Tetrarch
Everything posted by Tetrarch
Second shower install into power shower system
Tetrarch replied to Square Feet's topic in General Plumbing
You could fit a digital shower, but that would be >£500 Regards Tet -
Insisting on MVHR is a big and expensive "requirement". I chose (and would heartily recommend) MVHR but as a planning stipulation it seems excessive - same with TWO EV chargers Regards Tet
Is it worth approaching your planning department as, with your new solar panels, it will be most certainly NOT like-for-like. Given that all local councils like to big-up their green credentials then an amendment/new planning application might allow you to consider other, less expensive, material choices Regards Tet
or EPDM instead of GRP... My solar is done like this Regards Tet
To put things in context From the calculator on https://solarenergyconcepts.co.uk/post/panels-tilt/ for a notional 10kw system If optimal 36 deg for South East gives 1,026 kwh Then 15 deg gives 963 kwh and zero deg gives 940kwh My understanding (from a previous insurance question) is that flat is defined as anything less than 15-deg Regards Tet
You haven't said what your floor surfaces are upstairs. If you go for the surface-mounted spigots then you will have to consider how to "end" your surface covering, whether carpet or boarding etc right above your glulam. I went for a surface-mounted option per JohnMo's suggestion and I can heartily recommed FH Brundle and their product offering (pics below) - the pricing was incredibly keen Link here: https://www.fhbrundle.co.uk/products/18SB19B__Includes_19mm_Glass?campaign=506233955&content=&keyword=&hsa_acc=1133268878&hsa_cam=506233955&hsa_grp=1271037173114202&hsa_ad=&hsa_src=s&hsa_tgt=pla-4583039411608752&hsa_kw=&hsa_mt=e&hsa_net=adwords&hsa_ver=3&msclkid=ec2a85bb0fc1131b4c0fefd760f900b2 Regards Tet
My Amtico fitter was outstanding. It is all he does and he is so good that he limits his quote area When he installed our >100sq m he trimmed every single plank on two sides at a 45 degree angle to stop the "glue squidge" problem. This was absolute genius and I cannot fault the quality of the install. I had some very fixed ideas about how I wanted it laid but all his "suggestions" were the exact right ones in hindsight. I have laid Amtico myself in a previous house and I got the "glue squidge" problem and a line where two plywood boards butted together, I was still pleased with my efforts but a proper professional makes a huge difference in quality Regards Tet
Amtico Spacia are the cheaper brand and the planks repeat more often than its more expensive sister-offerings You are also hampered by the laying pattern you have chosen. (IMO) Straight patterns show up repeats and duplicates more obviously. This is one of the reasons we chose a herringone laying pattern for our Amtico Spacia. Over time and especially as you fill your room with rugs and other furniture the repeat highlights will become less noticeable Regards Tet
I have an outbuilding that I'd like to insulate to make it useable as a workshop and to keep my solar batteries warm! I'd also like to reduce the rusting of tools etc stored there The visible sides are all loglap but the rear is a combination of old brickwork and (currently) sterling board I have some Versarend render board left over, enough to completely cover/replace the sterling board. Do I need a vapour layer and where? Regards Tet
We had a completely free choice as left/right wasn't a consideration. We tried 1200mm and felt it was a little too large. In the end the aesthetic and practical choice was to align the worktop in order to have both corridors the same. In practice this has worked extremely well As a comparison I attach the same picture as SuperPaulie's 1200mm example plus the plan view from which we made the decision Regards Tet
More digging: From https://www.planningportal.co.uk/permission/common-projects/paving-your-front-garden/planning-permission When you click through from this bit: you get this:
I have read through this several times and I'm not sure you're right. The legislation is to counter the adverse effects of the addition of PD rights for new drives. The only mention of existing/replacement was this: "Existing driveways Existing drives can also be converted to be permeable or drain to a rain garden. You should ask a builder for advice because the drive may also drain water from the roof." Just to labour the point. I have an existing tarmac (non-porous) drive that empties steeply into the road. At the moment, after my renovations and a massive concrete lorry) there are a couple of bits of open ground (where a lot of the) water drains into. If I repair these (<5m) holes with non-porous material I am OK If I cover my non-porous drive with porous material (i.e. gravel) I am OK, In my personal opinion, and I stand to be corrected, I don't have to create a non-porous drive if one exists already, only new drives/hardstanding areas of >5m are in scope Regards Tet
Not sure if this is helping or hijacking, but what is the definition of "new"? Does this apply to replacing an existing drive? In my example I have a large downhill old tarmack-y drive that I would like to gravel over - Is this a "new" drive? Is the OP's drive "new"? or do all these regulations apply to any driveway maintenance and/or replacement? Regards Tet
Downdraft extractor or over-hob?
