OldSpot
Everything posted by OldSpot
I've got a Grundfos UPM3 AUTO 25 70 130 on an Ivar UFH manifold. Just trying to work out why you wouldn't just run it in the "Constant Pressure Auto Adapt" mode as opposed to any of the other 3 Constant Pressure settings as this seems to cover all bases? Or have I completely misunderstood!?
Planning in Principle - what constitutes "Householder Development"
OldSpot replied to OldSpot's topic in Planning Permission
Thanks for your thoughts. It might have been better if I'd have put "if someone wanted to..." as I'm interested in whether this route is permitted in the circumstances š -
I'd be interested in people's thoughts on the following. If I wanted to building a separate dwelling in my garden but it required me to demolition part of the existing house (single storey extension) to do so could the Planning in Principle route be used? My view, having read the various documents, is that it can't as partial demolition (or alteration) constitutes building operations which is defined as "development" and...... Householder development is specifically excluded from using the PiP route. According to The Town and Country Planning (Permission in Principle) (Amendment) Order 2017, LPAās can only granted permission via that route under certain circumstances. They are not able to granted permission under PiP when the application is in relation to āHouseholder Developmentā. Section 5B(5) of that Order states that Householder development means ādevelopment of an existing dwelling, or development within the curtilage of such a dwelling for any purpose incidental to the enjoyment of the dwelling, but does not include change of use or change in the number of dwellings in a building;ā So it then comes down to what development of an existing dwelling means. The Town and Country Planning Act 1990 has a section on what is classified as development: That states in Section 55 (1):āSubject to the following provisions of this section, in this Act, except where the context otherwise requires, ādevelopment,ā means the carrying out of building, engineering, mining or other operations in, on, over or under land, or the making of any material change in the use of any buildings or other landā And then further in (1A)ā¦"For the purposes of this Act ā building operations ā includesā(a)demolition of buildings; (b)rebuilding;(c)structural alterations of or additions to buildings; and (d) other operations normally undertaken by a person carrying on business as a builder.]" So it seems that if you demolition part of an existing dwelling to seek permission for a new dwelling to be built the PiP route can't be used. Thoughts?
Steel Ridge beam to rafter connection details
OldSpot replied to OldSpot's topic in Roofing, Tiling & Slating
Further investigation has revealed this is the standard of construction I'm left to deal with!! That's the rafters siting on the ridge beam Having done a bit more research, I came across this suggested solution from an engineering forum: bearing on top of steel ridge beam -
Just realised I posted this in the wrong section so re-posting here... I wonder whether anyone could offer any thoughts on this connection detail please? The extension we have has a steel ridge beam to allow a vaulted ceiling. The rafters have been skewed to a 2" timber with what look like your standard nail gun framing nails. The timber has been bolted to the steel i-beam. Make-up is as shown in the picture below. The rafters haven't been birds-mouthed onto the timber but are just as shown. (The horizontal timber shown is a ceiling joist so doesn't extend from wall plate to wall plate and is about a 1.4m down from the ridge. Floor to ceiling is 2.5m) Any thoughts as I'm slightly concerned about the roof loading and restraint onto the steel.
OldSpot replied to OldSpot's topic in Lofts, Dormers & Loft Conversions
Thanks all. Alas I fear that's exactly what might be happening š”. -
Thanks Tommo, I wouldn't guess it but unfortunately it's already built (before we bought the property)! -
Thanks both, that helps!
Can someone help me understand these figures please? For example, the first model says at an ambient temp of 7/6c and a water in temp of 30c and out of 35c, it has a nominal capacity of 6kW but it also has a heating capacity range of 3.10 - 8.90kW so can output more than the nominal by 2.9kW..? Presuming there is a direct relationship between Heating capacity and Heating Power Input? i.e Input = 2.10kW, Output = 8.90kW On the MCS product pages, they list an SCOP at different flow temperatures - what ambient temperature is this measured at and is there anywhere to see the SCOp at different ambient temperatures. How did you determine this James? Many thanks.
Yeah I agree James, it is a bit thin on the ground and requires significant searching to find anything! The "glossy brochure" has a bit more data.....(here) and includes the sound power level iaw EN12102 Just on the subject of noise: I see from the noise calcualtion that note 4 only extends out to 30m. If the distance to your neighbour is >30m can you account for the lower sound level at an increased distance? Common sense would suggest so but this is planning we're talking about!
Thanks both. Done a little more digging and they are made by Guangdong Phnix Eco-Energy Solution Ltd and appear to be the same ones as sold by Earth Save Products The MCS data ( MCS code BSI KM 748508/7 ) suggests an SCOP of 4.96 wi@ 35Cth a flow temperature of 35c for the 9kW one.
