Tetrarch
    2
Everything posted by Tetrarch
  1. OK - now I'm confused... I've never heard the word "dwang" before so I went a-checking https://en.wikipedia.org/wiki/Dwang Here it's referred to as a "nogging" - I've always thought (and the above posts would tend to corroborate) that it is a noggin. Anyone come across this before or does Wiki need a correction? Regards Tet
  2. Vote for Rubber for me I self-installed an L-shaped flat roof 20 years ago on my previous house (still going strong). Recently, I've installed rubber onto two outside buildings It's cheap, completely waterproof and easy to install, my only real criticism is that the flashing and finishing accessories are expensive. Regards Tet
  3. I can see that my previous comment might easily be misinterpreted. Following your comments I will now be using glued 22mm chipboard with PW under the shower tray, cut to exact dimensions and appropriately noggined Thanks and regards Tet
  4. Thank you both for your comments. I had assumed that becuase ply seemed to almost a requirement for the shower tray that it would be a superior product for the remainder of the floor. Is any filling required or even recommended for the joints prior to LVT or are they good enough as are? (You can tell that the previous experience really burns - 20 years of looking at an unremediable DIY mistake in a premium product) Regards Tet
  5. I laid an Amtico floor about 20 years ago and whilst I was quite pleased with the outcome I did have a visible line across the bathroom where the plywood sheets were butt-joined I'm in a new house with a new bathroom planned, and whilst I now consider Amtico overpriced I'm looking to lay LVT again, but definitely with a T&G sub-floor of some sort. My thoughts are that 22mm T&G ply would be the bees-knees in terms of spec for the floor . The hierarchy is probably: A. 22mm T&G plywood B. 18mm T&G plywood? C. 22mm T&G chipboard? D. 18mm T&G chipboard Does anyone have any experience or recommendations that they would care to share? Regards Tet
  6. IMO it is a valid complaint. I had the same from an old neighbour when I renovated a kitchen. I re-routed the vent via a rigid channel within the cavity wall and had the vent exit at the rear of the house, effectively adjacent to the boundary Regards Tet
  7. Thank you for the replies. I chose the 15kw Biowin to replace a 1950's oil boiler in an area that is nor connected to the mains gas grid. We live in a rural setting and so I am sanguine about our contribution to pollution from our boiler, and indeed our wood burner. My intention is to go for a 300L Megaflo and run the boiler every other day. First things first will be fitting a water softener..... Regards Tet
  8. I had a Winhager BioWin pellet boiler installed in December 21. At the time, pending a planning appeal we had it connected only to the upstairs rads and the UFH that has been installed so far. I am using an immersion heater for hot water and a basic 8.5kw electric shower. The heating is plumbed ready for HW delivery but it is not yet connected. The planning appeal is dragging on interminably so I'm now looking at potemtially another Autumn/Winter under these conditions. Knowing that the run cycle for the pellet boiler is fairly long I was thinking that a larger HW store with the HW run every other day would be more efficient than a small store/daily run when the heating is off during the summee. The question is how do I optimally size a megaflo (or similar - open to recommendations) to accommodate this kind of arrangement? Our household is just two persons so just a couple of showers and hot water for washing and washing up. Regards Tet
  9. We have a pellet boiler for heat but I like the EV-as-a-battery idea. Regards Tet
  10. Thanks guys - I am convinced. With energy proces going only one way and EV's an inevitibility, now is probably the right time to consider solar. Next consideration is yes/no on storage and to wait for planning permission so I can know how big my South-facing roof will actually be... Regards Tet
  11. I'm definitely having a new slate roof installed over the next year or so. I'm also considering getting a solar array, but am not sure about the economics Is there any way to pre-fit a roof for a solar array at the time or is this one thing that sits between trades? What would the likely sunk cost of this kind of approach? Any advice, suggestions welcome Regards Tet
  12. House is a 1914-built detached that is (PP pending) going to be extended and refurbed, including a complete external re-rendering and intternal re-plastering. The plan is to have UFH downstairs and rads upstairs fed mainly from an ASHP. Also, considering an MVHR to provide superior ventilation in a more sealed house The insulation is going to be substantially upgraded. From here https://www.thegreenage.co.uk/thickness-solid-wall-insulation-u-values-can-achieve/ it states a requirement to add 67mm of PIR to a solid wall to achieve a u-value of 0.3 My current thoughts are to add 25mm internal insulation using insulated plasterboard and 50mm outside on the old solid walls under a new render.This will avoid creating too much depth on the reveals but will improve the u-values to the right levels Any reason why this solution won't work? Regards Tet
  13. Absoltely none. May I pop back to my original question. The Jablite (no particular reason for choosing this brand, are others better/cheaper?) comes in standard thicknesses up to 200mm. Listening to the previous comments; to accomodate any unevenness I was thinking of getting a 50mm layer to get a proper level and then laying the 200mm on top - does that seem a sensible plan? Do I need to tape the 50mm layer or just lay the 200mm at an offset and then tape that Finally, the Jablite 70 would seem to suffice - is there any tangible benefit from upping the spec to the Jablite 100? Regards Tet
  14. Concrete subfloor is staying, electrical cables and microbore radiator pipework is most definitely going Regards Tet
  15. Hi guys, Thank you for the responses. Floor is hundred year old concrete. It is a bit weird as it is light in colour the stones are larger than I would have thought is normal now, but it appears extremely solid. I attach a couple of pictures. I am a DIY'er and the 70mm value is from my (likely) builder. His recommendation was to remove and use hardcore under a slimmer layer of PIR, but I went the whole hog and removed everything. Just to re-terate the measurements I have a tiled fireplace with a 100mm upstand. It is 300mm to the bottom of the vertical tiles so I was working on 250mm insulation + 70mm UFH screed + 20mm Flooring to bring the final floor level about half way up the tiles Edit: UFH is for long and low as this is not for a working family, but newly retired Regards Tet PS - look closely and you'll see that the double socket by the floor is actually connected by a bakelite junction box and a cooker switch plate - bodes well!
