Adsibob
    10
Everything posted by Adsibob
  1. So basically this is a mistake by everyone involved: the architect, the builder, the brickie and BCO. I really don’t understand what purpose BCO serve? They seem more nuisance than actual assistance.
  2. I started a post a few days ago about what I thought was a faulty window leading to water ingress through the top frame of the window, but after discussion with my architect I’m now realising this is more likely an issue arising from no weep holes being provided in the external skin of bricks linking to the DPC tray which I’m hoping was installed within the cavity wall above the window. The on site findings are that the screws screwing the window top frame into the lintel above have rusted, and water is entering the window frame via those screws. There is no issue with the window seals, in that spraying water directly onto the window does not cause water ingress. Some 45cm or so above the window, the external brick wall is showing brown discolouration in the mortar around a few bricks. The discolouration is quite localised and does not occur anywhere else in the brickwork of the extension (which is quite big), but this is the only place where we have a small cavity wall above an opening. The cavity wall above the large sliding door doesn’t have weep holes either, and the architect tells me that the reason there is no damp issue there is because there is much more space within the cavity for moisture to mix with air and evaporate. No idea whether that is right, but it at least sounds plausible, his theory being that no cavity will be perfectly moisture free, but weep holes are only required where this is a problem. The construction drawings show DPC trays laid through the cavity wall at the top and coming through the outer skin of bricks, but that’s it. There is no further detail about including weep holes. There is also not a cross section of every new wall, so on our rear extension the cross sectional diagram shows the two side walls, but not the rear wall (which is the wall where we have the water ingress through the window problem). Is that normal? Or has my architect taken short cuts which have led to this omission? On the one hand, the builder I went with is very experienced and on the whole has done, or at least I thought he had done, a very good job, and I can see him saying that this is a design flaw, because the drawings aren’t detailed enough. But on the other hand isn’t this a standard construction detail, that any competent builder would know about? Surely cavity walls are bread and butter building work? What about the bricklayer and foreman (both employed by the builder) shouldn’t they have noticed the omission? Seems like a colossal f@ck-up!
  3. Thanks @SteamyTea. i did actually look at ironmongery direct, but wasn't sure anything they had would work. On the first one, this won't work as my carcass frame is not a flush fit with the door. The second just doesn't make sense to me. Both fixings appear to be fixed on the same plane? If that's right, how is it meant to fix onto something that is in one plane and something which is in a perpendicular plane? Even if it did theoretically work, the reviews for the product are bad. The third item looks like the best option out of the three (apart from the finish which just won't go with anything in the room). Assuming i could find something similar with a nickel or brushed steel finish, or even chrome (though my optic nerves are allergic to chrome), how wide do you think I could open the cupboard door with such an item. This photo (taken from a review of the item) shows a very narrow angle of less than 50 degrees: Presumably if I fit it closer to the edge of the door I can get closer to 90? EDIT: I've just seen they come in multiple finishes: Window Operators | Joinery Hardware | IronmongeryDirect
  4. Thanks Joe, but couldn’t something like this damage the door (just because It’sa cheap door)?
  5. I'm after a cupboard door restrictor for a bathroom cabinet that is only 126mm deep. Accordingly, the restrictor needs to be small enough to fit within that. i was hoping something simple to install that does not require routing of the actual door (since this is made of cheap MDF and is unlikely to router very well - and in any case I don't have a router!) I found this, but the supplier tells me it is too big to fit: Cupboard Door Restrictor PDF (gjohns.co.uk) (same product also sold by SDS). The door has a mirror on it, but is otherwise pretty lightweight (measures about 45cm wide, by 65cm high and 12mm or so deep). Can anyone recommend something? I need to restrict the door opening to anything between 85 and 91 degrees. Before somebody recommends a hinge restrictor, this will be complicated to fit as the hinges that came with the cupboard are not blum or some other standard hinge, and have no brand name on them so I can't find the little stopper that the usual manufacturers make that would have worked. I considered swapping the hinges for blum or hafele ones, but because these aren't standard hinges, I'm not sure the holes in the door will match exactly, so would be much easier to just find a separate cupboard stay. Perhaps @SteamyTea, @ProDave, @joe90 or somebody else with equally impressive skills can help me out. Many thanks.
  6. I’ve checked the drawings, and they do show cavity closers. It doesn’t say “cavity closer” it says DPC tray, which I’m hoping is the same thing; basically shows a DPC closing off the cavity. But discussing this with the architect, he tells me that the builder should have provided weep holes for the water to come out at certain points between the bricks. This definitely hasn’t been done. Architect’s suggestion is to cut out the mortar at those points and install the weep holes/vents now. I really do find this astonishing. Not sure what buildings regs is actually for, other than bureaucracy and fee generation.
  7. So I don’t think we have a cavity tray either. Is this a breach of building regs? If so, shouldn’t it have been picked up by building control???
  8. Here is a picture of the rusty screw by the way: I’m really concerned that water has managed to get that deep into the brick work.
