gravelrash
Everything posted by gravelrash
  1. Morning all, any suggestions on suppliers or diy cavity closers for 200mm in block/block cavity... would benefit from being cheap and able to accept frame fixings ..or am i dreaming
  2. Cant afford ridiculous cost of BS, but according to Axter the BS 6229 : 2018 – Flat roofs with continuously supported flexible waterproof coverings – Code of practice states zero fall roofs can be designed to 1 in 80. I would be using EPDM.
  3. Does Building regs trump British standards? House build limited to 3.2m ridge, architect is designing roof to 1 in 40 as he says thats the regs to allow for bad tolerances and any sag as per regs...but this dramatically lowers ceiling height. I would have thought that modern materials and web joists would allow a 1 in 80 design that retains 1 in 80 slope. BS:6229 allows design and build at 1 in 80 - so Building regs or British standards?
  4. Use a third party BC inspector...they are only interested in what the Building control plans are and if they are to standard. Its you responsibility to build to approved plans not the inspectors.
  5. 6mm BFRP tensile strength is >700 MPa and compressive Strength >400 MPa, certainly strong enough.
  6. Most of the suppliers have certs with technical standards but only for US and russia.
  7. Further research shows basalt rebar is the same or similar spec and quality as teplo and other basalt wall ties. 6mm diameter can be bought on the coil and can be bought with silica bonded surface giving stronger pull-out resistance for very low cost per meter- but no BBA . A friend has said this does not matter if mechanical strength can be shown to be at least equivalent as accepted standards for wall tie. Is this advice correct? The cost to my project would be reduced from about £1800 to £180 so big benefit if a good alternative.
  8. I see the general consensus for heavy doors over insulated cavity is CompacFoam inset and bolted through to floor slab. This seems a good option but wondering if anyone has used fibreglass angle or box section to solve the same issue.
  9. Iceverge- Where did you you get your stainless ties from? can you remember the manufacturer?
  10. https://www.engineered-composites.co.uk/products/grpfrp-rebar/#1461414691930-7d88e20c-b600
  11. Nylon? No...Glass Fibre.
  12. persimmons?
  13. Ha anyone used fibreglass wall ties? Looking around and seems teplo has the market for insulated ties- but at a big price. I can get fibreglass rebar at a good price and can cut to size easily with the strength required, but was wondering if anyone has used FG and which make.
  14. Thanks Mike, a clear and concise answer.
  15. I was originally asking if anyone knew the difference between boards and how they are effected by different locations...or is foil backed phenolic board just a foil backed phenolic board 15 years ago you just bought a board, not one specific to a roof or wall or anything else.
  16. No you don't need small boards, Helical ties are put in after so any size board can be used.
  17. Looking at cavity block wall with external render and timber clad facade so should be no water penetration of cavity. I was looking to build inner leaf first and use full size insulation boards. Does any one have any experience with PIR or phenolic boards...why do the manufacturers seem to make different boards from the same material but for specific jobs ie cavity, floor, roof? Seconds and co are selling 150mm Kooltherm phenolic at very cheap prices but not coded as k1** . Anyone know how using the wrong board would affect the build?
  18. Well after planning officer being adamant regarding a survey report I spoke with senior member in contamination department, explained covid 19 had stopped surveys..he replied that I should send him some photo's which I did and he signed the condition off with no further testing required. I think it upset the planning officer but it just shows how some officers are inflexible.
  19. The metsec system creates a problem with wall thickness as needs cross batten as well as large thermal bridging on mountings. might aswell just use less insulation if I was to create a large thermal bridge. EWI companies say you can just batten fix through insulation..but non state max insulation thickness which is obviously becomes an issue the thicker you get.
  20. CLOSED thread.------Moved this to correct area of forum..sorry
  21. Had this in wrong section so moved it. Single block wall with 150mm external pir insulation and cladding I need to clad exterior walls as part of planning stipulation. Has anyone any experience / knowledge of how to fix cladding battens through insulation in to wall? See attached quick sketch... I was thinking possibly using a standard exterior wall insulation fixing but replacing the plugs internal nail with a long screw that would pass through the batten and insulation plug in to the wall but the standard plugs only seem to be 8mm dia so screw would be about 4mm dia. ...not very strong! or alternative is helical bar fixing... Any wisdom out there? external insulation.pdf
  22. 190/215 aerated blocks is standard practice...its single storey with flat roof and 150mm of insulation.
  23. Had enough of Timber frame companies trying it on with cost and upfront design cost...so Looking at simple Single aerated block and external insulation. I need to clad exterior walls as part of planning stipulation. Has anyone any experience / knowledge of how to fix cladding battens through insulation in to wall? See attached quick sketch... I was thinking possibly using a standard exterior wall insulation fixing but replacing the plugs internal nail with a long screw that would pass through the batten and insulation plug in to the wall but the standard plugs only seem to be 8mm dia so screw would be about 4mm dia. ...not very strong! Any wisdom out there? external insulation.pdf
  24. The issue is that there is no asbestos or asbestos type material within the building or fabric of the building..its brick built with timber and steel roof ...is it possible the BC inspector can verify prior to demolition?
  25. I just found out that my desktop phase 1 does not cover another condition req post demolition. ‘Please provide documentation indicating what asbestos / asbestos containing material was present on site (e.g. a demolition / refurbishment survey report). Please provide further evidence or a statement explaining what was removed / that all asbestos was removed and by whom. Such a statement would ideally be provided by the removal firm. Should documentation relating to asbestos removal be unavailable or insufficient, post-demolition surface soil sampling of future landscaped or garden areas may be required.’ what a stitch up! Anyway, the building was a stable and never had any form of asbestos as part of construction...does anyone know if you have to use a registered surveyor, or is it possible to DIY report.
