torre
Everything posted by torre
Yeah, enough to rule out Velfac sliders even though we're using their windows elsewhere. Not really, as others said, it's a sales lead opportunity for exhibitors
We found one of the majors expos at the NEC (Homebuilding & Renovating) helpful in a couple of ways: 1/ it was a great opportunity to look at and get hands on with quite a few window and door manufacturers at the same time. 2/ it helped inject a bit of enthusiasm and energy after set backs and delays There's also a chance you'll encounter new or different materials and products that you might want to use, overall worth a day trip if the travel isn't too far Free expo tickets but around £15 parking.
Rear Extension with incorporated W/C advice
torre replied to M_Wels's topic in House Extensions & Conservatories
Given you need to move the WC to make the open plan work at all, then I'd definitely go for something like option 1 - in the scheme of things, moving the WC that bit further isn't going to make that much difference and may even be easier - it looks like you have side access (there's a side window) so fairly easy to connect to the existing drains. Option 2 really compromises the open plan feel. I agree with @ProDave that you'd benefit from a door between hall and kitchen. -
What did your build cost come out at 2024/25!
torre replied to PSC88's topic in Costing & Estimating
The long house? Think they budgeted around that but finished closer to 750. That episode was a difficult watch and really put any setbacks with our own project into perspective. -
Uw varies by window size so I think there's a very good chance that Velux chart is based on a standard window size (1.2 X 1.4m) much larger than the average Velux and the Uw of smaller Velux windows will be worse, because a much higher percentage of the window will be frame
With a timber packer bolted into the web of your steel you could face nail joist hangers onto the packer. The hangers then also prevent any rotation and easily nail at different heights. Given you'll need SE calcs for this anyway, honestly I'd leave the design to them. The bolted on shims sound like quite a lot of work and will need additional specification by the SE.
Silicone Render Acceptable Skim Quality
torre replied to ricardo100671's topic in Plastering & Rendering
That looks rough to me. Have you seen other examples of their work? Is it possible your render will be finished with a scraped coat? -
I don't think there are that many people with the plant, materials and experience to safely build a double garage size compost heap and a ready supply of half a m3 of compostables per week to feed it, presumably needing a digger to load efficiently, but I guess it points to being able to heat a garden room from something more manageably sized. It'll produce most of its heat when you need it the least though (summer) and during the winter if you draw off too much heat from the compost won't you risk the whole system stalling?
Poured insulation! Am I missing a trick here?
torre replied to Nickfromwales's topic in Heat Insulation
Aeromix website doesn't work, aeromix limited active application to strike off at companies house, no BBA approval, can't see a whole lot of advantages tbh -
Internal wall insulation upgrade during refurbishment (Part L)
torre replied to Mos's topic in Heat Insulation
There is an exception if adding the insulation would reduce the floor area by 5% or more, so it's worth calculating the before and after areas. You might also be able to argue the condensation risk is too high. Pretty sure the BCO is plain wrong about insulating a solid party wall in a renovation, maybe confused with a new build. -
The basic architect questions thread
torre replied to SilverShadow's topic in Surveyors & Architects
If you'd started a basic builders/trades etc thread instead I think you'd see a similar mix of views, coloured by individual good and bad experiences rather than anything intended to offend contributors. -
Looks like your architect has your counter battens fixed to the joists on the left and suspended in mid air on the right. Ask your architect what's filling the gap between the joist and roof membrane to the right of Z? And why the square section is needed at all?
