MortarThePoint
Everything posted by MortarThePoint
Estimating how much gravel is needed. For 110mm pipe, the trench needs to be at least 410mm wide and the depth of the gravel at least 210mm including the height of the pipe or 160mm if ground suitable. That works out as 0.41m*0.21m = 0.086 m3/m or 0.41m*0.16m = 0.66 m3/m (ignoring pipe for contingency). Round that up to 0.09m3/m or 0.7m3/m. A bulk bag of pea gravel seems to be about 2/3 m3 so that provides enough for 7m or 10m of pipe. 7m or 10m per bulk bag. Does that sound right? 10mm pea gravel links: https://www.travisperkins.co.uk/bagged-aggregates/travis-perkins-gravel-and-shingle-bulk-bag-10mm/p/938182 https://www.jewson.co.uk/p/pea-gravelpipe-bedding-bulk-bag-AGSTB016 https://www.wickes.co.uk/Tarmac-10mm-Gravel-Pea-Shingle---Jumbo-Bag/p/131897 Osma: PolyPipe:
Neither Floplast nor Osma make a 22.5 degree bend in 110mm, but Brett Martin does: Single Socket: https://direct-drainage.co.uk/products/110mm-single-socket-22-5-bend-b5071-underground-drainage-pipe-fitting Double Socket: https://direct-drainage.co.uk/products/110mm-double-socket-22-5-bend-b4051-underground-drainage-pipe-fitting
Two 110mm into one 160mm
MortarThePoint replied to MortarThePoint's topic in Rainwater, Guttering & SuDS
Looking closer on site, the 160mm pipe is closer to the corner of the house than I thought, so I think I can use the setup below that looks pretty reasonable. May be better to use a 160x160x160 junction to keep all inverts level. I don't think I have to have the optional rodding access as the bends on that branch will be 30 degrees or less meaning I could rod the branch and the 160mm main section through the top Inspection Chamber (I.C.). If space allowed, it would probably be nice to have it after the lower bend and focused on rodding just the 160mm main section. Still interested how people would tackle the original challenge though, but that's relegated to curiosity now rather than necessity. -
It's just surface water from gutters and all below ground -
When they put in the drive and the rainwater pipe across it, the ground workers asked if I wanted a 110mm pipe or 160mm pipe. It seemed like a small additional cost to go with 160mm pipe. I now need to connect two 110mm pipes to it. They are coming in opposite directions each at 90degrees to the 160mm pipe forming a T shape. Rodding access on each 110mm pipe will be about 3m away via 4D960 chambers. Some options to connect are shown below. It's right at the front of the house, outside a bay window, so I'm keen to have something discrete. Using the equal tee (6D193) feels like a bodge, but a blockage here feels unlikely given the step up on pipe diameter. The two 6D198 feels less like a bodge as could provide rodding access, but doesn't have level inverts. The rodding access could go via a 110/160 reducer to decrease the size of the rodding eye. Floplast 6D900: mixed 160/110 chamber plus 2no 45 bends 6UR928: 160mm chamber plus 2no 45 bends or the naughty option on right where the central channel isn't used 6D193: 160mm 90 tee plus 2no 110/160 adapters. Feels like a bodge as no access but could add a second to the outlet with the branch facing up to allow access. Level inverts benefit 4D960: 110mm chamber plus short pipe, 2no 67.5 bends and 110/160 adapter Level inverts benefit SP230: A wildcard option is to use a soil pipe double branch and allow rodding access. Would need a short length of pipe and a 110/160 adapter into the 160mm pipe. I have one of these spare. Feels like a shame to have the combined flow in a 110mm section of pipe even though it would only be about 200mm worth. Level inverts benefit Polypipe 160/110 branch: allows rodding access via a 160mm 45 bend technically compliant down to 600mm depth I think Would prefer a ring seal version 6D198 or 6D218: two of these have the benefit of having 110mm side ports. 6D198 would need 2no 45 bends but have a smoother flow.
I tried disabling the DHCP server in the Router menu hoping that DHCP requests would make their way to the original router, but sadly not. It isn't obvious how to have it act as a switch. There is a Bridge option, but it says it only supports one device at a time and has to use mobile data. With it acting as a Router (inc DHCP server) I can happily RD to a machine on the other network as well as shared drives
For the two turns, I think I'll use Osma 4D960 plus two bends as I've identified a cheap source and didn't like the look of their 90 bend chamber (4D918) and the total cost of that was looking like £100+ each. The first corner can be achieved with a total turn of 2x22.5=45 if I bring the pipe out from the house at 45 degrees. Despite all being level invert, it says to always use the main channel rather than make the turn with the chamber's 45 inlet. I loved the look of the Polypipe SFA7 option but it's too expensive.
Made a few calls. Polypipe suggested that Bottle Gullies are the standard approach. Wavin (Osma) said it was down to taste and Bottle Gullies are probably the easiest and neatest. I said I liked the idea of hopper and rested bend and that seemed ok but may be less roddable. In terms of joining the main run of pipe, it's standard to use a tee, as long as the main run is roddable (ie chamber at is ends). It's looking like I'll go with an Osma 4D960 with 2x45 bends at each corner of the house, straight runs between those and then Y-tee branches to each hopper or gully.
