Thorfun
Everything posted by Thorfun
ICF or Sips for new house in Scotland
Thorfun replied to Meabh's topic in General Construction Issues
our batten costs are high as we're having vertical cladding so need counter battens and they are 50mm x 50mm battens to allow room for the external blinds. all in all our timber cladding will be a very expensive item but it should be amazing! -
just a regular joiner (he did a friends Larch cladding and comes highly recommended and I've seen his work first hand so I know he'll do a good job). we had a huge amount, 230m2, and so we managed to get wholesale price which came in around Β£65/m2. so it's not cheap when you compare it to standard larch but it is cheaper than Western Red Cedar! at the moment though there is a shortage of Siberian Larch so you might want to hold off for a bit. π -
lovely looking house! your black timber cladding.....what are you going for? we're having charred larch and has it delivered the last week. it looks stunning and we can't wait for it to be fitted! -
The roofs, the windows and the solar PV array
Thorfun commented on Thorfun's blog entry in West Sussex Forever Home
we do very much! love the colour and the door itself feels very solid. I'm sure you'll love yours once it's installed. -
thanks guys. I've ordered some interior block filler paint for the block walls and some acrylic floor paint for the floor. should do the job and probably cheaper than plasterboard or ply at the moment! I'll update this thread once I've finished it for appraisal of my work. π but more seriously, in case any one else has the same question and wants to know how my solution went.
yeah. figured this would be best. is PVA enough to seal the concrete blocks or should I be looking for something a bit more specialised? plus underlay though, right? but, even so, with 5mm underlay it would still only be an 8mm step down in to the plant room. so, just paint the plant room floor sounds like the best and most cost effective route! π
greetings. our plant room is in the basement and we've had the whole thing (basement that is) screeded with Cemfloor liquid screed. There is 15mm throughout to put a finished flooring in so we're most likely going to go with LVT throughout the entire basement. But what is recommended for the plant room? should I just leave the screed and live with a 15mm step down in to it or should I put tiles down and have a small step up (maybe 5 - 10mm) in to it or should I put cheap lino...errr....I mean LVT in it just to keep it the same level as the rest of the basement? With tiles I'm concerned about fixing down in to it as I'll have to go through tiles and I wonder if spending money on LVT for a plant room is just crazy when I have a pretty smooth screed already. Also, the plant room is against the exterior wall of the basement so one wall is concrete (250mm thick) and the other 3 are dense concrete blocks. What would be the best way to cover these? I think the concrete wall should just be painted as it's pretty smooth already but how about the block walls? I was thinking of putting ply on the walls to make a smooth surface for fixing to but don't want to reduce the size too much so would have to limit myself to not too thick ply. or is that just a waste and I should simply PVA it all and paint it? ideas?
Thorfun posted a blog entry in West Sussex Forever Home
Well, itβs been quite a while since my last blog post but weβve not been idle but I do admit to having been slack in updating the blog. At the end of the last blog we had a superstructure and the roofer was about to begin his journey up the scaffolding. This is where that tale beginsβ¦.. βTwas a sunny November morning when all was quiet that a white van man arrived at our site to felt, batten and slate our sloping roofs. And he wasted no time at all in cracking on with it after the site orientation was complete. With his dad along to help with the battening it didnβt take long for the membrane (or βfeltβ if youβre a roofer) and battens and counter battens to be done. After discussions with our BCO it was decided that we would fully fill our rafters and use a breathable membrane (Proctor Roofshield) attached to the roof trusses and then 25mm x 50mm counter battens and then slate battens which gave us 50mm ventilation. This allows us to not need soffit vents (or indeed soffits) which fitted in to the design of the house better and also meant we donβt have to worry about creepy crawlies living in the soffits. We started with the southern elevation so that the solar PV array could be installed and the roofer (Chris) fitted the first few rows of slates and some flashing leaving it ready for the solar team to arrive before moving on to the northern elevation So while Chris was busy working on the north side of the house the solar installers arrived and fitted our GSE trays. Once done they started to fit the panels. But it was then discovered that the company who did the ordering ordered the wrong size GSE trays and the panels wouldnβt fit. So the solar installers took all the trays down and left site after wasting a dayβs work. Meanwhile the flat roofers attended site to single-ply membrane our flat roofs and balcony. A great bunch of guys from a company recommended to me by Chris so I had every confidence of them doing a great job, and they didnβt disappoint. DPM, PIR, OSB then single-ply membrane. First roof which will have a wildflower green roof being overlooked by our bedroom balcony Second roof above our utility room which links the house to the garage which will have a sedum roof They will return a little later on in the blog to install the green roofs. Meanwhile the solar installers returned after the correctly sized GSE trays had been delivered and managed to fit it all in a day. We think it looks brilliant. 28 x 375W LG panels, each with Solaredge optimisers as we have lots of trees around us. And when theyβd finished each panel was giving out 1V and was confirmed each was working by being shown the 14V on each string in the loft. Job done for now until we get electrics first fix done and they can come back and fit the inverter. The only real issue we had with the solar is that the panels were resting on the slates making them lift up in places. I created a thread about them (https://forum.buildhub.org.uk/topic/24530-slate-tiles-lifted/) and after much discussion and deliberation I decided to simply use black CT1 to stick them down which worked nicely. A bit of a bodge but you canβt tell from the ground and a lot less disruption to timelines than other solutions. While all of that was going on Chris was busy slating the northern elevation and it was all coming along nicely. During that I had another discussion with the BCO about vent pipes. I asked if I could have one by the STP but she was adamant that I had to have one through the roof. When I mentioned I didnβt want a pipe sticking out the top of the roof she said that they