Everything posted by Adsibob
it's not even that bright! But me being the perfectionist that I am find it annoying. Weirdly, i just tried the light in that room and the issue didn't occur. I wonder if maybe it only happens after the light has been on for an hour or so, maybe it only "glows" after it has "heated up "(but even that would be surprising given it's an LED).
The mild irritation is that this is in our bedroom.
We have a long LED flexible tube light, made by ilumos, recessed in our bedroom ceiling. After being switched off, there is still a very very faint glow from it. Maybe 1% of its lumens. I googled this fault, and it appears there are several possible causes, from poor wiring, to poor bulbs to poor light switches: https://ledstore.pro/blog/2023/02/06/why-led-stays-on/#:~:text=Thanks to their high efficiency,to produce a dim light. the light in question can be switched on or off from three different light switches, all using the same brand of light switch, which I believe is this: https://www.corston.com/products/intermediate-toggle-antique-brass?variant=39293017751649&bcndyn=d2lkOjQ4OHxjaWQ6NTY5&gad_id=&utm_campaign=Google_Ads&gclid=Cj0KCQiAgK2qBhCHARIsAGACuzl1FlNR3r1YE3F-6TPccW9ae0fi-GGOtwnMByEOeoQZSo5eXcBeDy4aAoBbEALw_wcB That switch is made in China, and although it was very expensive I suspect the manufacturer focused its efforts on the brass switch plate rather than the internal switch module. The wiring is all brand new (less than 2 years old) so I’m hoping it’s not that. Can anybody recommend a high quality switch module that I could swap out for the three switches to see if this is the cause? It needs to be a toggle switch, not a rocker.
Mvhr might help. how old are windows?
Which heating option? Going round in circles
Adsibob replied to WGL's topic in Other Heating Systems
Agree. mvhr is good, but for various other reasons, not as the dominant heating system. If you went down this route, wouldn’t the increased airflow dry out the place too much, such that you would need an enthalpy exchanger thingy as well as a heat exchanger? -
All I’m saying is my heating bills are much less than you would expect given my house is now a 2300 square feet part 1930s semi, part new build, and I’m sure a big part of that is from mainly restricting our heating to the ground floor and half the first floor, and having a very efficient MVhR system. -
I’m not so sure about this. We modernised and extended a 1930s semi, spending a lot of money on making it airtight, insulating it* and installing a very good MVHR system (Brink Flair 400 which has an efficiency of 95%) and we manage to get away with only heating the ground floor and only heating the kids bedrooms on the first floor for a couple of hours before bedtime. This keeps the first and second floors warm enough for our purposes. My wife occasionally complains that our master bedroom is too cold, but this is nonsense; it hasn’t dropped below 18.5C this last week, and is only heated (at the moment) from indirect heat from the ground floor below and MVHR. Whilst we still have some variance between rooms and zones, I think the mvhr is helping reduce our bills a lot. i would however be concerned by a 80% efficient machine. Why not get something better? *our insulation is not top spec. We only have 2G windows, except for one 3G velux, and our EWI is not particularly thick, about 45mm. -
Crosswater make some good ones that aren’ttoo pricy. I like their MPro range.
Single room MVHR
Adsibob replied to Tony359's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I think you should call the various suppliers: BPC CVC Systems ventilation land and ask them to recommend and supply a basic machine. Being a garage, you probably don’t care too much about how noisy it is, and just something that is durable and problem free. For just a one room garage, I don’t think the difference between 80% efficiency and 90% efficiency will make any noticeable difference to your heating bills. I guess it depends how you are heating it and what the heat loss is, but unless it’s really bad, a 10% differential shouldn’t make much difference. -
Single room MVHR
Welcome Antonio. I would stay clear of unknown eBay retailers, and instead go with a company such as Bpc or CVC who can give you a free design service. Something like one of the cheaper units from here might work well: https://www.bpcventilation.com/heat-recovery/heat-recovery-units/vent-axia-unit How high is your ceiling, or how do you feel about boxing in some ducts on two sides of the room? I ask because given you plan on creating fumes, I would be tempted in having three fresh air supplies scattered around on one side of the room, and at least two extracts on the other side. This will require a ceiling void or some boxing in to conceal the ducting. Having said that, you can get low profile rectangular ducting that only needs about 7cm of height. -
Hello! Almost-complete on my garden studio build
Adsibob replied to oliwoodings's topic in Introduce Yourself
Looks amazing! Well done! -
MVHR intake and exhaust separation
Adsibob replied to dnb's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Obviously. Otherwise the Sahara would be experiencing heatwaves every day of the year. I think of a heatwave as unusually hot weather that lasts long enough it begins to get bothersome. -
Yes, I agree. I could have saved £200 on a smaller boiler, and also saved a bit of space in my utility room as I think the smaller one is 5cm less in one of the dimensions, can’t remember which now, but all things considered, it’s not the end of the world.
