Everything posted by Pocster
Rental . Smoke alarms are interlinked and have no control panel . Honeywell control panel is just for the 4 call points ( still want to call them break glass ) . Randomly it will show a fault on one . Panel beeps to alert you . Enter code , cancel beep , then reset panel and ‘fault’ disappears There are only 3 components here ; panel , all the call points , the wiring . I’ve been told a ‘load resistor’ can be put across the call points to prevent it showing a fault . The supposed call point that fails appears to be random also . This resistor doesn’t sound particularly appealing to me . This ok though ? . Panel can go weeks or even months with no issues . My only other solution was new panel and call points . Then if still errors must be the wiring .
Can 100mm block walls be built on top of beam and block
Pocster replied to Boyblue's topic in Floor Structures
Gave you a ‘sad’ for that - because it’s the type of thing I would have posted . -
Gutter mate for the win !
Some of these diverters come with a flexible pipe to the tank . The photos suggest the down pipe fitting is higher than the inlet into the tank . So it will fill ok with rain . But I see quite a few comments relating to tank overflowing when full rather than back into diverter and into down pipe . Just seems a bit unclear which systems work ( assuming installed correctly of course ! )
So you get these things that connect to your down pipe to fill a water butt . Unless you add a seperate overflow it would seem the tank will overflow once full . I guess if you get the height / level exact it will fill on rain and not overflow when full . Seems a bit hit / miss . What about a diverter from the down pipe and an overflow back into the same down pipe ?
Invest in pocsterAI ; it’s the best . Not a (expletive deleted)ing clue , doesn’t ‘lie’ just doesn’t get the facts ; won’t kill humanity. Be on Dragons Den soon for Deborah meads questions yr 1 : profit (expletive deleted) all yr 2: profit 12k yr 3: profit 100 billion 10% of my BS company for 10 million
So...I'm about to do Rainwater Harvesting
Pocster replied to mike2016's topic in Rainwater, Guttering & SuDS
Out of interest are you going to ( able to ! ) get in there and suck the sludge out ? -
You've said that before haven't you? -
I did Uncle Nick.! PV, battery, then more PV and another battery. With my EV ( admittedly low annual mileage ) my ROI is around 6 years from when first installed. If we have a stellar sunny summer I reckon I won't be far off break even this year. -
I originally was going down the route of rwh . Even got a non return valve put in at the request of Bristol water . Guy came out and actually told me it probably wasn’t worth it ; his reasoning : maintenance / replacement pump suggested not using it for toilets as can stain ( so some chemical agent needed adding to the stored water ) So use for what ? Watering the garden ? - that’s about it . With the purchase costs of a tank etc I just couldn’t get any sensible roi . So dropped the idea . As our water is metered it is relatively expensive , but even if I did install and used for garden , toilets , washing machine - I think savings would be minimal. -
Or this ??? I want to toggle 240v on each relay https://hobbycomponents.com/lora/1190-longreach-lora-4-channel-digital-tx
Hmmmmmm to find a relay resorts to AliExpress - always a flip a coin and hope ; this maybe ? Are all Lora devices compatible with all hubs ??
I was reading about someone that bought a Lora based sensor and didn’t know they needed the hub . Been working by magic apparently for years ; not on their WiFi or Bluetooth or anything else . Recently found out it had connected to a Lora hub 5 streets away 🤣🤣🤣🤣🤣
Lora !!!!!! Yolink New toys ordered ! 1/4 Mile range …. 🙄🙄🙄🙄🙄🙄🤔
Cooooorrrrr - that’s at least a few days work !
Yeah ; it gets used rarely in winter . But I ordered anyway ( peace of mind ) Then it’s also another “ job “ to fix it ( 10 second jobs can turn into half a day for sure ! )
I have an outdoor tap also so should do the same !
I was thinking this also . But then I drank some 🍷and thought (expletive deleted) it
Interfaces to home assistant ? What does it generate on activation ??? Concept sounds good …. reviews seem not good . A battery I change once a year or less is fine . My problem is WiFi and zigbee at this point is poor / shite
I’ve got an ip camera that can see it - too many false triggers as I walk past it to enter my abode
Still got to run 20m of cable . I’m a lazy (expletive deleted) ; that’s all under my decking
Bast’s - I knew it would be like that
Not for sale to Germany apparently… why ? Not a musk nazi device is it ? 😆
Needs to be a (expletive deleted)ing big parcel to move 10kg of meat
