Everything posted by Onoff
Meant to say about UV crazing. Painting cable too can be detrimental.
Best image I could find. Really annoys me that the undulations in the orange carrier don't line up properly even with two 5's. You get 10 not 11.
Went with Crown in the end over the Wickes acrylic primer: First coat, applied with two sizes of synthetic brush then rollered:
Yep. Price is about right but you can get tubes for around a fiver. I use it for everything. I dip wire ends in before I put crimps on if something is going in an external enclosure. I then dip the crimp in, say a 1/4" blade type. Loads of mates now use on their motorbike connections. Good on car battery terminals for stopping crud building up. Dip your coax cable ends in before fitting F connectors onto satellite dish LNBs etc. I found it suggested here first: http://www.satcure.co.uk/tech/silicone.htm
Other option would have been an IP6X junction box. Fed from loft is it? A neat option is feed through the back of a wall mount jb then bottom entry to the light fitting. Silicon the back of the jb where it meets the wall. I like the IP6X Amphenol / Bucaneer style connectors like those, good for 16A some of those. What I do is go belt and braces & pack the inside of the connector with silicone grease at work. They last indefinitely. How does the white cable come out of "wherever"? Watch for chaffing. I'd have used black too. I'd have added some nylon P clips and used stainless screws tidy things up / stop things flapping in the wind.
That's actually a proper IP6X one. Undoubtedly let down by a bad gland install. Top entry is the work of the Devil. Bottom or rear entry every time if you can. Appreciate difficult against a fence post.
Does nobody on here give a flying f*** about copyright? Ripped off from the dodgy PDF is it?
Ignore the IMDB Jaws link at the end of my post!
What would be your wishlist for a kitchen/diner?
Onoff replied to Powerjen's topic in New House & Self Build Design
Define long? Try having one with dementia. Seems like they live for ever. I think 7 years was quoted to me. Poxy disease. -
That I come in every night to the apricot, honey and vegetable tagine that SWMBO dished up tonight... -
I don't believe so but you could make your own big system using carriers e.g. 222-500. They're primarily for DIN rail mounting but I've screwed them into the raised plastic bosses of enclosures before
No rattling with this Wago jb! Should satisfy any neat freaks...
1) It's the wrong way up. 2) By Christ that must be one big cat!
An automated loft ladder...that'd be a step up...
We want pictures!
You haven't been here long, he's got a serious aversion to leaks.
Is there really going to be that much difference in quality between Dulux and Leyland? Is it paying for a name with in the case of Dulux? Or do I really splash out and go for the Diamond stuff? Tbh seems daft if I'm changing to oak veneered later!
If you really want to see DIY solar thermal working for people who think outside the box head across the pond to here: https://simplysolar.supporttopics.com/ Yes, they get more Sun. They also seem to go for size to compensate for lower efficiency of the designs.
Typical, found the rollers during the ads.
Couldn't find the rollers!
Ceiling Heights - different from 2.4m
Onoff replied to Kate12's topic in General Construction Issues
I used 2.7s as for some daft reason I decided to go with a nom 2470mm floor to ceiling height! Meant wasting nearly 300mm. Idiot, I should have dropped the new joists lower. Could have avoided those rips by the ceiling, took forever. -