  9. Annoyingly, our first water ingress issue started a month or so after the 12 month snagging period had completed. FFS! Yes, it was a bit odd being off for so long. I enjoyed much of it, but I think I’m on the whole better when I have a job and a salary.
  10. The job is pretty good. Not having time for issues with the house was suiting me rather well, until I started noticing water ingress. It just really p!sses me off that we spent a fortune and the newest bit of the house (ie the extension) is the bit that’s been problematic in terms of weather proofing.
  11. So it’s not the windows. Is either the brickwork or the roof. I f**cking hate this. Question: Does a coping stone need to project beyond the edge of of the brick that it sits on. We have a parapet wall, and the coping “stone” at the top, which is actually a composite made to look like slate, does not fully cover the top brick. So it’s possible water is coming in from there and seeping down ten rows of bricks and then getting into the window that way. Seems impossible to me, but the window company have shown me that the screws fixing the top of the window into the brickwork/lintel from underneath the opening where the window in question is are all rusted and their position coincides with where the water is coming in. It’s not a huge amount of water, maybe 20ml a day since a few dates ago, and only after quite a bit of rain. Other possibility is lack of drip profile on underside of brickwork where window opening is, but architect assures me this is not required for brickwork where the joint between the brickwork and the window is sealed with mastic sealant, as is the case here. I guess the sealant could have failed??
  12. Yes, I think it must be wind driven rain because the window itself is under a slight recess in the brickwork that is almost 5cm, though I note with it was more. The installer is FENSA accredited, but that doesn’t mean they can’t try to exempt liability for what they will call consequential damage to the plasterwork. I will give them a call first thing in the morning. With another window, we noticed a draft shortly after installation and they came back and tightened a part which they called “the mushrooms”. I wonder if it’s the same issue here?
  13. Got home this evening to discover water ingress at our kitchen window. This, as with all our other windows, is an Aluminium 2G MetTherm casement window which was installed almost 2 years ago. A couple of the windows had problems shortly after installation, but these were fixed by the installer, the problems having been identified a couple of days after installation. The installer also supplied them, so there wasn’t any room for them to dodge responsibility. We’ve not had any problems since then. There appear to be various drips that have come in from the top horizontal seals, and possibly also at the vertical edge - difficult to tell whether the water at the edge came in from that edge or dripped down from the top edge. They are top hung. This is part of the extension, so everything is new and I’m wondering how I prove this is a window issue, rather than some other construction issue? Some of our (rather expensive) clay plaster has been ruined by the leak. Not much really, but enough to notice if you know where to look. I suspect the window company will have purported to exclude such consequential loss, and I can choose to either argue with them about the lawfulness of such an exclusion clause, or make a claim against my buildings insurer, or just accept the marked plaster.
  14. Yes, managed to keep the others from melting by drilling partly underwater (was drilling holes into ceramic pots). Not sure how I’ll keep it wet enough when I come to drill the tiles. They are also three times as thick as the ceramic pots!!!
  15. So finally got around to trying this out with a spearhead drill bit made by “Universal Fit” bought from screwfix. I took it fairly slow but clearly not slow enough as I managed to break the spearhead off at first attempt: I had my DeWalt drill on the greater torque setting of 2 (out of only two options, 1 or 2) and the other setting on 7. Created a lot of heat and only managed a 6mm depth hole before it broke!
  16. Yes, there was a fake rock grain that looked very realistic, and would have been a shame to lose it. So I’m still glad I spent so long fixing that mud-labelling error.
  17. I like my wine, and I like my wine fridge. But I’m not sure that makes me an expert!
  18. You will be stung with a customs charge. Vote Brexit!
  19. @DIY-builder-Dad you could certainly remove those rafters, and then the roof would fall down. Only way to do it really is with lots of steel beams, and that’s probably a non starter, because the house wasn’t designed for that kind of weight up there. If you really need the extra space: get a design for a proper loft conversion. I think it will cost minimum £30k… and then some. Garden room far cheaper.
  20. Not everybody is certified with Veissman to give you the guarantee. Search for an engineer that is.
  21. A Veissman might. Depends how big those UFH loops are, but a Veissman can modulate down to 1/17th of its maximum output. I have a Veissman and we don’t have short cycling issues - we do however have a low loss header installed.
  22. It depends how you spec your UFH. I specified thicker pipes, because I wanted a higher output system, and the possibility of possibly switching to a heat pump in the future. We laid very expensive insulated boards made by Cellecta under the first floor. I can’t remember what they are called, Xflo something. This has resulted in a response time of only 80 minutes or so, so if you’re at the airport and unexpectedly need to bring a guest home, you switch the call for heat on remotely, and by the time you are home you only need to wait about 20 minutes or so for the room to start warming up. We are fairly well insulated, so even in winter it’s rare that a room is more than 2C or 3C colder than we want it to be, so 80 minutes is manageable.
  23. See my previous post.
