Everything posted by Adsibob
What’s the worst mistake you’ve made on your build?
Adsibob replied to Adsibob's topic in General Self Build & DIY Discussion
Thanks @Gus Potter. I think what you are saying is that this is all a very deliberate design that can’t be changed? At least not easily! -
MVHR system in new build
Adsibob replied to deuce22's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I think you'd really struggle to find a unit big enough for your house that cost less than £2400. You want to oversize the unit so that you can run it really low. Add all the ducting and some nice looking lindab airy valves, booster switches and humidity sensor and you're going to getting close to £4k in materials. If you design and install it yourselve you could save a few thousand, though I think I'd want a professional to design it for me. Some do basic designs for free as part of their "marketing". -
Rigid vs semi rigid ducting?
Adsibob replied to SBMS's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I didn’t know that. Is the BCO’s flow rate / Air Change requirements excessive then? -
Maybe sleepless nights are rights of passage for us self builders… -
Thanks @Nickfromwales. On your response to Q2, i probably wasn't being clear. My question was whether the fact the red hand is pointing to 4.8 means that it is set to restrict to 4.8 and so the reading of 3.3 is just the unrestricted reading at that time of the day. i.e. is it best practice that when you set it up you leave the red hand pointing to where you've restricted it to? Sorry, no idea how a PRV works.
hmmm. not sure that would work. I think the options are to clad the projecting corner in an oak veneer to match the staircase or leave it as it is or ask the SE whether we can reduce it. Assuming it can be reduced by shortening steels 10 and 11 and then joining them together with a 1/4 ring beam to link 9 to 11/12 junction as suggested by @Radian, anyone have any idea what it would cost to remove the plasterboard around this 85cm by 85cm corner, cut the steels, connect in the the ring beam and patch it up again? -
Due to the open plan layout of our ground floor, BCO insisted on getting a fire engineering report which recommended a sprinkler system. We went with imist who initially said all I needed to do was ensure there was a power supply and water supply to the area where the tank and pump would be installed and they would do everything else. This turned out to be a bit misleading with them actually sending through a list of much more detailed requirements for my plumber and electrician to sort out. They have now done that and I had to supply photographs of what had been done to imist prior to the final fix of the sprinkler system. A These photos have prompted imist to raise the following question: I can see you have installed a pressure reducing valve, is this due to having a booster on site and the pressure being above 4 bar?I find this question a little surprising because I thought PRVs were fairly standard operating practice and required to balance the system. Our pressure on the the below gauge is showing 3.3bar. This was take at 845am on a weekday, so I assume though not quite at peak demand time, it was close to peak demand time. My questions are: Why do imist care given they state their requirements are a minimum of 1 bar and I clearly have more than this? Does the red hand point to where the PRV has been restricted to? i.e. my pressure won't exceed 4.8 bar?
Party Wall agreement and neighbours questions
Adsibob replied to Lk1980's topic in Party Wall & Property Legal Issues
If she has consented, it is too late for her to ask for anything. Carry on. -
Well annoyingly, it was the staircase designer that pointed this out AFTER the staircase had been installed. -
Yes -
Yeah, bloody ridiculous that. But what I don’t get is why the SE specified 10 in the first place. If it can be removed, what’s its point? I fear that when we consult the SE on Monday, he will say we can’t just remove it. -
As far as I can see, all steel 10 is doing is connecting 9 to 11. Two thirds of 11 is holding up the sky light, but I’m not sure Why steel 11 needs to project beyond where it connects with 12. Maybe @Gus Potter has some views on this. The issue is purely an aesthetic one. The staircase would look much better with a bit of space around it. If we got rid of that redundant corner, it would show off the staircase more, and let it “breathe” a bit more (visually). Difficult to explain, it just looks wrong having the beautiful sweeping bannister almost touch this very angular corner. If it was cut along the diagonal, we could then build out the diagonal into a curve. Even if it’s just a 250mm or 300mm radius curve it would look so much better. -
Ouch. Did you have to take up the karndean flooring up and redo the screed? -