Tetrarch replied to Lincolnshire Ian's topic in Kitchen & Household Appliances
I had exactly the same concerns about the duct and have none of the regrets that you do. Why do you wish you HAD ducted it? The only weird thing is the draught from under the island Regards Tet -
Our downdraft has no external ducting. The post-filter exhaust vents through the plinth into the room. We have MVHR that gets rid of the moisture as a whole-house solution but we have a double extract over the island (you can see it above the bottom left corner of the island) Regards Tet -
Lowest profile flat roof ballasted system
Tetrarch replied to Mattg4321's topic in Photovoltaics (PV)
You could fasten the supporting ally structure to the verticals (house and garage walls) to carry the panels. You may need a support in the centre of the garage but this could be a non-fastened foot that justs rests on your flat roof with no penetration My solar panels are only at about 12° . The visual aesthetic was more important to me that the 5% increase in efficiency. Regards Tet -
Sorry to hijack thread, but I would echo the above advice. My MVHR unit is directly fixed to a wooden backboard in the loft. I have noticed that the slight vibration generates a bit of noise as described above In the case that you do NOT have an outside wall - is there any advice for some kind of dampener for the fixing? Regards Tet
When I did my refurb I wanted CCT Led light strips under the kitchen unit run, in each of the three rooflights and also I have two (PIR controlled) inset LED strips in each of the bathroom niches I had different profiles for each of the locations but went for KSR LED CCT strips in each. I had seen them in an electrical supplier and they were very smooth in brightness and colour control. I had them custom-made for length to avoid any unnecessary joins and, of course, ultimately bought six drivers for control The rooflights and under-cabinet are synched such that they are controlled from the same switch Strip: https://gosparky.co.uk/product/ksr-ksr95184-led-strip-light-navara-14w-2700k-6000k-cct-ip20-cob-w-1m-lead-5m/ Control: https://gosparky.co.uk/product-category/lighting-controls/control-gear/control-panels/ (note: there isn't a dedicated CCT controlled so I went for the generic RGB one) They've been in well over a year and I'm really happy with them. In my personal opinion, the only way to avoid light pooling is to use an LED strip. I had my kitchen units routed out with a single channel before hanging. The channel and strip was then inserted post Regards Tet
it's not the direction of travel, just the pace that I have a problem with Regards Tet
Now you're getting it! We adopt a sensible policy and give ourselves some time to innovate and find an alternative. Regards Tet
There is disruption and disruption. The outage last April in Spain that disconnected 31GW of power for 10 hours was caused by renewables and the fact that renewable output isn't managed at the correct frequency as it isn't generated by tunable turbines There is a balance to be struck here, the transition needs to be managed and needs to be proceed at a sensible pace. We have got too far over our skis Regards Tet
Materials for fascia’s & soffits
Tetrarch replied to newbridgewolf's topic in Roofing, Tiling & Slating
I used regular exterior ply with a custom single piece 2mm aluminium extrusion made by a local fabricator. The main reason was these should never need any maintenance in my lifetime Regards Tet -
I would have thought that explicit time-limited state guarantees would be possible until a the private insurance market can restablish itself Regards Tet
Ducting fumes from ventilated induction hob on a kitchen island
Tetrarch replied to Smallholdertoo's topic in Ventilation
We've had our 900mm Neff Downdraft I98WMM1S7B for over 18 months now. Our MVHR has a double extract (almost) directly above the hob. The outlet vents through an open vent in the plinth, it has a 90-degree vent on floor level but isn't even ducted to the opening. I took the picture attached just now and took the opportunity to remove the vent and check the opening. There is absolutely no presence of any grease build-up or residue there. The MVHR vent is also grease-free as far as I can tell Regards Tet -
Allocating your precious resources on the horizontal surfaces is (IMO) the way to go Your island will absolutely be the focus of your new kitchen. It is what you see and what you notice, it will become your social centre, your prep. area and the focus of your kitchen. I would suggest that the surfaces are more important than the cupboards to some extent You definitely should actually go and see the products themselves. Our kitchen supplier got us in to see the supplier of the slabs in their raw polished full-slab form. After a decision was made we managed to negotiate with the quartz finisher/installer to get the splashback in the same material at a discount and one waterfall edge thrown in for free from the initial quote I've since been back to the quartz installer to get window sills made up. Regards Tet
