ruggers
Everything posted by ruggers
Airtight walls & fixing stuff to them
ruggers replied to WWilts's topic in New House & Self Build Design
I don't think a vapour barrier will be required on masonry walls by regs when i receive my completed plans, I'm just considering anything that may help pending the cost of it vs how much it involves. I know the architects plans will mainly just be software pulling over standard data and it will take suggestions to add anything extra to it. I'll be adding a parge coat now, but as others mentioned, these may crack over time especially while bedding in, and once covered with board, it wont be visible. The D&D walls will be getting full perimeter seal, ceilings vapour barrier and I presume internal stud walls too? I thought it might have been a good belt and braces idea to also fix a vapour barrier behind any walls I'm using battens on as I wouldn't have the D&D seal if the parge cracks. The posi joists are an awkward size 253mm high & don't match the block courses, so if allowed, i think a bolted on wall plate attached to the face of the inner leaf would be best to hang joists off then rest on internal walls. If they have to go on the inner leaf, Tony tray or something like the rubber joist seals. What are ceiling vapour barriers adhered to block work with, butyl tape or tube sealant? Apart from the brick work and slating the roof I'll be involved with most parts either on my own or assisting trades I know or who've been recommended so hopefully can keep it right if I get enough info. Once I start I'll post up any work for others to learn from the good and bad points. -
I agree the wet plaster is a great option for masonry inner leaf, but with 100mm PIR partial fill cavity wall construction I'm looking to add further insulation to the inside of inner leaf whether that be D&D insulated board, or insulated boards on top of wall battens providing space to run some services, or some form of insulation between battens & standard board on top. The latter would have a lot of cold bridging though. A couple of ground floor walls will require water supply pipes dropped down but thats about it. Some rooms I can afford to lose a little off the inside, others not so much but would like to keep insulation thickness consistent. Looked at blown bead & I don't feel comfortable with certain things I've read plus, I'm in a severe wet/wind driven area with partial face bricks so not recommended after consulting one company. Great points there Nick, I never considered parging before the joists go in via hangers or wall plate method same for the trusses and leaving a big enough gap between last truss & gables to be able to parge & add insulation. How are vapour barriers adhered to concrete block walls to prevent an airtight seal with battens over? Does this mean neat or a lightly diluted SBR painted onto the perimeter of the slab and lapping up onto the walls or in addition to using Purple paint you mentioned. I can't see how SBR alone would form any find of seal? -
Airtightness - Parge Coat vs Airtight Paint
ruggers replied to Johnny Jekyll's topic in Heat Insulation
Nod that sounds really fast for what I'd expect. I understand you don't have to polish it up or get it tidy but it just seems a lot of area to cover in a few hours floating on. Do you prefer sand and cement or the sound coat or other? I imagine it plastered on being a better job than brushing it on thinner it's just getting the labour in Cumbria. -
Does this apply easier or require much less work than the likes of bonding and multi finish? I can't even image one house being completed in 2 days with a float. Very hard to get plasterers where we are. -
I'd be more concerned about it being the other way affecting the cable, it was in the small print when i looked on the kore website. Sleeving would get around this anyway as you say.
What was your choice or mixture for parge coat, Yes MVHR was planned from the start, Spoken to a few companies and favoured two over the others but would like to do more research on this and not cut corners. -
@SBMS I'll be similar wall area as yourself, actually around 40m2 less. I've been reading some of the posts on here, had a look over the Kore system website but it says that for the West coast area its severe wind driven rain zone and a render finish is required instead of brick finish. The cavity is already 150 for the partial fill. It's hard around here to get any labour to do anything different to traditional. Most people won't entertain wet plaster only board skim, PIR all the time if not timber frame which I looked and it was at least 20k more for the build. Reading some older posts I seen two comments I didnt understand one mentioning to sleeve all pvc cabling coming into contact with the beads and another saying any opening DPC to be laid flat. I will have to check that again.
