Thorfun
Everything posted by Thorfun
Vaulted hallway
Thorfun replied to eandg's topic in Mechanical Ventilation with Heat Recovery (MVHR)
We have no supply or extract in our entrance hall (also vaulted) which was designed by another company. So sounds like it’s normal to not have MVHR in a hallway. -
I wanted something that could power the house in a power cut. Tesla Powerwalls had stupid lead times and so I went for a Luxpower Squirrel Pod with HanchuEss Greenlinx batteries the maximum 13A in a power cut is a little limiting but I’m planning to ask the sparky to wire lights and a coupling of emergency sockets to the EPS. but you’ll find that answer to your question depends on who you’re asking! If you read the threads in the battery forum you’ll get a good understanding of the sort of response you’ll get. 😉
No rings, we are going radial what are the practicalities?
Thorfun replied to MikeSharp01's topic in Power Circuits
these were exactly our thoughts and why we went one ring per room. that way if a room trips it doesn't take out the whole floor or any other rooms. -
why no rings? all our lighting is radial but our sockets are one ring per room so kind of a halfway house. seemed like a logical compromise to me and my sparky. -
Apart from the theft aspect isn’t it really expensive compared to other covering? We had some lead work on our roof and the rolls of lead were costly.
I’m confused. You want to use lead on an entire flat roof? Didn’t even know that was a thing
But then the screed wouldn’t cover the conduit and I’d still need a ‘hole’ deep enough to house the spotlights. Pretty sure the extensions were the only and best solution! Just would’ve preferred not to have to pay so much. Or that the wife hadn’t packed away the 3d printer.
ordered. to be delivered tomorrow. they're still stupidly expensive. thinking maybe I should've got the 3D-printer out of storage instead but too much to do and not enough time.
F*****g peer pressure. If I’m £25 short to finish the house I know who to blame!!
Definitely not! Penny pinching extraordinaire.
It’s funny as when I saw the price of £2.25 I thought, f**k that’s expensive. But when I wrote the total of £13.50 I did think “am I just being a real tight arse here?” 😂. I guess the answer is yes then.
Was going to but SWMBO has packed it away to make space for something else.
Sadly our screed level is dictated by our finished floor level so this won’t work.
evening. question for the sparkies out there. we have some conduit boxes in the floor insulation for ground mounted uprights. I need to find some extensions for them to bring them above the level of the screed. then I can put the spotlights in them after the flooring is done. I found these on Screwfix but they're metal. any issue with that? our conduit boxes are plastic angle boxes. I would need at least 3 of these to take it up 75mm. only problem with metal is that it's not as easy to cut level with the screed. I did see these at CEF but at £2.25 each I would need at least 6 (2 x lights and 3 extenders each) and so £13.50 seems a little excessive for what is simply a bit of plastic! which lead to another option where I was thinking of sticking some 50mm waste pipe as a barrier against the screed and that will give me a 50mm hole to put the lights in. and if I find lights that are a smaller diameter then I can put narrower pipe in to reduce the hole size. I hope the above makes sense! I can pop to the house and take photos if not that might explain it better.
I had a quote from Spectrum for Internorm windows. they were on the expensive side and more than another Internorm provider. but, as with most things, you get what you pay for! and a personal recommendation is worth it's weight in gold especially for a big ticket item like windows. sometimes it's better to pay a little more for peace of mind.
Are you with give an indication as to what ‘quite reasonable’ is? I do t remember reading anyone on here using this. Maybe you can be the Buildhub pioneer!
I don't have any in my house....at least that's what I tell myself.
not suspended ceiling like your office type ceiling. it will be a dropped ceiling that will be plasterboarded and skimmed.
awesome. 40mm through the B&B it is then! I can then make the decision as to whether to up that to 50mm at a later date. I was actually thinking of putting more than one hep2o pipe in the larger bore ducting! thanks for the tip on 45° bends but in this instance I'll just send them up vertically from basement to kitchen through the B&B. any bends will then be under the ceiling in the basement. the foam wasn't to reduce the noise of the pipes it was so there wasn't a hole going through from the basement to the kitchen so making noise in the room below/above won't travel through the ducting to the other room.
I was told that running horizontally isn't a bad thing, in fact it can be advantageous. if your board horizontally starting at the bottom you have the bottom board to 'rest' the top board on when you get to it. also when cutting for the bit at the end of a run it's easier to cut a horizontal board as you're only cutting 4' instead of 8'. it made sense to me! but @nod is the plasterboard/plastering guru around here so maybe wait for someone who actually knows what they're talking about to respond! 😉
ok, so I 'think' after re-reading the advice above I've decided to run 40mm through the floor. this will then reduce to 32mm at the sink. and then I can attach the 40mm to 50mm pipe for the run to the soil pipe. so from the sink it'll be 32mm -> 40mm -> 50mm -> 110mm. good, bad or ugly?
just remembered that up above @Nickfromwales said 50mm for anything buried. the kitchen sink waste isn't 'buried' but it'll be a pain at a later date to get to as it'll be above the ceiling in the basement. also, it'll be about an 8m run to the soil pipe from the kitchen sink. worth using 50mm? I'm thinking it might be.
his and hers toilets aside, I have another question....well.....more of a sanity check to be honest. Tomorrow I am putting down the insulation in our kitchen in preparation for the screed. our sink is in an island and so I need to run the waste pipe and water pipe straight down through the block and beam and in to the basement. the island will contain the following: Sink Quooker with Cube Dishwasher so I was going to run a 40mm waste pipe and hot and cold feeds for sink and cold feed for dishwasher (all 15mm Hep2o). Do I need anything else? Also, I was thinking of running a large bore pipe and putting the hot and cold feeds through it. that way I can foam the large bore pipe to reduce sound transfer between the kitchen and basement rather than drilling 3 holes for the water pipes. is that a stupid idea or genius? am I just trying to solve a problem that doesn't exist by running water pipes in their own holes? most important thing is am I missing anything to run now as it'd be a bugger to do it later.
New build in SE - MCS engineer says 22 kWh ASHP required....
Thorfun replied to Navron's topic in Introduce Yourself
Put your data into the spreadsheet that is available on this forum (a search for ‘heat loss spreadsheet jeremy harris’ should find it) and see what that says.
