, then it would be much more than 100k. If it was setting up a Credit Union, then it would be much more and take several years with regulatory hoops. But that is perhaps a different fish-kettle to helping people who have hit a financial brick wall or quagmire half-way through a build, where the numbers might be "25k to get us in to save 2 years more rent or caravan freezing". One other option (losing track of threads here) would be to ask Folk2Folk to do a la carte deals case by case - we know that they lend for self-build. Say "We have *this* project, and *these* investors" - will you do the admin via your normal processes for your normal fees at X rate of interest?". One advantage is that they are structured to let the investors have it in an ISA wrapper. One disadvantage is that they start with investments of 20k+. But perhaps we need to try different mechanisms in the early stages, and may actually be a catalyst for other people to widen the range of market options for different circumstances. If we create things we do not end up running, that is surely a good thing and a win-win?
