S2D2
Everything posted by S2D2
Last I heard they're all still variable tariffs so no fees for switching.
The figures I quoted here: Are from billed data from Octopus, i.e. it is the real life performance of the system. That allows you up to 16% losses whilst still being a "symmetrical" tariff - the seasonal shifting I referred to before. I had some comments about use case/costings here, I think I have a different view to many on what the battery should be doing on this tariff: Agree that AC batteries have even higher losses, so the maths would change for those.
Flux seasonal offset couldn't be working better here, I've just hit £0 net bills since joining in mid March - gas and electric including standing orders. I'm now building up a reserve to offset September usage. Average import price 21.73p Average export price 25.16p 8% of the PV/A2A ASHP investment repaid in those three months of Flux
Looks great! Good price on the slabs too, was that a local company or national? The planters are nice and low so won't affect the feeling of space at arm height which is good.
I'd also have Octopus fit the meter, might be worth enquiring with them what the lead times are in your area before switching though?
For those interested, I took another look at figures and clipped the data to where solar gain overtook heating demand which gives two months worth of data: Modelled gas heating demand for that period was 2662kWh Actual gas consumption was 640kWh The ASHP consumption was 372kWh That means every 1kWh the ASHP consumed offset 5.4kWh of gas This is likely to be accurate/an underestimate as I tried to push the ASHP for maximum gas offset meaning the house was on average 1°C warmer than the regression fit data 76% reduction in gas heating usage from a single multisplit unit Assuming a boiler efficiency of 90%, that gives an estimated CoP of 4.9, though this was in the March-May period so will be more favourable than mid-winter performance. Still, it compares well with the stated SCoP of 4.2 Even accounting for "lost export" on Flux's high rates, that means the unit has repaid 20% of its cost in 2 months (~30% of the heating season) - not bad at all No more data until the next heating period, though I'm interested to test the cooling performance over the summer.
The unit you linked is R32 so legally must be installed by an fgas installer. R290 units don't have to be, but the DIY unit I got has 1.5m of pipe on the indoor unit then a 3m extension. If the joint is internal it has to be brazed but outside it's just mechanical. Unsure if you can DIY braze an R290 line, someone else will know the appropriate regs.
To offset what, 31kWh of gas per day? Sounds like you need to limit the shower flow rates first!
One thing to note with this plan is that you would end up with an internal join due to the length of pipe, ruling out a DIY R290 install. If I had paid the heavy premium for a professional install (despite 0% VAT...) I would probably have gone the whole way with a multisplit. I do think you'll get short cycling with a unit that size in that space, perhaps aim for a smaller unit and run for longer. I'm no expert though, just a hunch based on what I've seen from mine. Summer lets will 100% turn on the air con, so that may also offset savings!
Yes compared to direct electric it's very good. You may find a humid climate slightly above zero worse for defrosting cycles, but even still the CoP will stay favourable compared to direct electric. This one is probably personal preference. I wouldn't want the internal unit on when in a bedroom, it's not quiet enough. More expensive units will be better I'm sure. I'm able to overheat the room the unit is in for most of the day when it's empty and leave internal doors open, which is the only way it can heat more of the house. There are still rooms it doesn't reach, hence the boiler still being on. If you can't overheat the central space I'd be very worried about a 7kW system cycling too much, depending on heat loss/size of the space. The other obvious disadvantage is if you choose to shut a door to a room, the room will get cold. Long term I'm likely to fit an A2W ASHP to get stable temps in all rooms. The A2A will do the large room it's in and provide whole house cooling if required.
Some thoughts on the DIY unit here: I've been happy with mine and offset whole house gas heating with the single unit. It's been working very well in combination with the PV since installation in March, but hasn't had a full winter to test it to its limits yet, though we did have negative temperatures in March. There are downsides (see thread) but overall no huge catches, it will pay for itself.
No specific rattle, just if a hand is placed on the front panel the noise is notably reduced so I was going to stick some rubber on inside or something. I did find a loose screw in the box but none visibly missing, I will check when I open up the front panel but assume it was dropped and replaced. Like yours it's just about audible inside the house in the adjoining room to that wall but far quieter than even the wet central heating so no issues at all from that. I did wonder whether a ground slab and rubber feet would have been better but it's not close to audible enough to make me change anything. Spacing the rubber feet that make contact with the wall out a little so the rubber doesn't contact the bracket and overall levelling the outdoor unit also notably reduced noise.
Looks good, it was beyond me why the supplied insulation left a load of exposed pipe, I also slapped some offcuts on to at least cover it but it was performing so well I've never got around to doing anything more significant. Does your front panel of the outdoor unit have any resonance? I'm still meaning to stick a damping panel on mine as it has a tiny bit but again never got back to it, it's tucked round the side of the house so never an issue.
https://www.visualcrossing.com/ is quite good, also has hourly data. There's a daily limit to the amount of data downloadable for free accounts.
How does your garden grow?
