Adsibob
    10
Everything posted by Adsibob
  1. I am having a cabinet/drop down desk being built which is about 67cm wide. The cabinet door drops down and forms a desk, and within the cabinet is our home PC. It would be useful to have an LED strip fixed into a routered out channel of the top of the cabinet carcass, which is 27mm thick. Can anybody recommend an LED strip that comes in warm white (I prefer 2800K but anything between 2800K and 3000k is fine) and that can be switched on by the cabinet being opened and switched off by the cabinet being closed? It would need to be around 60cm or 65cm wide.
  2. If by HPV you mean Passive Ventilation with Heat Recovery, I’m afraid I can’t help, as I don’t know much about it, or why you would choose it over MVHR. But plenty of people here have Mvhr and warm up their uFH pipes with water generated from green methods, such as a heat pump, supplemented by solar.
  3. Although their gutters overhanging over the fence is not ideal and possibly illegal (the fence might belong to them and be on their land, in which case as long as the gutters aren’t actually over your land, it’s perfectly lawful), this is not a planning issue. Now you have submitted, you might as well wait and see what happens, but if the planning officer gives you an incling that they might object or if you are asked by the officer to make any concessions to get approval, I would certainly make the following concession: I would move your property so that you are at least 70cm but preferably 80cm away from the fence. Not only does this give you a side passage, with helpful access to your back garden, but it will also avoid a boundary dispute with your neighbour about the gutters and give you space for your own gutters.I appreciate you already have access to the rear on the other side, but it’s helpful to have access on both sides for things like window cleaning and maintenance, clearing gutters etc.
  4. You probably only need ufh in the ground floor and, if you want that warm tile underfoot feeling, in the bathrooms. My house is nowhere near passive, but the bedrooms are well insulated following an extensive refurb and extension, and apart from our kids bedrooms, which SWMBO insists need to be 21C at night, we never have the heating on in the bedrooms. The MVHR is pretty good at averaging out the temperatures to an extent and imo bedrooms are best at about 18.7C anyway. So keep your ground floor slab warm during winter and your ground floor will be 21 and your bedrooms on the upper floors will get close to that.
  5. Says who? If the timber is treated regularly, it could be underwater.
  6. Other easier option is that it’s tear of pouring a concrete slab, you buy the plastic interlocking grids/trays. That will cost you about £120. Then you have the option of filling them with peashingle for extra stability/sturdiness, but it isn’t essential. You could just fill the grids at the perimeter or skip it altogether.
  7. It’s because of our neighbours’ trees and the deep clay, that the SE specified such deep foundations and that the BCO then increased them to something over 2m. I’m in very bad clay, the bbq is 1.1m away from a boundary line. I have no control of what is grown on other side of that boundary, so I based my ballpark assessment on the basis that the builder said 200mm and I thought, let’s add a bit to err on the side of caution, in the same way the BCO did. On reflection, based on the comments here I’ve clearly added a bit too much, but its future proofs the thing against any eventually, whether that be sustained drout causing shrinkage of the soil, or the neighbour’s trees growing even bigger. The extra 0.1m depth is an extra 0.144m3 of concrete, so extra cost but not extortionate. And given I will only have myself to blame if anything goes wrong, I just rather pay for the extra concrete.
  8. I’m plugging in a kit. So why did my BCO insist on footings deeper than 2m for a part single storey part double storey rear extension? SE had specified 1.7 and BC increased these to 2.2m from what I recall.
  9. Congratulations! I would wait a bit before raising it with the neighbours. Wait until all documents are online, and you’ve been formally notified. But you could start the process of appointing a PW surveyor in the meantime.
  10. Refractory bricks are very heavy. At least 25% heavier than a standard brick. But yes, there is probably a degree of over engineering here.
  11. assume that’s not an issue, because we can train the plum to grow away from the barbecue and onto the trellis on the nearby fence. Supposedly the one I have is not off the vigorous type. But maybe you are right and it’s safer to move it now whilst we still can.