I think even there you are not immune from a hot summer’s day. Only last month you had a few: https://m.belfasttelegraph.co.uk/news/northern-ireland/official-heatwave-to-be-declared-in-ni-as-experts-predict-when-soaring-temperatures-will-peak/a1117229642.html Given climate change, summers will only get warmer. -
Ask that question again during the height of summer. -
Sorry, i never updated this. They did the work in the summer and then I had to duel with Cadent telephone operatives for them to come back and clean up the mess they left. It is working just as well as it did before the "upgrade". I haven't spotted any difference. I guess now is winter time, there is greater gas use in our street, but I don't recall having any issues last year. Ultimately, I think our boiler is massively oversized. With the hot water tank being heated at the same time as half the heating is on, the boiler rarely modulates to more than 45%. I think the most i've seen is 50%, when we also had a couple of towel heaters running.
Recommendations - Storage combi or Normal combi?
Adsibob replied to Del-inquent's topic in Boilers & Hot Water Tanks
@Del-inquent find out your mains pressure and flow rates as @SimonD mentions. We have one more bathroom than you, and still manage well with just a 300L UvC and system boiler. Unless you have lots of baths, you could go smaller than that, maybe 240L. In horizontal configuration they can be hidden in lofts quite easily. -
How much technical detail should a construction drawing show?
Adsibob replied to Adsibob's topic in Damp & DPCs
Thanks @LnP this is really reassuring. I think part of my sleeplessness was caused by the same worry you had, so reassuring to know that it’s not a massive task to fix - my builder likes to do things quite slowly, so what took your guy a couple of days will take my guy a week. I think the other thing that causes me sleeplessness is he is just generally quite a difficult man to deal with. He hates any sort of constructive feedback, let alone me pointing out a mistake as bad as this. He gets incredibly defensive and starts blaming someone else. That’s basically his personality. Luckily, I’ve always been able to see the good in him, and so despite various issues over the past couple of years, we’ve never fallen out. It took me a while, but I eventually learnt how to deal with him. That doesn’t stop it being a difficult experience most times. So I guess I’m dreading the meeting as I’m worried this bit of feedback will be the final nail in the coffin for our relationship. I say that, because in the past he’s always had the retention payment to incentivise him to continue, but I made that payment some months ago, so there isn’t much in it for him now other than decency and pride. So I will just have to deal with him extra diplomatically and probably end up paying for some of it. -
Nearby Piling, advice needed!
Adsibob replied to Residential build's topic in General Structural Issues
I’m not sure that’s accurate. Although it is best practice to comply with the PWA, it is not compulsory. It’s power lies in the fact that if you ignore the PWA requirements, then in any subsequent dispute, if it was caught by the PWA then the Courts can make negative inferences (ie without evidence) against the person who ignored it. -
Any thoughts on approximate cost to rectify this by: inserting three weep holes, spaced 45cm apart above the window and inserting 8 weep holes, similarly spaced, above the sliding door (the cavity wall above the sliding has no damp at the moment, but I want to future proof); and cutting out bricks to also insert cavity trays in a worst case scenario that this wasn't done either! In each case I suspect there will need to be some repointing done. If bricks break, I luckily still have spares. Though they've been stored uncovered on a pallett, and will be quite damp by now. Maybe I should bring a dozen into the house to dry them out for a couple of weeks? I'm hoping only (1) will be required, but want to understand how bad (2) will be. -
Young, naive and potentially stupid.....
Adsibob replied to ClifftopBuild96's topic in Introduce Yourself
Yes, give up now, sell, and buy a house that needs no work at all. -
I guess. Unless there is also moisture coming in through the parapet wall at the top, though there we have some plastic/composite coping stones and an overlapping membrane that came with a long guarantee, so seems unlikely. i hate this sh!t. -
Yes, I agree with this. What is best practice here? What should the window installer have done instead? -
I wonder if that is what the "Alternative Approach" in section 5.6 of BR Approved Document C refers to, which states: "The requirement can also be met by following the relevant recomendations of Clauses 4 and 5 of BS 8215:1991". I tried finding that British Standards document "Code of Practice for design and installation of damp-proof courses in masonry construction", but I can't seem to access it without buying it. If so, the builder definitely sealed the brickwork and mortar with a sealant, but I'm not sure what type was used. -
So is my architect just giving me false assurance that the bigger the cavity wall the less likely it is to need any weep holes? If so, I can’t explain why the small cavity wall above our window is visibly damp, whereas the bigger one, which is the same orientation, and just as exposed, looks fine.
