Everything posted by Adsibob
So just going back to the drawing board on this one, because the reality is that PoE is always going to be better than wifi. With the doorbell, we can rig this for PoE. There are a few compromises, but we can do that. For the camera, we could also do PoE, but only if I use a Powerline adaptor to send the internet through our electrical circuit. I have just tested this at the power point on the inside of the house which is nearest the point outside of the house where I would install the IP camera, and even with the kids streaming Netflix HD, I'm still getting 72Mbps download / 61 Mbps upload and latency of 15ms unloaded / 39 ms loaded through the powerline. That is much slower than our stupidly fast connection on standard CAT6 cables, but clearly plenty fast enough for an IP camera. So the questions I have are: 1) Will a powerline adaptor send power as well as internet through it? Googling this it seems the answer is "it depends" but it wasn't clear to me on what it depends. Perhaps the model. I have a TPLink AV600 powerline adaptor, and with the brand new electrical wiring in the house, it's giving us a great "ethernet" connection. If not, is it just a case of using an injector alongside the powerline? 2) How hard is it to drill through an external wall? It's a solid brick wall with about 50mm of insulation and then silicone based render on the outside. There is a breathable membrane on the inside as well as a void, both of which were installed to deal with a historic damp problem (1930s house) but the damp was fairly low level, and this hole will be almost 10 feet from the ground, so I'm not too worried about penetrating the membrane. Will i need to waterproof the hole?
What do you see as the added advantage of CAT 6A over CAT 6 for this particular use? I ask because when I googled this previously, I found the main difference came to this: “Cable requirements are often dictated by the equipment that is currently installed, or will be installed in the near future. 99% of all network equipment will support Ethernet data cable speeds of 10 Mbp/s to 1 Gbp/s (1000 Mbp/s). Take stock of your current equipment. Does any of your equipment require or even support 10 Gbp/s (10,000 Mbp/s)? Do you have plans to upgrade your equipment to support this higher speed? If the answer is “yes”, then you should use Cat6A cabling. Most of the time, however, the answer is “no”. In this case, Cat6A speed cable will not benefit you in any way, but it will certainly cost more.” So I’m not sure of the justification for spending more for this requirement.
Shall I make my “you need to get a good divorce lawyer on retainer” joke again, or is it getting tired?
Ok, good to know, but I’ve bought the AP already and unlikely to be able to return it, although the vendor did state that it would be fine for outdoor use. I will call them on Monday to try and return it. The alternative would be to build a cover for it. I had planned to install it on a fence, in a fairly well sheltered spot, but it is uncovered. How much of a cover would this need? Its projection from the fence would only be 35mm, not sure that includes the mount. Say the mount might take it up to 45mm or 50mm at the very max. Would a small roof that projected from the fence by 90mm be sufficient?
It was her idea. She wanted a view of the garden whilst washing up. Don’t think she would have settled for a peep hole.
I think the point of big windows is to lose the separation between inside and outside. We have a huge window in front of our kitchen sink, so that when you are by the kitchen sink, you feel like you are standing in the garden. Similarly with our 2.2m high glass sliding doors; whether they are open or closed the lounge is almost seamlessly joined to the garden. You couldn’t achieve those effects without large pans of glass.
No, that’s not right. It’s definitely rated for outdoor. The spec list states it’s IP54 rated: https://www.4gon.co.uk/ubiquiti-unifi-access-point-wifi-6-pro-p-10059.html I agree, but it’s too late for that, unless I tear stuff up that was finished over a year ago. I will not do that. Simply because the cheap Ring doorbell was wired with CAT 5 without my knowledge. The house was all finished, only then did we discover our walls’ steel rods were acting as a faraday cage making the doorbell wasn’t working so well. There is not an easy way to link the internet router to the end of the doorbell’s power supply. I also don’t want to set up my own video recording station, Ring is convenient and I’ma sucker for convenience and have bought into their system. Intuitively, I’m also a little nervous about it sitting in water, but isn’ta direct burial cable exactly designed for that?
Effectively a whole 5 bed house from scratch, so a lot.
Are you talking about running CAT cable to the doorbell, as opposed to creating an external WiFi? If so, we actually have the capability to do that, as the electrician decided to power the doorbell with CAT 5 cable, but the PoE doorbells are stupidly priced, and I prefer to have an outdoor WiFi network so that I can install a few devices outside. If that wasn’t what you meant, I’m afraid I don’t understand your question/point.
I touched upon this in another thread about the waterproofness of the U6 Pro, but thought it deserved its own post: This is the basic plan of my front yard/driveway: The yellow line shows one possible path of an outdoor rated ethernet cable, siting the AP at the yellow triangle, pointing both down the side alley and towards the wifi doorbell (which is in desperate need of a better signal). The advantage of the yellow path is that we will get a very good signal for both the doorbell, only 3.4m away and down the alleyway where in due course we are likely to install a wifi camera,or if that is too close for an optimal signal, I can also raise the U6 Pro up higher off the ground as the fence there is very tall, about 2m high. The downside of the yellow route, is that apart from needing a longer cable (25m as opposed to 10), the cable will pass through a plastic water channel (marked as slot drain Driveline on the plan). This is easy enough to do, but means the cable will often be wet (but who cares, it's a cable designed for burial) and could impede the effectiveness of the drainage, though unlikely, as the drain is almost 10cm wide and the cable will at most be 1cm diameter. The downside of the red route is that the U6 Pro will have to be mounted quite close to the ground and about 80cm in front of it, there is going to be a big car parked, which will block the direct line of sight to the doorbell, so could interfere with the signal. Also, less chance of the signal travelling down the side of the alley way. Aesthetically it will also be more prominent there, whereas could be installed more discreetly if I go for the yellow option. I think I've answered my own question, but can anyone think of any issues with the yellow plan. Will a cable that is 15m to 20m longer than the red route make a very big difference to responsiveness of the doorbell?