I'm looking to start a 100mm pir partial fill this year. How does EPS beads compare in price compared to PIR sheet, do the plan needs changed much? Can you also use this with facing brick exterior as theres a lot of mortar with potential to let in more water than a rendered finish.
@ProDave @Russell griffiths @Nickfromwales I thought it's much better to jump onto this relatively new post rather than start a new one repeating what many have before. i'm in the final stages of submitting B regs to building control for a masonry build 100mm partial fill cavity house, so if there's any small changes I can make, now is the time. So i have further stupid questions to ask ? I've read a lot of air tightness posts yesterday and theres for and against to all. Theres wet plaster, or parging the inner leaf, then adding a membrane then battens and boards followed by skim finish, or dot & dab with sealed perimeter boards dab with or without parging. Before I heard of sealing the inner wall,I was just going to dnd board to the block having a complete perimeter of dab on each board. Q1. Over 2 floors I have roughly 140m2 of exterior walls that would require parging, how long would this take a professional? Can i brush it on like tanking instead of floating? Q2. What kind of membrane are we using for walls under battens, theres so many? is it duct taped to the ceilign vapour barrier and butyl taped at the bottom to the masonry? Q3. Metal back boxes, i can seal around these with a seal and or board dab, but how do you seal the cables coming into the box? Q4. Do battens/boards/voids not make it even worse for fixing anything to the boards over dnd? Q5. Does a wet plaster finish not make a house lose heat quicker than a plain or insulated board finish when a PIR partial fill cavity is used? I see it too ways, the inner leaf retains the thermal mass via cavity insulation, but boards inside or even better, insulated boards would prevent your heat getting to the inner leaf as quick. -
What type of build construction and airtightness do you have to achieve them levels, it must be well insulated in the walls floor and roof area. Do you just have the 1 thermostat then? I understand the benefit of the electric towel rails now but I wouldn't like an all electric house with it costing 4 x more per KW hr, It can be more efficient in response times but electric UFH seems poor and expensive to run.
@ProDave Thats sounds really good managing to not require them upstairs. The site is about 400ft above sea level and can get a bit chilly in Winter, I'm not sure what to expect in terms of heat loss from a masonry build with cold loft compared to some timber frames. I'll be having 100mm PIR in the cavity, rockwool in all of the stud walls and between the ceiling & floors. Loft insulation between and over the ceiling chords, I was going to enquire about the foil quilt for under the rafters more as a heat deflector in summer to stop the slates transferring so much heat into the loft but the loft is trussed so quite awkward to make it sealed. There may be no purpose to the superfoil type if it's not sealed. I was considering adding insulated plasterboard certainly to the North facing walls, but unsure if I do all rooms in it or not until I 2022 quotes. @JohnMo If you can shut off the heat but can't call for it, is this just by using standard TRV's? What's the benefit to having electric towel rails over water heated? What are you referring to as linking to an area, do you mean don't extract from the ensuite, or do you mean to make sure the ensuite radiator is always linked to an area that will be calling for heat throughout the day? I've various reasons for wanting zones, some might not need applied to a new build vs my old current house with only partial insulation. 1.Temperature control over certain rooms, like living room at night when people are in bed not wanting bedrooms heated. 2. When working from home just heating the room i'm in for 8 hrs or heating only 2 rooms early morning as I leave for work 2.5 hrs before the kids. 3. I just thought it was more efficient to only heat the rooms we use the most on some days. I'm used to an older house with a living room fire and all radiators controlled from one thermostat. It heats up well and loses it well in the old part with no wall insu., new extensions better.
Both assumptions are correct, and it will be airtight and highly insulated as per regs, but I should maybe rephrase part of Q2. I understand that the incoming air will be lower temperature than what is being extracted due to the heat exchange process/loss. But If i have a small ensuite that is enclosed, with an MVHR extract vent, if the only source of heat in that room is a radiator, during the winter months, when that radiator isn't turned on because the zone it's linked to isn't calling for heat, would it not end up really cold because any air that's in that room has been extracted out? If I had no extract in there, then all of that heat would be retained in the ensuite room after the radiator turns off if I insulate the walls around it correctly. Although any smells wouldn't escape with no extract. I don't quite understand the quoted line?