S2D2 replied to recoveringbuilder's topic in Landscaping, Decking & Patios
Given these are designed for hot drinks I'd be surprised if they compost quickly, I'd definitely remove them before planting. -
Coil whine? Not everyone can hear it. Up to manufacturer/installer if they consider it a fault depending how you bought it.
Thinking about this also and I've come across a few paver sets that are designed to be laid 3.6m deep, so I think that will be a good size. How tall will the planter walls be?
Carry on and remove them when you're ready to connect up the pipes. I just attached the extension and coiled the excess behind the unit, the adaptor would be a neater solution though. I presume you would have to release some amount of charge though as it's designed for the length of pipe. Manual tells you how much to add per metre extended, but that sounds too tricky for the opposite (kit required). No idea what the impact of an overcharged system is.
I could be wrong, but I think you're looking for EN 14825. There's a decent explanation here: https://www.varmepumpsforum.com/vpforum/index.php?action=dlattach;ts=1505933467;topic=65119.0;attach=49952 An average year is binned into temperatures which gives a good agreement with lab test data, I was pleasantly surprised with how accurate it should be. There are quite sweeping climate classifications (average, cold, warm) but it seems to do the job. It's calculated from lab testing points, so I believe it would be performing weather compensation in those conditions yes. Caveat this entire post with I've never actually read EN 14825, I just thought it was interesting when looking at A2A manufacturer claims.
Just in case anyone is doing these sums, I'm not sure I agree with the logic here. You have to have a battery to be on Flux, so your next best bet without a battery would be Octopus Outgoing at 15p/kWh. That means every bit of export is worth 8p more, regardless of inefficiencies. This is the "worst case" benefit - as if you bought the battery but aren't actually using it other than for the higher daytime export rate. Based on your 23p export you look to be in Eastern England so are paying 34p for import. You would actually charge your battery in the cheap period 2-5am, so for 20.4p, or 22.7p after 10% losses. Everything you import to battery to offset usage (outside of PV generation) therefore saves you 11.3p. This is better, but not a likely use case for summertime Flux, as there is plenty PV to charge the battery without taking from the grid. Therefore in summer, your usage for the battery is shifting from daytime export (which without the battery is 15p/kWh) to the peak Flux export window, 36.6p for Eastern England. For each kWh you shift you gain (36.6 - 15) = 21.6p - by far the best return on battery usage. As an added benefit, you also get +21.6p for any generation in this window, but again you have to have the battery to be on Flux. This is what I believe to be the intended use case for Flux, Octopus are running an experiment where you are paid to load shift the National Grid a tiny bit with your battery, and so pay you a higher export rate for that service. I'm not arguing that batteries are green, or worth investing in for Flux alone which can disappear at any time (it's a flexible rate tariff and Agile Outgoing is already averaging about 9p/kWh) - I just wanted to highlight the sums are a little more complex, 8p/kWh is a long way from 21.6p/kWh, the actual value will depend on your individual usage and lie somewhere between the two (in Eastern England, other regions have slightly different rates). Winter is also a very different story due to the peak import window, I haven't done the sums on this but I don't think Flux will stack up well for winter when options like Cosy exist. I'm also a firm believer that installers are oversizing batteries from a ROI perspective and consumers shouldn't be dragged in to this when a small battery will gain 90% of the ROI benefit. Mine is 2.8kWh usable capacity.
PVGIS: https://re.jrc.ec.europa.eu/pvg_tools/en/#MR Nothing wrong with that pitch, PVGIS will show you the generation which you can compare to South, probably less of an impact than you were expecting. West has the unexpected benefit of pushing more generation into the peak flux export window, if you're installing batteries too.
You can, but only by storing the heat in the house (i.e. overheating it). It wouldn't be worth trying to store it in the porch as there is so little capacity and the losses are huge when the sun goes down. I use a conservatory in this way if heat demand and sun intensity are both high. Open the doors and let the house heat up to 24 then close them. It's up to you and the thermal behaviour of the house as to what you consider a comfortable maximum.
System sizing based on actual consumption - a better way?
S2D2 replied to JamesPa's topic in Air Source Heat Pumps (ASHP)
It's by far the least significant of the three but had enough of an impact for me to leave it in. If I get around to the known airtightness issue jobs I imagine it would become even less significant. Good airtightness and insulation would see it removed entirely as an input variable I imagine. -
+ @SteamyTea It doesn't really matter for calculating peak load but for interest I was able to get a much better regression fit by adding the following variables to a multivariate regression: Solar energy Temperature delta HDD*Windspeed R2 = 0.93 -
What would you do differently if you could do your PV install fresh?
S2D2 replied to Gill's topic in Photovoltaics (PV)
Yes, 3.68kW if you go the G98 route. Back on topic, the one thing I'd change is to go G99, there are a few more fast track options now which let you get to 7.36kW which would save some complicated battery management I've set up to ensure capacity remains for excess PV when the inverter is running full whack. Ask the DNO early, no point putting 16kWp panels up if they say no to anything but G98.