Came across these ASHPs recently and wondered if anyone had any thoughts on them? Ecoheat Superheat Seem pretty cheap but can't find any detailed specs for them?
Hi James, Thanks for highlighting this as it is thought provoking and forearmed is forewarned! Yes, but if your neighbour complained about noise and your ASHP install was shown to have the same or less noise than was required by MCS then it could be demonstrated that it was to an equivalent standard. I suspect the LPA would then be content and would be on shaky ground if they tried to take enforcement action. A court would also take a very dim view of the LPA if they took legal action without first trying to resolve the issue first. To do so would require the LPA to provide information on why they didn't think the install was of an equivalent standard. Backing this up is that the guidance to LPA's is that they should try to resolve the issue without resorting to enforcement action. In general, any action should be proportional and be in the public interest. Simply because an install hasn't been carried out by an MCS registered installer, without evidence as to why it was required, would I doubt pass these tests - especially if the LPA also failed to define equivalent. The guidance also says that action should not be taken if "there is a trivial or technical breach of control which causes no material harm or adverse impact on the amenity of the site or the surrounding area". So again, if the install has been carried out to a high standard then it is unlikely the LPA would have grounds for enforcement action simply because MCS aren't or weren't involved. Granted this is contained in UK Government guidance to LPA's but as with nearly all UK Government guidance, you should follow it unless there are overiding reasons not to. My final thought on this would be that if you could only install via the MCS Planning conditions route then there would be no need for "equivalent" in the text. By including it, there is an acknowldgement that there is another route but it is clearly up to the installer to ensure they do a proper job. So, as I started , thanks for highlighting this. It's likely that many previously believed you can simply install under PD without consideration which is very much not the case! Cheers.
Of course the MCS documentation is going to say it has to be installed by an MCS installer. It's a bit like car manufacturers used to say that you MUST have servicing carried out by dealer network to maintain the warranty and look how that ended.... I think the real question is what "equivalent standard" means and what an MCS installer does that no-one else is capable of doing? If challenged I think it would be reasonable to ask the LPA to provide information on what they viewed to be an equivalent standard. A response of simply saying it doesn't meet the MCS planning requirements wouldn't be sufficient because you wouldn't be declaring that it did, only that the install had been installed to the same standard and was thus equivalent to. If it went to court I would expect any judge to ask MCS to provide details of exactly what their registered installers did so a view could be reached on what equivalent meant.
Of course though, the rest of our UK tax system is completely even-handed!
used water softener: harvey twin tank worth a risk?
OldSpot replied to oranjeboom's topic in General Plumbing
Which Harvey unit is it? The ones I have seen (mainly S3/HV3) don't have that rotor with left & right on and have a slightly different layout on the top. I'm considering buying a Harvey so would also be interested in what the numbers in the boxes below "Service"; "Regen"; "Resin"; & "BV" mean if anyone can help. -
I bought a sink from Vieffetrade and they sell all manner of things. They're based in Italy but buying from them was quite a bit cheaper than in the UK - even when shipping was included. I was sligghtly concerned but the comms from them were really good and it arrived after a couple of weeks. It was well packaged on a crated pallet and was sent via air freight to us.
Or Mapei 3240 seems to reasonably easy to source too.
- 11 replies
- tiling
- self levelling
Thanks Nick, I reckon it's 8 or so sqms, part of which is >5mm. Noting your previous comments on 2 part SLC, I can source Arditex NA or Mapei Latexplan locally so I wondered about using that? According to Ardex you can use Arditex NA to fill in Ditra prior to tiling, although I've got Durabase CI++. Thoughts? KRgds.
- 11 replies
- tiling
- self levelling
@Nickfromwales Sorry to resurrect this thread but I've run up against a similar probem where Durabase CI++ is already down. It's a concrete screed with wet UFH embedded. If I understand you correctly Nick - to level the floor - you work out levels, mix up the adhesive and then trowel/straight edge it level to the high point(s)? After that, do you need to leave this layer of adhesive to dry and then just going ahead with the tiling as normal or is there anything else to do first to the adhesive layer? In the first paragraph where you then say "apply the SL, mixed" that's just to cover the UTH wires so wouldn't apply in my case? Also, can anyone clarify why you shouldn't use SL over Durabase CI++? Many thanks for any help! Ps They're stone 900 x 600 so putting them down and then taking them up again isn't simple!
- 11 replies
- tiling
- self levelling
Cheers all.
- 21 replies
- doors
- spraying doors
(and 2 more)
@Ian I know this is going back a while but presume still no issue with the doors and Osmo Poly-x?
- 21 replies
- doors
- spraying doors
(and 2 more)
Just getting around to this so would be interested in any updated prices...
Or here.... Boom, Boom!
