Roys
Roys's Achievements
Regular Member
Regular Member (4/5)
57
  1. I went with 20mm overhang, and edge handles, worked out perfect, I like it.
  2. Are you across the water in Stranraer end of this week, I am and you are welcome to borrow my mag drill.
  3. I did my apprenticeship at the start of the 80’s 1st year of which covered a broad range of skills including arc welding, I was fairly decent at it. Fast forward 20 years I bought a welder, got a lump of scrap steel and away I went, my welding was rubbish, spoke to welder to ask what I was doing wrong, and he echoed what was being said on thread. Steel ain’t what it used to be, gone are the days of top quality British Steel, mostly from China now with all sorts of strange lumps in it. He gave me a couple bits of decent steel and my welding was much better.
  4. Used to be a MK man but not for about 15 years, Scolmore Click now, have had only one failure in 15 years. Nice extensive range and a nice shape to them.
  5. Not much 110V on sites now, even vacuum cleaners are mostly battery, sds drills fairly much battery from about 5 years ago, drills and impact drivers have been battery for a long time, as said above the only 110V stuff you tend to see now is big chop and table saws and demolition type Kangos..
  6. Looks proper, I do like a bit of unistrut
  7. Something I have always had is decent first aid kits and have had to use them on myself on a few occasions as I have had a few injuries over the years,
  8. I bought a house 15 years ago, it had been built about 10 years previous but was never signed off, my solicitor had to get a “letter of comfort” from the council, I’m afraid I don’t know much more detail as I just let the solicitor deal with everything. I dare say a lot depends on the council and the solicitor, Scotland as well.
  9. Will pre collapse be a concern when he is using galvy trunking @TonyT ? i will using galvy 2x2 or 3x3 in garages / workshops, usually come of it with 20mm plastic conduit down to sockets and switches.
  10. Whenever I use GP I tend to keep my dog away from it for an hour, as said above the council use it liberally along all the path edges, no warning signs etc so I presume the risk is low.
  11. The couple did well, they put a lot of effort into it rather than paying lots of people and they did a quality job in my opinion. Like it.
  12. That looks fab.
  13. It’ll be easy, just make sure you either roll the drum to get the cable off or elevate it so that the drum spins, if you have the drum flat on the ground and not moving and you just start taking the cable off you will end up with a nest like slinky coil tangled mess.
  14. Is it going in a trench or through the building fabric. if in a trench just roll it out out along line at side of trench. If through fabric of building I would use a short scaffold pole and a couple of car axle stands, with a spare bloke stabilising it all and helping unwind it while you take the loose end on its travels.
