Everything posted by Onoff
Smoke problem from neighbours
Onoff replied to Savage87's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I'd set up a powerful, wall mounted fan, on my house in direct line of sight to his extract. Job done. There was a building back in Hong Kong in the 80's, Standard, see through, curtain wall glass. A new skyscraper of a rival company went up opposite with architectural features resembling arrows on the facade this was all about Feng Shui. The new build deliberately presented an "aggressive" face to the one opposite. The original build commissioned a retro fit on that facade of mirrored glass to project the negative energy back. -
https://www.laddersukdirect.co.uk/latest-news/post/how-to-use-a-roof-ladder & https://www.ladderstore.com/blog/why-do-i-need-a-roof-ladder
I'd best dismantle the kids sandpit then!
Good old fashioned railway sleepers make a good shed greenhouse base. I believe they were steeped in vats of proper creosote.
Looks like Dexter's workshop.
Tell him he reached that trigger point a long time ago but like another idiot close to me just won't give up...
You've a vote for the Cuprinol Garden Shades above. I've then used Cuprinol non slip deck stain and it really does what it says on the tin. Reckon you'd be safe with the Ducks Back.
A rather fetching little Golden Ale number here from the Harper's Brewing Co. in Co. Kildare.
I'm missing An Officer And A Gentleman for this! So I countersunk the fitting: Olive fits in the chamfered end a treat: A bit of Jet Blue Plus to lube things up. I'd need to take the burr off created by the countersinking so the pipe goes in further: Imho it works. Didn't go OTT with tightening the nut but it definitely squeezes the olive into the pipe. I'd risk it: (No I don't have a life ?)
See, this is what happens when the kids are left unsupervised! Surely the olive would tighten onto the pipe to stop it popping apart? Aware it's flat, I'd have countersunk the face anyway to take the olive.
On the back of Covid quite a few companies have seen a sudden increase of work after the lull. It's meant in some cases them having to sub out and by contrast not sometimes being able to get their favoured (read good) subbies in the first place.
OK 15mm pipe goes into the cranked fitting by a country mile: I could probably countersink the end a bit to make a seat for the olive. So it'd look something like this. Back of nut against the tiles. You'd lose that square plate brass backing plate thing: Next, found in the "this is going down the tip unless I can find a hoarder to take it box" kindly donated by @PeterStarck: What are these btw Peter? Ending up something like this: Might need a good dose of silicone to fill the gap: Bits in the post if you want to have a play. Edit: Sorry about the photo quality.
Hmmm...what if you were to ditch the silver bit with the spanner flats on. Then put a 1/2" nut over the pipe, olive then the cranked adapter. Would the cover plates that go over the 3/4" end of the cranked bit be deep enough to hide your faux pas? @Nickfromwales!!!!
I reckon you'll need a mixer with adjustable centres like this: https://www.notjusttaps.co.uk/versatile-manual-shower-valve-adjustable-centres.html
If it had said "Glassfiber" I'd have been worried about their attention to detail...
You ideally want to keep any wood of the shed 6" above the surrounding ground. Treat the Hell out of the bearers. The age old and tbh accepted premise is that a raindrop bounces 6" up in the air. You can mitigate the lack of 6" to some extent by painting the bottom timbers of the shed with a black bitumen paint. Can look quite good tbh. Deffo dpc strips above and below the bearers.
And the best cure for this is ....
Onoff replied to ToughButterCup's topic in General Self Build & DIY Discussion
Just screw a round in and Easifill. You'll have it done and painted before SWMBO gets back and she'll be none the wiser! ? -
Mains pressure shower I guess is a good way too, either via TS or UVC but they have their own issues.
I could get to my faux pas from both sides and it was pre skimming do I clamped the pb round in with a couple of bits of batten. Secured with no nails or similar. Once set the round was perfectly level. I might in TB's case, genuinely fill the gap (sub level) with intumescent mastic with the aim of retaining the fire integrity of the board at that point. I didn't do this on as I have fire hoods covering the downlights. Different strokes etc. -
Been there! Piece of plasterboard cut with the same hole cutter. Affix with one or two pb screws but leave a constant gap round the edge. Squirt in some no nails or similar with an uncut nozzle. Make sure the no nails is below the surface. Finish with Easifill. Paint and forget. -
Be happy to but at the mo have only successfully printed in PLA. I don't know how warm it gets in there but PLA isn't good when it gets warm. That and my lad is back at uni so the printer is sitting idle. I can only measure/draw/model in AutoCAD. Never even worked with a slicing program like Cura. Keep meaning too learn it but... (Don't like electric showers, give me pumped any day ? ).
Can't say I've noticed. Thought that was Romesh? Maybe they're related.
I bet you sound like Russel Howard!
Roger that.