do slate vents. A quick google search revealed what she was talking about and I purchased the item and it was installed. Looks fab and from the ground you can barely notice it which is just what I wanted. And now the solar PV install was finished he could move on to the southern elevation. But while he was doing that the flat roofers came back and installed our green roofs. The wildflower material So thatβs those finished although we were still waiting on a Velux roof light for one of the roofs which was delayed but the flat roofers came back to install that for me and finish off that roof a bit later. They also installed our patio paving slabs which we think look ace. So, back to Chris and heβd now finished the main house roof slating and it finished off around the PV panels nicely. He did make a start on the garage roof but as we were still waiting on Velux windows he couldnβt finish that so he left site and would return once the Veluxβs were delivered. During that period our windows and doors arrived! We used Norrsken for these and went for alu-clad triple glazed windows and sliders. The majority of our windows are fixed and we had quite a small profile for the frame which means more glass. The installers, Elite Installations Nationwide (https://www.eliteinstalls.co.uk) were brilliant and Jim and his team were a joy to have on site. They brought their spider crane with them which made lifting our windows up to the first floor a breeze for them. We decided to be bold and went for a red front door. We love it. As the window install was done the week of Christmas the installers couldnβt finish them all in time before the Christmas break so we wished them a safe trip back to York and would see them in the new year. Happy new year!! (Belated). With the new year came the return of Jim and his team to finish off all our windows and doors. Once they were installed it made the house feel so much more like a house. Closing the front door had a feel of shutting out the outside world and we were (almost) water tight at last. We also eventually received our Velux roof light and sloping and vertical windows. So the flat roof was finally completed and so was the garage roof. So we are very nicely watertight at this point. All thatβs left now is the time-lapse video for this period of time. Sadly our camera only shows the south side of the building so we only get footage for stuff that happens on that side but it still makes for an interesting watch and I hope you enjoy it. Until next time.- 40 comments
- 16
welcome, looks an amazing project. the problem here is that many contractors out there are very much of the 'it's how we've always done it' mindset and so using timber frame is deemed wrong by some. it also means that, generally, they won't be paid for that as the majority of people use a TF company to erect the superstructure and then hand over to the contractor/client to do the rest. I also whole heartedly agree with all the comments above about insulate now! for a small cost now adding extra insulation will reap the rewards for the rest of your lives living at the house. don't stick to building regs, you need to far exceed them. I also agree to the comments about external blinds. get them in the design now and you can hide them away in the fabric of the building. I recommend spending the next 2 weeks hidden away in a dark room reading as many threads on this forum as you can! good luck and we look forward to following your journey.
I don't think Β£4k is too bad for that staircase @Faz! looks great.
+1 to getting more quotes! I always try and get 3 quotes minimum to get a good comparison. I do think your quote is a little on the high side but, as is mentioned, if you need to pay for scaffolding then that can add a substantial amount.
Pylontech do 2.4 and 3.5kWh batteries. And you donβt say if itβs a hybrid inverter or an AC coupled system. Nor make/model of inverter. either way and making assumptions Β£14.5k seems a lot for the 10 panels, 2 x pylontech batteries and a hybrid inverter check online prices and compare with whatβs on your quote.
Yeah sorry. My post was mostly for @Faz as he needs to rate the videos to allow those without accounts to view.
it's hard to compare if you don't give us all the details. battery size/make, inverter, panel make/model, any optimisers/micro inverters, trays in-roof/on-roof etc.
Vimeo now enforce the uploader to 'rate' the videos labelled as public for suitability. like an age rating. if it's not rated then you have to log in to view it. https://vimeo.zendesk.com/hc/en-us/articles/224818087-Content-ratings
Buying a 'traditional' new build! (Persimmon?)
Thorfun replied to Andeh's topic in General Self Build & DIY Discussion
the Persimmon house won't be how you want it though. yeah, it might be easy and it might 'do', but that's not what self-building is about! I understand the stress, time, money issues and I'm going through it all but the other day our charred larch turned up and it's beautiful and something you'll never find on a mass built home! and I knew it would all be worth it. π -
we've left 30mm for tiles. I think I got that figure from previous posts from @nod and our architects seemed to think it was a good number too. π
I was only joking btw. I'm happy to let you win this one. π I have a 10.5kWp array so I think 4 x 3.3kWh batteries should suffice for me. the think I'm liking about using Pylontech batteries is if I need more capacity I can just chuck another battery in there to increase it. I like the modular aspect of it.
how about 2 x Squirrel PODS with 8 x 3.3kW batteries per phase? so that's 79.2kW total storage with 7kW discharge per phase.
and with climate change who's to say these occurrences won't become more frequent. I see no issues with doomsday planning, I do have a basement/bunker after all. when the s**t hits the fan only @pocster and I will be left in our dungeons living out the rest of our days off our battery solutions. π
the cost of a wood stove with chimney etc wouldn't be far off a whole battery solution let alone the slight increase for one that islands the power in case of a power cut. I'm after a battery system so that I can use my excess generation at night, and having the ability to use it in a power cut is a bonus I'm happy to pay a little extra for.
not according to the marketing blurb from other manufacturers! Sonnen have a 'Sonnen Protect' which acts like the Tesla Gateway (which you have to pay for on top of the PW2) from my understanding and the Lux also has something similar built in. The Sofar has a separate 'chint' that you wire the important loads to for use during switch over. What the PW2 does have though is the 5kW throughput and 7kW peak which is nice but if you're just planning to run lights and low power stuff overnight then 3kW should be more than enough.
even if it's only once every two or three years that's enough for me to want to plan for that eventuality.