  12. We are pouring a 160cm by 90cm reinforced concrete foundation for a brick barbecue we will be building. The construction of the barbecue will be single skin brick side walls and a single skin brick back wall up to about 95cm high (a U shape). Then there will be a 6cm thick reinforced cement platform and on top of that we will continue the three single skin walls with the same facing brick, but in addition add an inner skin made of refractory brick. That will go up to about 1.95m in height total, then we will buy a lightweight galvanised steel cooking hood and flue on it. The concrete platform will also be covered with a layer of refractory bricks. i estimate a total of 420 regular facing bricks plus about 170 refractory bricks. Builder initially advised 30cm reinforced foundation would be enough. But now he has asked about a nearby plum tree which I planted a month ago. I could move the plum tree, but I’m wondering whether I really need to. It is currently 1.2m tall and will grow to a maximum mature height of 2.5m (it’s a VVA1 semi-dwarf variety, known as a Plum (Prunus) Jubilee Bush). We are on London clay. The base of the tree is 1m from the planned location of the nearest side of the foundation. The root ball was only 30cm in diameter when I planted it last month.
  13. Ok, so almost a year after driveway V1 was finished, my trusty builders are back to redo it. Costing me an absolute fortune, but probably cheaper than couples therapy. Here is progress (of two guys) after day 1 (which started at 11ish and finished at 445): they have managed to take up almost half the setts. The rest will come up tomorrow.
  14. On window 2, I believe you tape the window to the 4 edges of the reveal, which will include taping it to the closers, using a thick airtight tape (probably at least 50mm wide, so there is 30mm on the reveal, and 20mm on the window. Then separate bit of tape to seal junction between cavity closer and inside skin wall. Then plasterboard goes on the left and right reveals, and the top reveal, whereas window sill board goes on the bottom. Window 1 should be simpler, as no cavity closers to seal.
  15. In the meantime, check out https://clay-works.com/
  16. I have clayworks clay plaster on my ceiling and it looks AMAZING. Our plasterer had never installed it before, but he watched a couple of videos and was able to learn on the job. I also have bejmat clay tiles on a large feature wall, and that looks pretty special too. I will see if I can find some pictures. I’m away at the moment.
  17. Going to try to re-engineer this for an internal depth of 530mm. Not sure why, but the joinery company has allowed 20mm thickness for the back piece. Wondering what the downsides would be of replacing this with 6mm oak veneered plywood? The wardrobe is quite big, 2m wide and 2.73m tall although that includes quite tall shoe drawers under the wardrobe and some overhead storage above the wardrobe. The wardrobe itself is 1.63m tall. Maybe the backing piece needs to be that thick for structural reasons? Could be attached to the plasterboard wall though.
  18. We are getting some bespoke wardrobes made up for our entrance hallway. Currently, the joinery company has proposed an overall depth of 550mm, but because the construction is very solid (these wardrobes will be very tall, floor to ceiling), once the oak veneered birch ply doors and the backs are factored in, the internal usable space will only be 510mm. This seems narrow to me. We would like horizontal clothes rails, but even ikea make their wardrobes 580mm deep. It’s all bespoke, so we can of course go bigger, the issue is that the bigger we go the more we narrow our entrance hallway. Will 510mm be enough to hang winter coats on a horizontal rail, or should we try and go for a bit more?
  19. Any recommendations as to what to look for - what makes a trap apparently “better”, as opposed to actually better which would only be determinable after years of leak proof service.
  20. 50 rolls seems excessive. I just taped all junctions with windows and doors, and the house is very airtight. I think I used about 12 rolls.
  21. The leak is back. Will speak to builder about this tomorrow. Worst case scenario, will the wet room need to be broken up and re-tiled, or can it all be redone via cutting into the utility room ceiling?
  22. So is it a case of asking the builder to put some sealant somewhere to prevent that 1mm of movement making any difference? If so, the million dollar question is where?
  23. Okay, so I did it, only for three minutes, but flow rate is pretty high, so easily 45L or so. No leak. Maybe it was that 1mm difference that caused some water to travel like this: The leak was pretty tiny, we are talking no more than 30 to 50ml of water after a 8 minute shower.
  24. Trying to bring the discussion back on topic, I checked the way I had reinserted the drain, and it’s possible I hadn’t replaced Everything exactly at it was; but at most we are talking about 1mm of difference. I pushed the drain piece down by that 1mm and have now been running the shower hose directly into the drain for 5 minutes, to see if I can recreate the leak. Nothing. Very odd. So either that 1mm difference in the position of the second item (the little 9cm tube) made a difference, or the leak is coming from elsewhere. I guess to see if it’s coming from elsewhere, I need to hose the edges of the shower area, and not just run the shower directly into the drain. But I’m too scared!
  25. Yes, my thought too. I think if the plot is big enough, you could make it narrower and shorter, but still achieve what you want by using more space from the back garden. The TV room and utility or plant room could also go in a basement.