How waterproof is the Ubiquiti U6 Pro
Adsibob replied to Adsibob's topic in Networks, AV, Security & Automation
That’s good to hear. Any thoughts on how good the signal is at travelling around the corner of a building and then through a steel gate? I’m thinking of mounting it in my front driveway facing towards the house, and trying to work out whether I will also need a separate device to cover the side alley of our house, which has a big 10 foot high steel gate at it’s entrance. Another consideration is whether an U6 Pro AP installed on one side of the driveway will manage to emit a good enough signal that when a car is parked in the driveway, it doesn’t block the signal to the other side of the driveway. Can’t really install it much higher than 110cm above ground level. -
Bought this access point and was about to install it outside when a friend told me it needed a sheltered spot. He referred me to a review: ”the Ubiquiti U6-Pro was built to withstand outdoor conditions and the device is indeed IP54-rated which I suppose could ensure that it withstands some degree of abuse from the elements. But I would still be careful to not put it completely in the open. Make sure that there is some sort of roof above it, otherwise it’s not going to last that long.” Just wondering if anyone has any experience of installing Ubiquiti IP54 products outside, and whether you have had any issues. The spot I had planned does not have any shelter from rain.
I don’t know if the actual margin was £4K, that was just the difference between cheaper option 1, I contract directly with the English manufacturer (albeit the actual factory is in Poland), and they are responsible for everything; and Option 2, £4K more expensive, but quicker, contract with only other company authorised to sell this product in England, manufactured at same factory in Poland. The entity I contract with is responsible for surveying, supplying and installing. Everything. Both vendors in both options make money. I’m just guesstimating that if the vendor in Option 2 is £4K more expensive, although some of that might be additional cost, say a fee to get this exclusive joint venture deal with the manufacturer, there is margin to be made on the other aspects of the supply chain. So £4K is still a reasonable guess. They were ok. They worked too quickly in my opinion, ended up making mistakes and had to come back to fix a couple of issues. But they did come back, more than once, and were decent about it. Maybe 6.5 working days in total, including snagging, although the snagging was done by just one guy, so 11.5 man days total.
And yet it did not take anywhere near that long to install the windows! Two fitters attended, yes. But they were there for at most 5 days. So that is less than a quarter of a month’s salary for two installers (based on 4.33 weeks a month).
There is no chance in hell the intermediary was paying the same as the consumer. If the manufacturer can make a profit on the installation at £28k, I’m sure the intermediary could as well. The manufacturer teams up with the intermediary to get access to an alternative sales channel, so it gains from the partnership, and will give up some of its profit margin for that.
Well it might be rare, but it’s what I was going to do, as the manufacturer also offered a supply and installation service. But the wait was something like 18 weeks, and I was in a hurry and so the manufacturer put me in touch with a supplier that it had an exclusive contract with. They had a reserved space on the manufacturer’s assembly line, and as a consequence could get windows about 6 weeks quicker… but at a significant premium. It was an eye opener into the profit margins involved.
Well on my order, I was priced £28k by the manufacturer and £32k buy another supplier for exactly the same windows (made by the same manufacturer). So just on that quote, there must have been a pretty fat margin.
Similarly, I had a large 2G unit replaced twice, because the wave distortion was bad on both. Only I and the architect noticed it, but this was enough.
+1. Definitely replace it. The margins on windows are big enough that they will still be in profit, even with multiple cock-ups, as the price of individual parts, like the glazing units, is only a fraction of the overall sale price of the window.
Wheelbarrow left on outdoor porcelain patio tiles for about 10 days. Quite a bit of rain. Wheelbarrow has finally been moved and now there are patches of rust on the tiles where the barrow’s “feet” were resting on the tiles. There appear to be a multitude of products online for removing rust. Anyone have any recommendation as to a particularly good one?
20 to 25 tonnes of 15mm to 20mm gravel should cover that. That’s a lot of gravel.
Thinking of fitting something like this, to prevent damage to a perpendicular wardrobe door that is adjacent to our bedroom door, whilst still allowing us to fix the door open to facilitate a cross breaze at night. Anyone have any experience of using such items. SDS and ironmongery direct make similar. They seem like such a great idea, but what is the catch?
I think @Declan52’s point is that this thread, which I think is meant to be about the practicalities of remortgaging/mortgaging in the present market, is not aided or improved by the ins and outs of COVID.
Thanks all. I’m going to ask them to redo one of the doors so that we have a standard 3mm gap as per the drawings. They will have to do some edge matching with the veneer; I’m sure it’s possible.