Why tell, when a picture says 1000 words: Spent a fortune on a beautiful oak staircase, with a lovely swooping bannister. Except that this corner of the floor (which is completely unnecessary as there is nothing above it) is obstructing a big chunk of it. There is no breach of regs, as plenty of head height above the stairs, just bloody ugly. not so straightforward to round off this corner because there are steels where the purple lines are. The steels are to support an internal skylight, part of the hole for which can be seen to the left of the picture. Here is the structural drawing (the junction between steels 10 and 11) is the ugly corner: Both steels in question are 150 x 90 PFC. Wondering if they can be cut shorter and the shortened ends joined by a diagonal steel. Obviously need to consult with an SE, but it’s a Saturday night and I’m pissed off! -
How to attach a tv mount to a soundproofed wall
Adsibob replied to Adsibob's topic in Sound Insulation
Maybe this will solve my problem: https://www.amazon.co.uk/1home-Universal-TVs-Height-Adjustable-Management-Holds-32-55-Height/dp/B075FN4GH5/ref=sr_1_1_sspa?keywords=sony+tv+stand&qid=1647102288&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExSzZTODhCSkpPMFZFJmVuY3J5cHRlZElkPUEwNjQxODg1Mk84WUlURzlBUzFMMyZlbmNyeXB0ZWRBZElkPUEwODExODkyM0dOUVpZMDE4QTA0ViZ3aWRnZXROYW1lPXNwX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU= -
The problem is (and this is a very middle classed problem) that the soundbar is curved and has speakers on half of the top, so really nothing should sit on top of it as I imagine it would interfere with the Atmos projection. -
We spent a small fortune narrowing the width of our room by a few inches so that we could build a false wall to soundproof the party wall. We have SbX boards which are filled with a honeycomb membrane of sand mounted on some metal studs which are isolated from the party wall with sound insulation mineral wool fills the voids. On top of the Sbx is soundproof plasterboard, two layers with the joints staggered. It's a very effective setup. I am now thinking that it might make sense to put a tv bracket on that wall, but I don't want to compromise the sound proofing by drilling into the wall for the fixings. Some people have suggested green glue can help seal the fixing points, but I'm not sure how that work. There is an alternative which is for the TV to just sit on a cupboard (which is going under the TV location anyway, but if I do that i need to somehow find a way of elevating the TV stand (which has a rather large oval shaped base) by 12cm to make space for the soundbar to sit underneath it.
DIY Kitchens Fitted Office - Colours
Adsibob replied to canalsiderenovation's topic in General Joinery
That all makes good sense. What Material worktop are you going for? -
@canalsiderenovation are you planning on sitting on stools for your office setup? That is really not great from an ergonomic perspective. You really want a proper desk height (which I think is around 75), or a standing desk (which depending on height is around 110-116). Those stools look like they are up against a 90-93 kitchen counter, which is really just not going to be comfortable at all. i also think that desk alcove is quite narrow. How much space will each alcove be? -
We’ve decided we are going to carefully try it out first before making any changes as the staircase company says they leave the treads slightly textured so that they are non slip. I tried it in socks, and it doesn’t feel slippery, but we need to see how it performs. Still a bit worried about the kids slipping though.
We are thinking of putting an anti slip coating on our oak stairs. They’ve been stained with Saicos ground coat, and then finished with three coats of Saicos hard wax oil. I subsequently learnt that Saicos do an R10 anti slip coating, though need to work out if I need to remove the hard wax oil first. (Link below.) https://www.saicos.de/en/produkt/additive-anti-slip-r10-2/ OSMO make an R11 coating, but maybe there is more risk of incompatibility with the Saicos finishing products I’ve already used? Does anybody have any experience with anti slip coating for oak floors/stairs, whether Saicos, OSMO or something else?
Tile Edging Options - Metro Sage Tiles
Adsibob replied to canalsiderenovation's topic in Floor Tiles & Tiling
You can also get tile trim in all sorts of finishes. Best to consider other finishes in room and match those. E.g. in our under stair WC, we are going to have antique brass taps, so we are going with an antique brass trim. -
Planning is everything. You can do really nice things with metro tiles, but you need to choose your layout style, spacer size and setting point very carefully. Grout colour also essential. -
Getting a quote for some work and joiner has said that I should decide whether I want to go ahead soon because already birch is starting to go up in price due to the Russian - Ukraine war. Apparently a lot of timber comes from Russia and so prices are going up. Anybody else experiencing this, or could this just be a sales tactic?
