Everything posted by Pocster
Plumbing: logical? Naaaahhhh. So how the Hell do you ....
Pocster replied to ToughButterCup's topic in General Plumbing
Back in my van now 🚐 -
You’re going to finish this ! - unlike @Onoff
@ToughButterCupafter 2 years must have your answer ( he didn’t tag me 😁 ) -
I know exactly what you should do , it’s easy . But because you didn’t tag me I’m not going to tell you ! Darn ! I’m 2 years to late ! -
That’s because the man in the attic left
Yes agree with the Gxx requirement. Just suggesting that exporting isn’t the be all and end all - though clearly the system needs to be installed with compliance.
Tbh if you plan a battery soon ( ish ) the export rate you are permitted becomes far less important. I can only export 3.6kw but I can store 23kw . Initially my plan was to export everything I could ; now it’s to store everything I can . Export rate is pretty poor ( 4.1p kw ) - so better to store .
“ My wife swapping “ …. 🙄
New series of Grand Designs 31st August 2022
Pocster replied to Thorfun's topic in Property TV Programmes
As you know @Onoff - if it was easy everyone would do it . Why do something easy ? . Do something ‘ard ! -
But that’s all part of the fun . It shows to err is human 😁 -
And everyone on here 😁🤣👍 -
How does your garden grow?
Pocster replied to recoveringbuilder's topic in Landscaping, Decking & Patios
https://metro.co.uk/2022/09/16/oklahoma-lorry-full-of-dildos-and-lube-overturns-and-spills-its-load-17387874/?ito=article.mweb.share.top.email -
Lol ! We shall wait and see the “ my batteries in my basement caught on fire “ post … 😋
You’re going to burn to death when they over heat next summer ! 🤟
Oh what memories they bring back ! Do you remember the automated neutral analysis localiser I used on you ? ( for dumb asses that’s A.N.A.L ) -
I’m sure it’s bad practise , but ….. macerator pipe 32mm over a long run of 14m . Potential problem in the last 2m . Can I step the pipe ( 45 degree tee for example ) . Or if that’s bad use a reducer to say take it to 54mm then do the step ….. 🤔
UVC in basement plant room but no drainage for overflow
Pocster replied to Thorfun's topic in Boilers & Hot Water Tanks
I’ve got a 60cm wide and deep hole to break in concrete in an enclosed area . Swap jobs ? 😁👍 -
Seem to remember you guys noticed no tundish in one of my rentals . Job was all signed off and ‘ finished ‘ apparently. I got him back to add one though he was of course pissy for an ‘optional ‘ addition . It’s a safety feature so it’s mandatory ( not just rules but even in my own view ) . -
@Thorfun ; my view of these things is you HAVE solutions. Whether it's a pipe run or a 800 quid pump. Don't beat yourself up over a relatively small cost addition to the entire project. Currently as SWMBO requests (wants!) a basement WC ( which I didn't plan for ) is adding around 3k in materials ( macerator toilet and pumping station ). So you got off lightly! -
Same experience for me. Architect made no mention of the UVC needing 'overflow'. UVC installer did though. I recall ( it was a few years ago ) that he said pump - I pulled a face and pointed at the perimeter drain. He seemed happy with that. Though lets be honest a perimeter drain is plastic and isn't afaik designed to take boiling water. The only 'professionals' I found that would communicate ( because they have to ) was the architect with SE. This would usually result in an argument to a problem where they both recommend I install BOTH their methods. Needless to say I would simply choose what method I determine was best as I felt they were being A-holes and 'professional' pride ( not to admit the other solution was better by the other party ) was the issue...... -
It’s impossible to know everything in advance . As you point out your architect didn’t even mention it . Assuming there are no other possible routes then the only solution is a pump of some sort . We all ‘miss’ things due to lack of hindsight - I should know ! 😁 -
No chance of getting a pipe in the wall studding ? . Only need a slight fall . -
No sunken garden or basement patio doors ? . Just trying to think if you could get a pipe from uvc to outdoor but below ground space . -
So what’s your method for dealing with water potential ingress ? . I can’t remember the make up of your basement structure . -
Is there simply no pump that can cope with that ??