  16. Hi, I have now removed floorboards and joists in the lounge and have a hole to fill (actually 2 when the dining room is completed). I am looking at a 20mm Eng Wood Floor on top of a 70mm UFH slab and thus have ~30 sq m of 250mm depth to insulate. What is the most economical and effective way to fill this 250mm? After a little research I believe I have three alternatives. A bespoke 250mm Jabfloor EPS (or similar) Layers of off-the-shelf Jabfloor EPS to reach the 250mm A Jabfloor layer topped with a Celotex (or similar) overlay I'm looking for any advice/experience or alternative recommendations Regards Tet PS: Below is a floor schematic where the green is floorboards, the yellow (uninsulated) concrete (to be dug up and replaced) and the orange is the proposed new extension
  17. The 1917 house refurb has a decision point and I am receiving conflicting advice. The new extension (25% of footprint) will of course be insulated. The 1990 (old) extension (35% of footprint) is completely lacking any floor insulation and so I am happy to have it dug up and relaid simultaneously with the new extension. So far, so simple. My builder has advised that I could/should remove the suspended floor (40% of footprint) and infill with hardcore, concrete and insulation to create a floor like the rest. The other option, is to insulate between the floorboards and either use spreader plates to drop the UFH pipes below the joists or (height-dependent) put floor trays with a screed (liquid FL if that saves some height) on top. Is there a huge difference in efficiency between my builder's recommendation and the latter idea? One advantage is that I can do all the insulation myself as a job before he even starts on site Regards Tet
  18. Mrs Tet will not countenance anything else but carpet and rads upstairs Regards Tet
  19. How do I find a "system designer" ? Regards Tet
  20. Thanks for the reply George. I didn't know about the reduced RHI payments. I will certainly have to take that into account. I was thinking a Megaflo for the HWC and these are super insulated. If the HWC is not an issue, then another major issue is the size of radiators needed upstairs. From the research I've done thus far it seems that I would need rads almost double the size of normal and that would compromise some of the plans that I had in mind. Regards Tet
  21. I'm in the early stages of the refurb of a 1917 property in Kent. The rough downstairs floorplan is below - The floor is a real hotchpotch of suspended floor (45% - Green), Previous extension concrete floor ( 35% - Yellow) and New proposed extension (Orange 20%). The current EPC is a horrible 23 and we're looking at using a combination of internal and external insulation to improve this. This may be an opportunity to seal the house (replacing floorboards?) Trying to bring all the potentially different technologies and solutions together is a challenge and every choice seems to lead to a particular specialist supplier that may have a particular axe to grind/product to sell. There is a wealth of knowledge and experience on this forum that I am very glad that I have found. Regards Tet
  22. I was only going by the 25-50 dB estimates. Not a lot of noise, but not none. We currently have a hot tub that is about that volume, so we are aware of how it may irritate neighbours, especially in the countryside where our new house is located. We do have an oil boiler but that will need replacing in fairly short order with something. The RHI would make an ASHP a no-brainer, especially for downstairs UFH, but we'd like to keep upstairs rads small and hot water more "on tap" - therefore an oil-combi would seem to be the most cost-effective solution on a 20-year payback basis. We arre absolutely not wedded to this and would welcome any feedback Regards Tet
  23. I'm looking at a multi-source approach to heating combining Oil and an ASHP. Downstairs will be ~90 sq m and currently the plan is for an engineered oak floor. There will be more questions regarding insulation in the future, but the current consideration is a siting one. The new extension will require resiting and replacing the current oil tank. I am very tempted to locate my new (yet to be chosen) ASHP away from the house for noise mitigation reasons. I understand that there will be a cost/efficiency from an insulated pipe run,, but is there a reason NOT to locate the ASHP on the same (new) concrete slab as the new oil tank and hidden by some screening (open to the back)? Regards Tet
  24. I'm looking for some advice on where to locate the join in a (quartz or granite) worktop. There is also a large island going in so this is not the only worktop The run is for a 4.2m worktop with a cutout for a 800mm sink in the centre. Therefore the choices are for a single join in the middle of the sink or three separate pieces with two joins. The glass splashback we're going to have will have two joins (1 x 1600m, 1 x 1000mm, 1 x 1600mm ), so lining up with these is an option, but this would add some risk with ensuring that the alignment is spot on. The other option is to have two joins elsewhere ( 3 x 1400mm?) The sink we're looking at is mounted and supported underneath so there are no particular structural integrity issues, just the asethetics. Any advice or experiences most welcome Regards Tet
