ETC
Everything posted by ETC
Eaves flashing gutter of Insulated box section panels
ETC replied to BotusBuild's topic in Roofing, Tiling & Slating
- 9 replies
- eaves flashing
- gutter
Have you asked the roof panel manufacturer?- 9 replies
- eaves flashing
- gutter
Do you have BC Plan Approval? What is complicated about B5 compliance?
https://www.buildingcontrol-ni.com/assets/pdf/TechnicalBookletD2012.pdf
I’ll pass your comments onto the author.
SE refuses to spec beam with underplate
ETC replied to flanagaj's topic in RSJs, Lintels & Steelwork
I’d say it doesn’t cross their minds to put a grid on. -
Why are you insulating the garage walls? Is it heated?
I think there are bigger thermal bridges than the steel post……just saying!
Post your SAP so we can take a look. I’m very surprised that a timber frame is failing the SAP. I would also assume that the junction calculations are taken from standard details rather than specific construction drawings.
I am quite happy to do a design for you…..please let me know if I can help…..
All well thanks…..SSDD……
Need ICs at changes in direction Gus……
Who in their right mind designs structural support over a drain?🙈……the extension isn’t really worth doing!
I would have done a design for free!
Why start now!
Just send in your SAP.
The condensate collection pipe should be insulated inside and outside the unheated space and should terminate to a suitable foul drain - not a rainwater downpipe. Failing this it can be connected to a limestone filled sump > 1.0m from the foundations. If the boiler is inside an attached garage/space a CO detector/alarm should be fitted. Also you may need to have a Building Control Application made for the works.
Advice please re fire rated mineral wool cavity closure. We will be having part timber clad and part render on our MBC timber frame airtight house. Do we need different types of cavity closure according to surface. No. ADB lists the types of cavity barriers to can use - and as long as they close the cavity they should be fine. Normally 38mmx38mm timber to the perimeter of windows and doors or bagged mineral wool by Rockwool. What about ventilation? The cavity needs to be ventilated (and drained). Where a cavity closer bridges the cavity vents and a drain should be provided.
Don’t forget that the Regulations only require “reasonable access”. Well compacted hardcore and blinding is in my opinion “reasonable access” and as long as a wheelchair user can get to your Principal Entrance this should be acceptable.
Cavity Block wall abutment to solid stone wall question
ETC replied to RobertG's topic in House Extensions & Conservatories
DPC is in the wrong place! -
Your footprint is the same as two adjacent houses.
