Pocster
    29
Everything posted by Pocster
  1. Supplied like that I should add !!
  2. Quick phone call to Merlyn ; apparently the seal is around 15mm for the edge ! . Guess I’d better find it !! ?
  3. Confused ! The sliding door stops are in the rail - their position can’t be adjusted . Closing the door causes this gap due to the top door stop ?
  4. These are hard to install on your own ! Also I’m about 1mm out and it causes issues !!! . No one will notice of course ! apart from you gits because I’ve said so ?
  5. Can’t ct1 another bit as it has a spring clip that would get stuffed !!
  6. Backlit leds on the vertical profiles
  7. Can’t get fitting screws in !
  8. The top piece Nice edge and other end , cut by blind left handed man . Bear in mind I filed it a bit better !
  9. Though the glass corner has a bevel it is dumb it pushes so tight on the cable
  10. What a complete &@&&& Panels bitch heavy . Have to cut the top of the fitting to gain 1mm Did it dry . Been gently tapping it in with a rubber hammer . No way am I taking it out . So no ct1 under this horizontal edge . It would just push up and cause more of an issue . Will ct1 then silicone the inside bottom edge once all done . A complete bitch !!
  11. Merlyn aryston shower cubicle going in .
  12. Little bit expensive
  13. Just call them up and sweet talk any terms you want
  14. Ok . You’re going to get banned
  15. Video footage would be priceless
  16. See now that's why I need a video doorbell with 2 way audio. So I can tell her to (expletive deleted) RIGHT OFF!
  17. That's sexist and against forum rules. I'm rather shocked and offended by your blatant disregard for the female form. Send her round
  18. Many many ways! I can open motorised locked via HA ( app or web based ) . Currently door has finger scanner ( though it's broken at the moment!! ) When working! - triggers a relay that homeseer can detect which in turn triggers a fibaro relay on the lock The unifi access reader pro does sound promising. But as you said some 'features ' don't exist yet. The thing that hacks me ( like ring ) is the subscription and also the video/audio isn't accessible too me i.e. propariatory . Doorbird stuff is accessible. Therefore integrates with blue iris which in turn integrates with Homeseer. Though it's way to expensive for a bloody video doorbell - I *think* door bird is the way to go - tempted to push the button on a purchase! ( did also look at arlo, arcrest etc. etc. )
  19. I can deal with the door lock mech via HA. Looking again at Doorbird. Seems the best off the bunch but at a cost!
  20. I see so it’s a Wi-Fi link to its storage box . Hmmmm - that’s a bit pants
  21. What do you mean by this ? I know you stick and SD card in it . I’m hoping it’s just seen as an ip camera so I can access RTSP or http feeds
  22. Do you mean when you are not at home ? . I guess I’m asking when you are at the actual property are notifications etc . Faster ? - or does it make no difference as all cloud based ?
  23. Also looking at https://uk.eufylife.com/products/T8200?utm_source=google&utm_medium=shopping&utm_content=&utm_campaign=uk_security_pla&utm_term={8780607502}_{95356673184}_{410387765729}&gclid=Cj0KCQjw38-DBhDpARIsADJ3kjlpBfUNjGOi5IhDSbMAEwM6Iq20XhjIrsG2P1Tg1lknv5AK5fRDUFAaAifwEALw_wcB
  24. Yeah I’m going to move away from Synology surveillance station - blue Iris was on my to do list .