Brett Martin's B2803 is a 90 degree 280mm inspection chamber, but the exits have a sharp 45 bend with the channel being straight within the inspection region. Osma's 4D918, on the other hand, has the bend in the inspection region. Osma have a useful selector, a copy attached. Slightly bigger though, 315mm vs 280mm. Here's some information about their Multi-Base IC range. The Osma 4D918 looks a bit silly from above, but there is a straight alternative (4D910) that could be used with 45 elbows. Even the smaller (250mm) Osma 4D960 could be used with two 45 elbows. Brett Martin B2803: Osma 4D918: Osma 4D960: F0026752_0001.pdf
That makes for an about 15,000mm * 1/60 = 250mm drop from the stack's rested bend to the tee by the 450mm chamber which has an invert of 600mm. That means the rested bend can have an outlet invert (600mm - 250mm) = 350mm below the surface. That works about perfectly to have the Floplast rest bend at the bottom of the stack (D571, dimensions below). If it was available in black, I'd consider having the collar sticking out of the ground meaning the invert could be at just 300mm below the surface. The orange stuff isn't UV stable and would catch the eye, but I guess I could spray paint it black if I needed to.
Banister / balustrade - optimum height?
MortarThePoint replied to Weebles's topic in Building Regulations
Looking at table 3.1 in Part K it looks clear that the minimum height for internal elements in a single family dwelling is 900mm. A block of flats however would require 1100mm as would an external balcony of a family dwelling. I just got spooked by a call with Richard Burbidge where they said I need 1100mm even for a singe dwelling. I checked with my BCO to make sure and he says 900mm. ----- -
I'll have to check my levels, but may struggle to get a rested bend in and have a good gradient as well (1:40). The longest run is going to be about 28m so 1:40 would need 700mm which may be optimistic even from the surface let alone a rested bend. Most of the run will be under paving so can be near the surface.
Gullies or traps are essential if the rainwater joins the sewage system. That's not the case for me as it's a separate system going to a drainage ditch. I have shoes for the bottom of my downpipes. Bottle gullies on first look seem like a good idea, but I have seen people elsewhere saying they aren't the right thing to use but with no clear justification. I know they can be expensive, but that's not the reason. I think it may be that the bottle gully would need to be right up against the brickwork, rather than having a hopper arrangement like Marley's UG47 which they proposed to use with a Marley UG44 trap (shown at bottom of this post). These traps aren't roddable and bottle gullies are in theory, but would they be in practice? If you have a branch (tributary) coming away from the house at right angle, I suspect the rod wouldn't be able to curve down into the trap's outflow and so it ends up unroddable. A different matter if you use an inline bottle gully, but that requires the pipe run to be close to the wall and I am keen to have a bit of separation (also need to go round a chimney outcrop). Perhaps putting the branch at 45 degrees would help with rodding access, but the ultimate access would be provided by an inspection chamber of access where it joins the main pipe. That seems over the top though. Is rodding access a red herring for rainwater as the blockages are local to the trap and not in the pipe sections? What do others think if the right approach? Marley UG47 and UG44: Looks like you have to solvent weld a length of pipe to UG44 since there's no rubber seal and anyway the outflow is higher. Toolstation's Aquaflow has a ring seal but that feels like tempting fate as it's still below outflow:
I couldn't find anything that combined a long range wireless bridge and WiFi access point / client into a single product that only takes a power connection. I didn't want the hassle of Ethernet to a wireless bridge at each end, so I've actually kind of done the opposite since I already had the bits: WiFi Range Extender with Ethernet port <--> 100m Ethernet Cable <--> WAN Ethernet port on a WiFi Router. The WiFi Range Extender with Ethernet port is a TL-WA850RE V6 by TP-Link and the WiFi Router is a 4G+ Router (B535-333) that I am no longer using for 4G. In theory, that could provide 4G backup as well, but I don't have a SIM in at the moment. Cost is minimal at £75 (£14 for TL-WA850RE, ~£50 for 100m of Kenable direct bury cable, £20 on eBay for the4G+ Router). Hopefully it won't get struck by lightening as I have just draped the cable along the ground. I think I could have a WiFi Range Extender with Ethernet port at each end, but I didn't have two. Manuals for TL-WA850RE if needed. 1910012385_TL-WA850RE_UG_REV6.0.1.pdf 1910013049_Range Extender Setup Help_REV1.0.0.pdf 7106508795_TL-WA850RE(EU)_QIG_REV7.0.1.pdf
Alternative Water Supply Connection
MortarThePoint replied to MortarThePoint's topic in General Plumbing
Good thought, but that won't apply as both houses have sewage treatment plants -
More straight forward with a private supply as I am sure it would be OK to share that. I like the idea of a borehole, but was led to believe it would cost around £20k and with ongoing maintenance/filtering costs. We have mains water o supply to the house which we are living in during the build, so it would be easy to piggy back off that -
Two relatively simple questions: Will Building Control sign off a house without a finished water connection? Is it legal to take the water supply from an existing dwelling that you also own? That second option is a possible short to medium term option that avoids the delays associated with the water company connection as well as possibly the cost if it became more permanent. I would be paying the water bill for both houses anyway.
Not so much. It's to connect between two buildings about 100m apart which is a common requirement (e.g. garden office, garage, workshop, barn etc). A good approach, but I have convenient mains sockets and not ethernet sockets. This must be a common scenario for the domestic market as most people have housewide WiFi rather than ethernet.
