Pocster
    29
Everything posted by Pocster
  1. Pocster
    Esp32
    Getting more complicated Can’t have transducers more than 1 metre from screen . So transducers will need an esp32 to send data via WiFi for other esp32 with tft to pick up 🙄
  2. I think if I do that it will look autistic rather than artistic ! Another issue . If I do stick a water butt to the left the overflow can’t just go over the soil so I should put into the main drain ?? Theres a small access chamber nearby ( photo tomorrow ) so overflow say mdpe buried in ground and drill into side of sewer chamber ??
  3. Pocster
    Esp32
    I usually do . But esp32 for embedded stuff ; no power off issues I.e memory card corruption . Even smaller and lower powered . Oh and cheap , real cheap .
  4. Pocster
    Esp32
    Come on guys ! Esp32 ( especially s3 ) is awesome ness !
  5. Bit stuck as to best route here . Want to tap off the roof guttering in the top right . SWMBO not keen on a visible pipe . I can run on the wall or on the copings ( look shit ? ) , or straight down to a water butt . Any other suggestions ? . Best place is yellow/ green route as tank can be out the way . But it creates a visible pipe .
  6. Pocster
    Esp32
    Ummmm , sorry , missing the engineering ‘thing’ here
  7. Pocster
    Esp32
    Decided building a house and fixing leaks is a bit boring after 10 years . Like HA but hate shite like yaml . esp32 through visual studio with platform io and C !! Awesome ! Proper stuff !! So 1st ‘work’ is a water level monitor in the automated watering system tank. Tft display with animating water and percentage full ( got chat to write the code lol ) . Controlled via Alexa ; but default run time can be overridden via a http request by speech . Lvgl for the rendering etc . Ultrasonic transducers to measure water depth Awaiting parts to arrive . So (expletive deleted)ing cool … Come on you other nerdy types - you must be on this also !
  8. (expletive deleted)ing rubbish this website
  9. Ok , ok . You wonderful people … keep on topic otherwise you’ll feel my tip !
  10. One hot , one cold . Choices , choices ….
  11. Right ! As acting mod - can we please keep on topic 🤠
  12. I know the feeling big boy 😉
  13. I think it would probably just be the mistresses bedroom
  14. Maybe a floor unit? . Usually cheaper . Still got to create a vent hole through the wall either way
  15. I’d like it on record @Nickfromwales whom started this degrading dirty talk . Yet has he been banned for a month like I suffered ? , no . I think a month in the wilderness will be good for him . @Onoff suck on that fella !
  16. Yeah I read that . I have tinnitus so noise probably not an issue . Split system better ? ( not just cost ) . That’s not just plug ‘n play though is it ?
  17. You’re such a dirty (expletive deleted)er ! . I can’t double use the glory hole for air con can I !
  18. Yeah - knew I’d end up here eventually . So I’m looking on just 1 bedroom for now . I believe a mono block system ? . Plug into a socket , 6cm hole through wall ( 2 hole system better I believe ) ; job done ? That simple ? , any advice or recommendations?? ta !
  19. Oh yes ! You have got a massive surprise coming !
  20. That’s really rude. I’m quite offended . But it’s Friday ; so don’t give a (expletive deleted)
  21. Yeah it is just an open or closed circuit ( the switch ) . Been fiddling and am indeed using pin 9 and pin 7 gnd and I think it works . Just noticed your diagram is different . Also just noticed I have the Shelly uni plus - so that could be the confusion
  22. Hmmmmm Not pin 7/8 and gnd ?
  23. Nah . Wire on float is 20cm - but will need to be much longer in real use e.g 3meters . Guess I need to wire it with ‘real world’ wire lengths aswell to test . I could get around this with software I.e switch triggers , alarm goes off , then resets after a minute ; switch as latched on won’t trigger it again . So a manual reset required - probably a good idea after a critical flood event has occurred .
  24. But why is it needed ? When the float is off - it’s fine . Activate float , Shelly uni shows ‘closed’ on dry contact . Which is correct . Why doesn’t resetting the float ( open circuit again ) not cause Shelly uni to see that ? as it’s a dry contact .
  25. Yeah and ? . It’s a dry contact;
