redtop
redtop's Achievements
Regular Member (4/5)
119
Flat roof (felt bitumen) and insurance backed guarantee
redtop replied to Newbuildnewbie's topic in Flat Roofs
Just going through this. Peacock will only issue the IBG to the company who installed the roof, not you as the homeowner... A seperate IBG is currently being quoted at £1300! And thats only if i can get an install warrenty from the installer to back of the IBG. madness -
1st floor beam and block v timber floor Price comparison
redtop replied to Canski's topic in Floor Structures
I have said this before, but.... If you double the building regs level of insulation, half the air Leakage to 5ish then you don't need mvhr and the house will be far far better and cheaper to run than a min building regs house. Chuck in a load of the rockwool noise insulation between floors. Not as good as passive of course, but a lot better than standard for sure and no more complex than a standard build with just extra expense for insulation and a bit of reasonable care over holes / gaps. -
I think I would take a slightly different approach. These type of letters cost a few quid for a solicitor to produce. I would write back and simply state that the shared access has been used for many years by the residents and is listed as such in the deeds. And then ask on what legal basis they intend to stop what you consider to be legal use of the shared access route. In respect of nuisance from the build this is an issue that should be raised with the council should it occur. Now to answer properly the solicitor will have to spend some time, and his clients money, which they probably wont as they know they would lose.
Not an expert enough to really known the answer.... But couldn't you construct the wall using 2 timber frames with the gap between for the sliding doors. As is, the 2nd timber frame would be on the inside and just be used to create the gap for the doors, effectively a larger service void. Yes that wall would be thicker but not really sure why it would be anymore complex than doing the same with brick wall.
Best model acoustic insulation for studs and joists?
redtop replied to ashthekid's topic in Sound Insulation
I started with that and gave up as its soo bloody heavy for one person to lug around -
Leave it for now. Sometimes carpet plus underlay seems to be thicker than expected. Ours was and we had to get carpenter back to cut some more off doors. Get these fitted and if the gap is still too big, and you don't have mvhr get them back then. Even without mvhr a gap helps air flow but also encourages noise transfer.
We needed nothing, just the dno bit you have done. they then fitted the meter with nothing else done. Everything else is down to the electrician. If they insist on having a consumer unit fitted first just get sparky to put a small one in cabinett with the earth rod / connection done at same time. Would take half hour to fit these.
We used r45 rockwool and just stuffed the frames with it. Works a treat at reducing sound transfer. I am sure there are better results, but this was quick easy and the end result is good enough for us. -
Farrow and Ball paint: is it that much better?
redtop replied to ToughButterCup's topic in Decorating
So we painted our house ourselves. Used dulux, leyland F and B matched and another coy that matches F and B. Then got some F and B for a small room. Sorry, but it defo looks better, miles so. It has a matt, chalky like finish we havnt seen on any other paint. Considering the gazzilions the house has cost to build, most of which you never see, spending more to get the best paint finish / look you want seems like small beer to me. -
How to achieve sound proofing/noise insulation in the house
redtop replied to Indy's topic in General Construction Issues
I just used Acoustic Insulation, the rockwool r45 stuff in the stud walls and between floors. Standard plasterboard, upstairs also is double decked, so 18mm OSB and then 22mm chipboard on top. That was down to a screw up by me. Carpet upstairs too. Anyhow, very little noise transfer compared to any other house we have owned so well chuffed -
We used to rockwool 45 in the timber partitions, floor between ground / 1st floor and IMHO there is far far less noise transfer between the rooms than other houses we have owned. I wouldnt do it any different if doing it again tbh.
Maximum demand greater than 100amp single phase ukpn
redtop replied to Newbuildnewbie's topic in Electrics - Other
And microwave on, few laptop chargers, kettle. But I agree, thats why we have diversity. I would 3 phase as well to future proof. -
If you don't apply diversity its very easy to say you need more than 100amps. Sparkles tend to apply diversity when calculating cable sizes, loads etc as a standard. Are you sure he is a sparky? Having said that, ashp, elec cooker and car charger and its very easy to exceed 100amps if you just add up the total loads -
MVHR system in new build
redtop replied to deuce22's topic in Mechanical Ventilation with Heat Recovery (MVHR)
We havnt put mvhr in, Air tightness at 4 and trickle vents. With Double the min levels of insulation and top quality double glazing house doesn't need a lot of heating anyway. When looking at the benefits most people compare with a standard build to min BC regulations. Half the air leakage and double the insulation and the benefits are far more marginal. Sure it would be even less with mvhr but the biggest gains are insulation