After delaying the start of a 2 storey masonry self build house 2 years ago, I'm looking to possibly make a start this summer and I have some questions I'd like answered to help me make decisions on where to place my heating zones, mainly linked to how the air will move. I'd prefer to understand this before I engage with the MVHR companies again as I'll be doing a lot myself. Questions: 1. Are extracted rooms cooler than supply rooms when they aren't generating heat. Example, when not cooking or showering, meaning the extracted air isn't too warm from that room and it not having a supply vent? 2. We will have a large master bedroom with small ensuite, toilet, sink & small radiator only, Will it end up really cold when the ensuite radiator is off because all of the air is being removed. Knowing this will let me decide if I have the ensuite as part of the same zone as the master bedroom or do I have it on open circuit (Heats when any upstairs radiator is called). 3. Hallway & landing I was told, they will unlikely need vents as the air will move between them from other rooms. If so, will there be cold spots in these areas with air movement? I'm trying to decide if I have the hallway on its own temperature zone, link it to another zone, or have it on an open circuit to keep the central temperature balanced with it being a central hallway. Details: The house design is fairly basic, ground and first floor, cold loft, central hallway and landing. Previous talks with companies were showing (5) supply air vents to 4 bedrooms & the downstairs living room. Extracts (6 Vents), from the ground floor kitchen, utility room, downstairs bathroom, plant room, upstairs bathroom and ensuite. We will have wet UFH downstairs zoned, & radiators upstairs some zoned.
Seamed metal roofing or catnic SSR2 advice required
ruggers replied to ruggers's topic in Roofing, Tiling & Slating
Thanks for the photos, looks quite a big job. How do you trim them long ways for the cut ends like each end of yours being 4m ish from the photo? I will have 1 top abutment, 1 side abutment and one verge but it's quite close to an exact sheet size, i haven't yet built it so if required for a better roof, I could tweak sizes 25-50mm. How have you found the noise when it rains? -
I have provided plans to your colleague and had a glance over the installation guide, but theres a lot of tools required for a one off small porch roof. I thought the snaplock minght of reduced the need for as many tools , the basic tool kit required says £550? The roof is an abutment at the top and down one side with a verge on the other side. 3m wide and a 2100mm fall at 7 degree pitch, i can go anywhere between 5 and 10 but would prefer to keep it low. So I could really do with an estimate of the costs including tools vs labour to compare against the estimate from Catnic/colourcoat urban. Is the greencoat PLX a different material used compared to the SSR2 of catnic? -
Thanks, but I need to use a plain surface because i will have slates on the main roof but can't achieve the same pitch on the porch so unable to use slates. Any other types would just look too much. Can I buy direct from the website or will I need to go through a supplier? Is there a difference in product material or price between colourcoat urban and the SSAB greencoat PLX? -
Thanks. I'm able to achieve the minimum pitch easily, I'm just looking at what products are available in metal standing seam, the various prices, longevity and if possible to fit myself. If I use GRP as a lean too I'm not sure it will look as good from the front elevation of a house as a lean to roof so it would be better in a parapet style but then I've the expensive of capping off the top and it's not too straight forward the face walls are being cladded in stone and different thicknesses. Flat roofs cause more issues if they leak and creating through wall drains. The standing seam metal estimate from Catnic SSR2 wasn't too bad but I don't know anyone who's used it, It did require £300 worth of tools to self fit that i'd not use again. Is the tata steel colour coat urban a different price or product? -
Does anyone have any information on the use of catnics standing seam metal roofs or any other companies I could speak to? I'm planning to build 2 storey self build house from brick construction and the architect suggested a metal roof for the flat/low pitched porch roof, the porch is external to the house but a closed front with locked door keeping shoes and coats etc. There will be 2 external cavity walls exposed as it is built into an internal corner of the house, so other than a parapet type roof or a low pitched lean to roof and standard gutter I can't think of many options. The size is 3m x 2m. Parapet roofs look a lot more prone to leaking if something fails and some of the aluminium copings for the top can be very expensive if a GRP roof is used or EPDM.
