Tom
Everything posted by Tom
  1. They said it was up to my plumber (ie me) to connect up the condensate drain. The problem is they are a commercial ventilation installers rather than domestic, if that makes a difference, so perhaps they see their remit slightly differently
  2. There are no boost switches, just the internal humidity sensor and the manual overide on the front of the unit
  3. Yes, I agree. Strange that I can't seem to turn the boost off though
  4. It's hung off a blockwork wall, all very solid and no vibration
  5. Right, I've investigated further. I've actually had it running with the condensate drain not attached to anything, just draining in to a bowl. There seems to be lots of air being sucked up the short length of corrugated pipe, and this seems to be causing the gurgling. If I put my finger over the end and then take it off, some water drains out. I did this a couple of times until no more came out and the gurgling stopped. It seems that the constant flow of air up the drain pipe was preventing water from draining effectively. Is it normal for air to be sucked into the condensate pipe? I guess when I plumb the thing in, a ubend/trap would stop the air flow and the water would drain more freely? Anyway, I've switched the thing off for the night as there is clearly a problem.
  6. Yes No. Its quite a short run and I could easily wrap it in mineral wool though. Another complication is that the unit is currently running at boost and I can't seem to turn it down to normal flow. It seems to be gurgling inside so I wonder if there's some trapped condensation in there tripping the humidity sensor. What's your opinion on the plenums? I'm assuming they shouldn't be making a noise?
  7. We moved in three days ago and so fired up the MVHR unit (ventaxia sentinel kinetic high flow). It's recently been commissioned, air flow set at 30% with 9l/sec at the terminals. When I finally sat down in the sitting room at the end of the day and things were quiet I became aware of a background noise, hard to describe, with another noise like a running stream, which eventually I realised was coming from the supply vent. This noise seems to have got louder - or perhaps I'm just more aware of it. I had a fiddle with the flow controls on the ductwork, and when I open fully the one for the living area the noise reduces. I did notice also that the plenums were very noisy themselves, there was an air leak detectable from the supply plenum and both sounded like a running stream inside. It seems this noise is being transmitted to the terminals - which in my mind seems counterintuitive for a plenum. Attached is a picture of one of them. It does seem small for all the ductwork going in to it, so I can imagine the airspeed must be high with lots of turbulence. I paid a lot of money for this install but I have yet to pay the final invoice. Am I being too picky - or is this all to be expected?
  8. Thanks all, sorry for the delay in replying with thanks, been absolutely taters deep in moving stuff. The ecodan has been on just about non-stop for the last 36hrs and the place seems to be coming up to temp. The flow to the ufh still only reads as 25° on the manifolds even with the compensation disabled and set at 45°. I presume the temp is reduced as the recirculating pumps are mixing the cool return with the flow? Anyway, we're in, and the place is warmer than a caravan, so it's a definite improvement. After 4 years it's taking a bit of getting used to though! First night I was a bit like Crocodile Dundee in his hotel room
  9. Yep, I know, but as its currently set up I need at least one to call for heat. No buffer. Two 12 port manifolds, one thermostatic mixer on each fully open. 8.5kW ASHP 300l uvc, low loss header. Though tbh, irrespective of what the plumbing is downstream of the ashp, it's just not producing very how water - the pipe coming from it is barely warm. Yep.
  10. Hi all, believe it or not we might actually be moving in tomorrow, so today I fired up the ecodan but struggling to get much heat out of it. For a start, the Wunda thermostats seem to randomly stop calling for heat and reset themselves to 10c, but I'm also struggling with the ecodan controller. It all seems.to switch on fine and the ASHP runs but the flow water temp to the manifolds hovers at around 15°. I've taken some pictures of the controller, any ideas?
  11. Thanks Joth. I did raise a concern at the start of the install re putting the data and AC wires in the same trunking, but it seems they weren't too concerned. Not that I found that very reassuring! Is there a way of assessing interference with the CAT6a before I make the final payment?
  12. I only charred the one side, though I stained the edges with a black wood stain
  13. We went with charred timber for some of our cladding and love it. I charred it myself and after a bit of trial and error got a pretty good system going. Happy to share if anyone wants to do similar
  14. Sounds interesting, was that a Part Q conversion? Our build was a Part Q then full planning, and has had PD rights removed. Will be interested to see if this can be reversed.
  15. We put half our UFH in the concrete slab and tbh this was far less of a pain to do than the other half we decided to lay on top of the slab and screed over. Our slab was 200mm and had two layers of rebar mesh (actually four, two at the bottom of the slab and two at the top), I tied the UFH pipes to the bottom layers of mesh then put the top rebar layers on, separated by rebar deckchairs. I did this all myself so could make absolutely sure no pipes were damaged. Seems to have worked well.
  16. We've been in our static for 3.5 years now (fml) and the only heating we have is a wood burner which I let die down in late evening. Call my crazy, but why do you need heat overnight if you're in bed? Buy another duvet!
  17. Oooh, my bad. Would be tight I guess with one year already gone and you'd have to gamble that the Part Q goalposts haven't moved if you need to renew
  18. Hi - the seller's structural reports isn't worth the paper it's written on - this would have been produced simply to get the thing through the planning process. If you are serious about the project then you will have to spend a bit of money and get your own structural report which will give you a less biased idea about feasibility. Also, don't underestimate the costs of getting services to site - depending on how close the nearest electricity supply is this can be tend of thousands - do some research now. Armed with both of the above, this could give you some leverage to negotiate price with the seller. Finally, what are the chances of getting full planning permission? Would likely make everything simpler/cheaper. Have a look on your local planning portal to see if other Part Qs in the area have been granted full planning. Seems to vary by region. In answer to your questions: 1. Waaay too many variables. Re 3 years, as long as you've started then it's fine. 2. Waaaaay too many variables! 3. See above and... read this site, visit others in the area doing Class Q conversions, find a friendly builder?
  19. Yep. They're semi-recessed. There are access panels though (photo above taken through one of them). Just spoken to him and he says access is just too tight - but concedes could be done if given enough time, but doesn't sound like he's willing to change them.
  20. Certainly didn't agree that he wouldn't use flexi pipes, but then again you'd assume that any decent plumber would use materials suitable to the job. Access is a bit tight but with a bit of time and effort I'm sure he could fit a proper waste. Agree re the push-fit elbows too. FFS, as ever two steps forwards, one step back.
  21. Our plumber has just about finished now, and was today making the final connections to taps, sink etc. I've just been round to have a look and am disappointed to see he's used flexible connectors for the wastes in the en suite and bathroom. Am I right to think this is a bodge?
  22. I thought it was an Austin Allegro, lol
  23. Crikey, any one on here still think the earth is flat? Peace out @joe90 and @JohnMo, weather's too good to be stuck inside: I'm going to bend some coat hangers and give this a go
