Pocster
    29
Everything posted by Pocster
  1. Leave your hole alone!
  2. You probably could! Can you make it all elaborate and fancy so SWMBO thinks it's mega and 'custom' !!?
  3. Oh ffs ! There aren’t any rimless ones ! It was a pig to get in because the access to move it was only available from inside the ensuite hence the positioning ! @Mr Punter gets the blame again ! . It was fine where it was before for a vent cover ! ???
  4. Yeah - I said that ? It won’t fit . So ! I might cheat . The ‘cap’ fits in the mvhr pipe with no over hang so I could use that with some holes drilled in SWMBO will never know ! . Or see if ‘rimless’ ones exist ....
  5. I’ll say you did it !
  6. I’m sure he will . I think every plasterer I’ve met moans . Even with a completely clear wall that just needs skimming . I think they only like easy jobs ...
  7. Ensuite done . Used twice as much plasterboard as I should and 1000% screws more than necessary . Do I or the plasterer fill gaps etc. tape joints ? . I assume I leave it now for a professional to sort . Before anyone says - the mvhr vent is on the piss ( but I can cut flush ) - though the vent cover will be an issue as it will be trying to sit on horizontal and angled ceiling ( blame @Mr Punter for making me move it )
  8. Sigh ! Removing screws ..... ? Nah !
  9. Yep it will be nas 2 a copy of essential files from nas 1
  10. My penny advice whether plasterboard/ timber - anything . You can never have too many screws in . If in doubt add more . If still not sure add some screws . Not confident yet ? - perhaps it needs more screws . @PeterW that’s exactly the type of professional curve I’d like !
  11. Was going to have 4 drives as shr - as it allows a failed drive to be replaced with any capacity drive . Drive 5 will just be nvr ; no raid . Any important video stuff I would copy off to the raid anyway . Of course for our younger viewers ... “A raid nas is not an alternative to a proper backup feature “ . I’ll probably copy valuable data off the raid to another raid drive ( cheap 1tb type thing )or usb drive . In turn will all copy off to a usb stick . So to lose everything would require 4 drives to fail in nas 1 . 2 drives to fail on nas 2 , usb drive to fail . Usb stick to fail ??
  12. I was going to take the diagonal higher then changed my mind ! Hmmmm ; think I’ll take the diagonal down and the horizontal . Put diagonal back up . Be easier to get the horizontal to be near flush with the diagonal then . Photo’s to follow of attempt 2 !
  13. Started on the ensuite ceiling . The ceilings angled where they meet . This ok ? ( apart from timber bit showing - will cut a bit to fit in there ) . Will a plasterer get over the ‘step’ ? Also I read that apparently he can curve the join between horizontal ceiling and angled ceiling . Assume this looks better ??
  14. Been trying to find a decent wall mount for the ipads . Avoided Bouncepad as way too expensive . Anyway after a few cheap punts I.e tacky ;went for it . ?? Ridiculously overpriced but it is quality . Trying to get power and Ethernet to it might be tricky . The arrangement I have using poe works but of course won’t fit in the case . Lightening female to Male extension ordered ....
  15. Don’t need any VM stuff yet . So Cctv recording and file sharing being its main function . Full report soon ?
  16. The thing is with this and everything else with building a house you can go round and round . Reading , asking questions , then reading more ! . Eventually you have to purchase . I read up on those nas reviews last night ; watched some videos - so at some point gotta put your money where your mouth is ! Will report back once setup
  17. All help appreciated Clicked the basket and went for the 1019+
  18. oops! Wrong piccy!!
  19. Or! Save some cash and just stick 5 RED hdd's in there and let the nvr do it's best!
  20. Certainly appreciate any input on which drives for nas/nvr parts - not capacity just recommendations. Been looking at broadband buyer for info/prices
  21. Think I'm leaning back to the 1019+ My plan was 4 drives for NAS allowing for upto 2 drives failling simultaneously. (so shr) 1 drive just for cctv (purple drive) so continually recoding ( so basic ). Is 1 drive likely to be a problem for 4/5 3MP ip camera's?
  22. You need to ssh into it . See how busy it is ( or is not ) . Presume you just have it on a timer plug to automatically reboot ?
  23. Ah @ProDave ! . A Mac will run and run ! I’ve had pc’s with camera software and even the software has the option to reboot the pc every 24 hours ! Not sure of your issue with raspberry pi . Mine at home has been on 12 months no issue - depends what’s on it . I use just max2play - it’s super solid for my audio needs . With my HA I might setup a reboot for the Mac every week or maybe shutdown all raspberry pi’s at night for example . Incidentally max2play gives you the option once you’ve set it up that no SD writes occur . So promptly powering off without shutting down isn’t an issue .
  24. Your routers on the entire time . That’s a dedicated cpu . Maybe you have a NAS on all the time . The consumption of a Mac running home automation software isn’t taxing ; so wattage is very low .