I think that's pretty reductive and unkind. What you're describing, especially on this forum, is the inexperience of people who are heavily vested in a once in a lifetime self build and often juggling a limited budget across all areas. Any self help forum also tends to focus on fixing issues rather than praising successful outcomes too. People tend to get swayed by opinions of their builders because they're often more approachable and available. Some architects need to explain better to such inexperienced clients what they do and how that's reflected in charges, and also how that may help clients save money and have their project run more smoothly down the line. RIBA's 8 stages can seem more reflective of much larger works and at concept design some architects are guilty of prioritising design over budget prepared at earlier stages. Concept design is also a stage where self builders in particular are likely to have strong ideas about what they want and have their good ideas incorporated while their less workable ideas are improved by the architect. We've had a good experience with the architect we chose, found a good balance of input, oversight and charges that reflected what both they as architect and we as clients and also as main contractors could contribute. It's easy to see though that a different architect could have brought plenty of creative and technical design and oversight to the project but fail to respect the client's own constraints and hopes for a project they've been dreaming of for years. There's a mix of real experiences on the forum of people who've paid little and had a poor experience alongside others who have paid a great deal and felt let down. -
Agree, you might have more space and more flexibility of kitchen layout if you swap the kitchen and the larger living room that connects to your dining space (losing the wall between). You lose the dedicated pantry but probably gain more in kitchen cupboard space and that frees up the pantry area to tweak the office and WC. Whatever you decide, remember these are all just opinions and your own is the one that counts!
We water tested drains the same as @Oz07 , filling enough so any below ground joints were covered and check the water level after a few hours (no need to block vents). BC were more interested seeing the runs and connections than checking any test but it's well worth testing as expensive to fix later. All our soil stacks are external though, so no worries or testing for internal stacks that'll end up built in and hidden.
I really like your hall and landing. Your dining/kitchen is a generous space but the two areas don't really connect and it looks a squeeze between the island and sink - maybe think about pocket doors from the hall so their swing doesn't intrude into the kitchen and move the island.
Reflective paint for EPDM roof
torre replied to sgt_woulds's topic in General Self Build & DIY Discussion
Interesting topic, something we might need to look at ourselves in future. it looks like Covalba may have a suitable product, I'd also thought about white pebbles but I'm not sure I'd like the look. Another idea might be pale tiles on pedestals (I mentioned this in another thread) which also adds an air gap between the reflective tiles and the roof. Wind uplift might be a worry though -
Did they tell you why or did they just want to sell you something else? I don't know that Bauder system at all, it certainly looks heavy duty. Bauder also look like they supply pedestals themselves, so if you do go that way I'd try and get those supplied with the rest of the install so there's no question mark later about suitability if you have issues.
Tapered insulation would save most of the firring height for approx same u value (but costs more). You can probably lose the top ply too (but I'd use thicker ply at the bottom). Realistically you won't save much from a warm roof buildup, maybe get it down 40-50mm. Presumably you're planning to install a cavity tray along the whole length of the wall, not just the opening?
Is that just for the roof covering or for the roof layup below plus slabs etc over? Sounds steep for just the covering. For a simpler roof finished with EPDM we were quoted a bit under 100/m2 (did it ourselves for quite a lot less). It's the edges that need the time and attention to detail EPDM looks a decent choice to me here, it'll be supplied as a single sheet so minimal chance of leaks and very patchable, and you don't need to worry about looks as it will be covered
If you think you'll be heavy handed with the screwdriver, you can get special bits cheaply that stop you driving the screw through
Neighbouring Balcony - Taken Down, About to be Rebuilt
torre replied to FC2407's topic in Planning Permission
If the materials are substantially different - say the old had rendered sides and the new were clear glass - then that may need planning as it increases overlooking. Have you asked the council exactly what's planned? Planting something tall may well be the pragmatic solution - if residents have been promised outside balcony space they're likely to resent a neighbour whose objection blocks that. -
Bungalow Roof Lift - Potential Floor Plans
torre replied to Cheesus's topic in New House & Self Build Design
I'd pull the shower room forward and also add a new doorway next to the annex front entrance straight into bed 1. That would bring its kitchen wall forward for more living space and also free up that corridor/lobby space in the main house by the boiler (but still have a door between annex and main) If losing bed 1 is your main motivation for the roof lift then a much cheaper compromise option would be to make the front of the annex open plan sitting room + kitchen then the shower room and the bedroom at the back. Keep bed 1 for the main house. There's a chance with a large side extension plugs a roof lift that you spend an awful lot for limited gains, versus finding a property already better suited or doing the minimum to be workable, but I appreciate when you need the annex for family decisions aren't easy -
You could enquire whether you can use fibre reinforced concrete instead of mesh. Cost more to pour but less labour faffing with mesh
