Everything posted by Pocster
Just be careful with the direct from China ones . Can be hit or miss . But considerably cheaper . Now though I buy from Amazon deliberately so I can return it with reason for return as “ is crap “
I had to supply an epc to my mcs accreditation installer . It was a requirement. Which I assume the installer sends something into the grant scheme . Installer said it was required for the grant so didn’t query it
Actually just googled it - for boiler upgrades it is 7.5k . I was referring to new builds I think
Unless it’s changed . Plenty of posts on here where we all got different amounts based on how ‘bad’ our epc was .
I meant you’ll need an epc to qualify for the grant . The lower the epc the more the grant will be . But yes must obviously meet min regs .
You’ll need an epc also . Best to get this as low a score as you can 😉
Ups for home assistant is a good idea . Also as you say if a device fails I.e becomes unresponsive you can get your automation to do something else ; at least send a notification of the issue .
Yes
The steels are behind a 30min rated ceiling . This I think is what convinced him .
I think it’s rather a lot of nonsense in a domestic . Fireman getting tangled in cables so needs a cable tray - hmmmmmmm . Massive rsj not fire resistant? . How hot is the fire ? Burning for how long ? - until it fails . Going to be quite a wait I think .
No no no . You play with HA to avoid doing the build . Trust me on this 😊
Are we sure that it’s not its own proprietary WiFi signal ? . E.g my somfy blinds operate on 433mhz and therefore a bitch to HA .
This type of thing is quite easy in HA . I did have a quite complex thing running but it just kept failing . So “ Alexa play a random album by Coldplay in the kitchen “ My local music library was used ( no Spotify shite ) - would choose a random Coldplay album and play it on my music system ( raspberry pi to powered speakers ) in the lounge . It was awesome - for the record you could obviously say ANY artist in my music collection . So I need to look at that again once their Alexa variant comes out . I did have working temporarily when I go downstairs in the morning ( based on my having my phone ) . Alexa asks me without prompting “ do you want the radio on ? “ . An answer of yes did it . Stuff like that is a bitch as you need an Amazon developer account and is a royal pita . Not reliable ! Also of course using Amazon cloud based spies !! Soon all that and local !!
Sending stuff to China ( or wherever) is becoming more of an issue . Home assistant is all local . Also they have been working on their own Alexa type hardware . So you can have voice control without telling mr.chim all your details . BTW - it’s me that’s been monitoring your Alexa ; I have all your details and PIN code . To prove it I’ll empty your bank account . You ready ? . Here goes ! Done ! Ah (expletive deleted) ! Your account was empty anyway ! 😊
Final certificate received!
Pocster replied to Thorfun's topic in General Self Build & DIY Discussion
VVv -
Well done ! Just like to add I beat you to sign off ! 🤣👍 -
Yeah . I’ve seen plenty of photo of burnt out Shelly’s / capacitors blown . They claim they didn’t overload it . My experience was a dimmer relay ( in a ceiling void so lots of airflow ) powering some lights ( max 20w - relay spec much higher than that ) . After 3 hours the Shelly shut down with overheat warning . Yet too see a zigbee or zwave device ‘panic’ over that . So I removed it . I only use Shelly’s for simple on/off ( so not on for long periods ) and where I have no choice I.e WiFi signal strong but zigbee weak .
This would be a nice easy and cheap way to automate. Personally I’ve not had good experience with Shelly’s .
This is the thing . What starts off as just a few lights on when you enter a room becomes ; control the heating , control music , alerts from cctv etc etc etc I would certainly try home assistant ( it’s free ) on maybe your laptop ( so no dedicated hardware ) just to test it and see . It’s a steep learning curve for more complex tasks though .
Going round the houses (literally!) on design…
Pocster replied to CaptainDram's topic in New House & Self Build Design
Go underground my friend …. -
Yep . Any Linux hardware will do it . Depends how much you want to do …
Mvhr funny noises and dripping
Pocster replied to Pocster's topic in Mechanical Ventilation with Heat Recovery (MVHR)
My current issue ( until the 2nd trap arrives ) is the heat exchanger effectively leaking at the base and coming through the front panel . Will test the trap problem ( and potential ) suction issues soon . -
Not being rude - but an architect should come up with something better for your needs . -
CT1 and/or Sikaflex for a shower tray installation?
Pocster replied to MAB's topic in Bathrooms, Ensuites & Wetrooms
I also used flexible adhesive to bed my stone shower tray ( weight around 100kg ) . Not going anywhere . -
Still leaks from front around this point circled . Managed to tip the entire until back a bit more . Also squeezed a plastic wedge under the front of the heat exchanger to allow it to tip a bit more . Front design here seems really poor - a tiny 1mm lip and the base felt sat in the middle of it which clearly soaks the water up .