Plastic vs Copper pipes for radiators
ruggers replied to Raks's topic in Central Heating (Radiators)
I'm going to contact them later today for some prices. They also have a good warranty compared to some if it's worth anything in the small detail. Thanks to everyone for the help. -
Brilliant, so the corner TRV you sent will just give the same look as onoff's picture above but a few less joints & pipe. Feels like a big relief resolving this so i can now select some components.? a decent manifold. -
Theres not really any other way to do a sharp 90 degree from a wall into a towel rail where you need chrome pipe. But there shouldn't be too many of these in a house and compressions are fairly solid when used correctly. Nice job. -
Thanks, I didn't think it was as simple as that, so it's just a pipe inset that slides inside the 16mm pipe and the tapered end fits inside a standard 15mm compression fitting or lockshield. The nut on the 16mm pipe has a thread that fits the 15 compression fitting? This looks the same as the link you posted too. https://pswtradesuppliers.co.uk/brass-compression-fittings/89-adapter-16mm-pipe-x-15mm-compression-fittings.html And at the manifold end, just use 16mm eurocone fitting with 3/4 thread like this: https://www.underfloorstore.co.uk/product/warmus-compression-adapters I didn't realise you can fit a range of pipe sizes from12/15/16 into an UFH manifold, you just buy a eurocone to fit your pipe size with a 3/4" thread and the taper takes up the gap and makes the seal if that correct. -
What pipe did you use with them? They only accept 15mm pipe. I need to join pert or pex from the manifold to each radiator. I can't think of any way other than having the manifold inlets and the radiator fittings both 15/15 or 16/16 to have one jointless run of pipe from end to end. Or pay 4 times the price for 16mm lockshields on the rads at £16 each. -
Any reason why you think they are crap? They are definitely expensive, someone just said they had excellent flow rates. I don't know what makes a good or a bad one, they all look the same so i'm relying on people who install & replace them regular to give me theirs views. I've not seen them elbows before, they would do but the reason i wanted standard valves on, was incase i remove the radiator to decorate or replace i suppose. I like to have one of them straight tails with an inline drain off on radiators, then an angled valve or lock shield. Theres 9 radiators total, 5 or 6 will be actuator controlled, 3 or 4 will just connected on the open circuit (So heat up when any others call for heat) because they are in bathrooms, some are towel rails. -
It's for a new build with dot & dab walls & scurtain board, most radiators are external walls so it would be hard to get 15/16mm pipe & fitting hidden otherwise i agree, also i don't like TRV horizontally adding to the length of the radiator. Does this mean if you use 15mm pipe & cones, that the manifold ports need to be 15mm, you can't fit 15mm pipe to a 16mm manifold? I'd like to use 15mm upstairs but there only seems to be polypipe that use 15mm manifolds. I was told they are an excellent manifold because flow isn't affected on the other zones when others open & close unlike cheaper manifolds, but a 9 port polypipe manifold is £300 without anything else which is a lot more than other models. I don't want to skimp on important components but haven't got money to throw away. 15mm x 1/2" angled rad valves with compression fitting are about £3.50 each. The only 16mm valves are £16 each. I'll be using a gas system boiler & unvented cylinder, UFH downstairs on 4 zones with actuators, and rads upstairs with 5 zones using manifold & some actuators. Some pipe I seen was max 60 degrees and rads will be 65 to 75 degrees depending ho i size them. 16mm manifolds and pipe seem to be easy to get hold of everywhere, but it's not cheap or easy to source angled radiator valves. Unless theres an insert or cone fitting i'm unaware of that allows 15mm pipe into a 16mm manifold, i have an expensive problem at either end. Its a 15mm manifold vs 16mm radiator valves. Using 16/15mm inline reducer under the floor means joints under the floor.
