Originaltwist
Everything posted by Originaltwist
  1. I know you can prove anything with facts but I'm sure that fan-coils run better on lower temperatures than rads. So before doing a radiator reshuffle may I suggest a simple 'DIY fan-coil heater' project. Just Google it. It's the green one, first on images.
  2. Anyone following all this should take careful note of the suggestion of micro inverters from @SteamyTea They are best for multiple orientations The setup is simple But, most importantly, they last for about 20 years whereas a whole bunch of various boxes, all with a 10 year life expectancy, is asking for a series of catastrophic failures down the line.
  3. Thanks all. And noted. Actually it was flagged by our solicitors when we bought 5 years ago so we asked the vendors to knock off a chunk of dosh ... so perhaps it makes sense to bite the bullet now. However the guy that empties, it every year at least, says simple is best and don't change it. One might argue that simple doesn't seem to be best right now. I'm doing a percolation test next week to start off with real facts and then go from there.
  4. Our cess pit is brimming from time to time and the suggested fix is a new drainage field (£7,000) or a new 'system' (£12,000) Has anyone here had any luck with a bacterial fix such as muckmunchers?
  5. I've seen an ASHP parked in the woods well away from the house, to avoid noise and unsightliness, and that worked OK. I expect a secondary pump was needed.
  6. This could all be MUCH simpler: Thermal store with F&E tank above Stove below - gravity feed to store (no coil and 22mm will be enough). No controls needed. Gas boiler direct to TS - no coil immersion in TS So, to get the idea straight, the TS has black water in it and EVERYTHING is directly connected. DHW is extracted via PHX. - lots of power and gas boiler can remake like a powerful combi.
  7. A wood burner with a large heat bank looks like the way to go for you. I see you are keen on the Ecco stove but I can't see on their web site how it heats water. Can you explain please? I ask because many stoves have an integrated heat exchanger which can crack eventually and that will write off the entire stove.
  8. It's not just about quantity of storage. Water is very portable energy ... much harder to pump sand.
  9. Nice one Joe. Sorry @richo106 for the brief hi-jack. I know nothing about driveway lights so that makes me qualified to comment. In-drive spots shine upwards so are only effective if there is stuff nearby to be illuminated. Pillars shine to side and down and must be more effective, also the cable terminations can be safely elevated.
  10. aha @joe90 Gentry spotted .... B engine?
  11. The Woodfire EX15 looks nice although I have no experience with them. I go for the Clearview because: Stainless steel back boiler - quick to replace if it fails - which they don't I never go more than 50% heat to water - condensation on the back boiler and not enough to the room otherwise. Clearview stoves don't break. Chuck a big log in and they will stay in all night - saves a fortune in matches. I guess it's just down to what you fancy in the end.
  12. How about a wood burning stove and a heat bank? A 14kW Clearview 750 with a 7kW back boiler works well for your size of house. You get almost permanent hot water and heating too. Twin tanks are best. A gas boiler is a good addition and will get little use to trouble your wallet. I had this arrangement and used to run the boiler for 10 minutes every morning just to make sure the showers were in the bank. Gas use was so low that caravan type bottles were sufficient. Then bigger PV and battery along with a Victron Quattro to pull in a generator occasionally. Then Robert's your father's brother.
  13. My old shed big six roof has a few cracks so I've made a couple of foam backed crawler boards so that I can get up there to start stabilising it. I imagine I'll paint on some sort of gunge along with reinforcing mesh where required. There seem to be a lot of options - rubber - bitumin. Any favoured stuff please? It's about 40ms. Quotes to remove have been around £1,800 and replace about £6,000 and as it's just an old cow shed I'd rather spend a lot less than that. TIA
  14. No sorry - it's solid chestnut with an inlaid stainless sink. I prefer wood for worktops as you don't have to look after it much and it is kinder to wine glasses at the end of the evening.
