ToughButterCup
    101
Everything posted by ToughButterCup
  1. Just put a shutter (say) a meter either side of the bit that changes direction, mix some 3:2:1 concrete and plonk it in then?
  2. Piling is a very interesting topic. As I (imperfectly) understand it, piles of many types - are driven, screwed or compacted to whats known as a Refusal - simply a calculated back- pressure beyond which its not worth doing any more work (called the Working Load I think, maybe wrong). Refusal sometimes therefore varies by position. In our case one of the 64 piles just shot into the ground - to Refusal at about four meters. Most refused at a bit over three meters. One hit an incursion of rock. Because it was the last pile driven I could hear the difference in the cadence of compaction. And the ground really shook. The rest sort of slithered in. Just for completeness, @eandg, piling cost us £6500, Groundsure test , about £2500 ish, and one critically important letter (email) from the SE - one that together with a bit of research on my part and help from BH members saved £17000 (yes 17K) . Hillard Tanner saved his fee many times over. Top bloke - and his partner Nick Bailey. Ours were tested to 2.5 times the static load. One or two of the piles achieved 3 times the static load and one a little more.
  3. Erm, what's concrete mass fill ??
  4. Whooooo Hoooooo, thanks sooooooooooooooooooooooooo much. ? Digger's just arrived and the pipe would have been under 200 mm of pipe bedding by 2:00 today.
  5. Yes. Compulsory. Whats the point of the piles if they don't carry the load you need? Just to check, could you post your pile quote(s) , and break it down into piling and testing, please?
  6. How right was Ed ( @Construction Channel) ? I had to resort to this to keep the bloody pipe still. It was like grabbing hold of a Turkish wrestler..... Those pipe / oil filter grabbers (that red one is magnetic) is worth it's weight in gold to me - 8 fingers in total, 6 that work. I used two crowbars instead of road pins. Thanks Ed. Ian
  7. Ahhh, heard about those but never used them. I'll shred some old shirts then.....
  8. So far I have the design needs to be BR compliant : read Part K does not need to be solid concrete : pad it out with blocks or similar : 100mm of concrete is fine consider how to radius the steps : silicone , plastic ; careful with the landing width line the block with soffit board maybe? consider adapting precast blocks It's obvious that @Ian's point is the key to success on this one. So, I'll get on with the design and post it here. Thanks everyone. Ian
  9. You lot have the bit between your teeth on this one : thanks very much, I appreciate it ✔️....
  10. Exactly @Adrian Walker. It'll need to be designed carefully just like other elements of the build. Perhaps better put my question is; In terms of the construction phase , is it just a matter of proper shuttering and correct concrete mix?
  11. Yes Dave it is.... You know the saying, Happy Wife, Happy Life....
  12. Watching Building the Dream the other day ( Series 9 Episode 8 , 21:50 ish) Debbie saw this staircase and loves it.... The concrete winder that is.... or concrete block or whatever you call it. I like it as well, partly it because it also simplifies the stair run. The bottom of our stairs are surrounded on two sides by concrete walls. To make Debbie's dream come true, all I need to do, I think, is pour a concrete block of exactly the right dimensions to enable a BRegs compliant stair run to be built on top of it. The block itself also needs to be exactly correct in terms of risers and run. And that means serious shuttering and a sore back I expect. Cure time doesn't matter too much, we have some nicely textured wood left over for the top surface. I think I can make this happen. Any gottchas you can think of?
  13. To answer your first question directly - the price depends on trial depth, number of cores and level of detail in the feedback. You cannot do without a proper soil survey. Unless your risk appetite is very high. In which case any reputable piling company will want to do their own survey or insist you get one done. Is 4k (your quote) expensive? Get 2 more done. And when you get the numbers back, be sure to compare like with like. Not always easy
  14. Re-read Table 7 in @Onoff's response above. Look at the footnote to the table: You have 400 centres I think @Onoff might be suggesting you decide for yourself on the basis of the evidence he presents. I can confirm that the information he presents is accurate . Here is the link to the White Book ready for you to download Almost every single post in BH is offered in good faith. But after reading all the posts and thinking things through for ourselves, every one of us has to take sole responsibility for what we do on our build, unless we have consulted a properly qualified professional who carries the appropriate level of Professional Insurance .
  15. Exactly @AliG : but that's all, annoying. I've had trades in this week for the whole week - (@epsilonGreedy , sorry mate, first week of non DIYMax for 2 full years) and every day I have been either a bit, or somewhat or bloody annoyed. Until Debbie reminded me to keep my eye on the prize: progress.
  16. Yes. Fixed price or day rate? Fixed price: ignore it. Day rate: kick their arses.
  17. No. Some bracing is sensible. As is careful pouring. It's perfectly possible to pour without bracing. It's how you pour that matters just as much as super careful preparation.
  18. Its very common to pour Durisol without shuttering. Most of ours was done without shuttering until......
  19. ICF. Price, simplicity.
  20. I'm using half an old bra. Or a whole one doubled up. You may mock..... you wait, it'll be all the rage soon.⚕️
  21. and and her reply by text Well, that bottoms that out. Silicone it is then. Thanks everyone for your contributions. Ian
  22. Currently the water table has disappeared. But your point is well made. By sheer chance the I/C I'm talking about is right next to the land drain ( see red elipse above) designed to protect the slab from frost heave. All but one of the I/Cs will be next to that land drain. Except one. I'll need to fettle that more carefully. Thanks very much. Ian
  23. ... buy it off the roll .... help me would you please? What would I be looking for ? I don't know where to start. Just a simple hyperlink will get me going. Thanks, Ian
  24. A 15mm (ish) plastic pipe for the wire, filled post hoc with airtightness foam. (Daughter works for Open Reach)