  15. @Thorfun I love your kitchen picture - the close coupled triangle of hob,sink,fridge is perfect. I'd advocate having the dishwasher next to the sink in the island so you get lots of landing space for the dirties and can rinse quickly before stacking. Mine is similar but looks rather cluttered by comparison. The pan hooks above the sink were good in practice as they could be hung up to drip and not take up the drying rack. I love the lights too, is that easy to do?
  16. Ah, those were the days - red oxide Bondaprimer that really worked. I think Hammerite could be the answer. I once painted a woodworking machine feeder table that tolerated daily abrasion and the lack of wear was astonishing.
  17. Sounds like the design is nailed now. From experience I'd add a a pair of smaller accumulators, rather than one, and valve them off too, along with detachable fittings. That way when the inners need a service you lock it off and remove the whole lot for disassembly. The spare one keeps you going with no draining down. The accumulators are not usually for storing water per se. They just stop short cycling, so a pair of 20 litre ones should suffice, unless your pump is rated lower than demand which is not the way to go.
  18. I did a study on staircase design on https://originaltwist.com/2018/03/16/modern-floating-staircase/ Here's an extract that might help ... about the ratio for a 'comfort stair' Tradition has it that a comfort stair is 7” x 11” for rise and going. Rounding up slightly that’s 180 x 280mm. B.S. regulations give ranges for rise of150 -220mm and 220-300mm for going G. The ratio of rise to going gives an important angle which here would be around 33 degrees and must not exceed 42 degrees. You’ll need this angle to saw off the ends of the beams. The distance H between your two floor levels will set the rise. Find which whole number divides into H to give a rise R near to 180mm or what you prefer. That whole number is one more than the number of treads but note that the bottom tread might be a platform like the one on the sketch above. Tread thickness T. B.S. regs state that a 100mm ball must not pass between stairs or guards so if we say that the open gap between the treads will be 98mm then T = R – 98 or more. The Going overlap. B.S. regs state that the overlap on open stairs must exceed 16mm but too much spoils the design, as you will see when you draw yours. So tread width W = G + 20 will do for a start. So the treads will be something like 300 x 80 in section. As for length just bear in mind that stairs over a metre wide must have hand rails on both sides. I think 85cm looks about right. Length of box beams L. To make life easy you could set the top of the box beam level with the top of the top tread, so; The base of our triangle is (no of treads -1) x G / R and then just use Pythagoras to get the longest length of box…. or, frankly, just draw it and see what you get. The drawing will reveal what angle to cut on the ends of the box beams too. Make a note of all your numbers then make a drawing of the side elevation to scale. Sketchup is perfect for this and is free and easy to use. Note the intersection of the top of the angle iron, the beam and the back of the tread. N.B. Sketchup can repeat copies easily so draw and colour just one tread then copy it upwards by the rise and then across by multiples of the going.
  19. My borehole had no buffer tank at all so the pressure it made was perfect for showers etc. There was an accumulator (20 litre) on the line to prevent short cycling.
  20. A look on the Vesternet web site might give some ideas. Maybe a Z Wave controller and set up to give perimeter breach warnings 'flash the lights' before the real bells go off.
  21. thanks @JohnMo that would work - expensive though. This liitle chap starts at 40c and stops at 25c , a bit limited but under £10 from RS i have to say I have searched in vain for something similar for the cold side
  22. @MikeSharp01 yon have an inquisitive and poineering approach to stuff. How about a go at one of these DIY jobs? https://originaltwist.com/2024/06/26/diy-fan-coil-heater/ Re the condensation issue. I think the 'just in case' drip tray at the bottom is OK, then just try not to need it. I have suggested a way for the unit to run automatically when hot water arrives but haven't sussed the cold water yet - any suggestions welcome.
  23. The smaller blue tank is probably an accumulator to stop the well pump short cycling.
  24. there's always this DIY fan-coil idea https://wordpress.com/post/originaltwist.com/2699
