ADLIan
    1
Everything posted by ADLIan
  1. Do not render direct onto (any) insulation onto timber (or steel) frame construction!! It's not accepted good practice and lots of failures reported. About this time last year I was dealing with an architect looking at remedial works on this form of construction - sole plates and base of studs all rotted on 2 houses built approx 15 years ago. Does PUR really form a VCL if the board joints are not sealed/taped in any way? Moisture vapour is a gas so will readily move through the joints. Discuss.......
  2. Congrats! From past experience. The mad/sad thing is no one from the planning dept will actually check on completion that you built your house to the upgraded spec!!! BCO won’t be interested either.
  3. The EPC should give the air pressure test result - either ‘as measured’ in this house or based on site average value.
  4. It's not a very good advert for an insulation manufacturer when they don't know the difference between a high and a low U-value!
  5. Not just an energy statement. It’s imposing a condition that 20% of the CO2 target emission is from LZCT. From past experience it will never be checked.
  6. Nothing to do with SAP - its a perfectly acceptable inclusion in the U-value calculation and is covered in the U-value conventions document that supports the Bldg Regs/Appr Docs. Done correctly, to MIs, mass air movement behind the plasterboard will not occur.
  7. Aircrete block will generally give a much better psi-value than a medium or dense block (in the same detail). In a typical ground floor/wall junction expect the psi-value with dense block to be approx 3 times higher than with an aircrete block.
  8. Yup. But check with your Building Control Body as it it responsible for enforcement
  9. Vertical flashing and soakers looking at tile type?
  10. This work would fall under the Building Reg requirements (assuming England) to upgrade the roof insulation. Generally max Uval of 0.18 W/m2K (IIRC) above conditioned space or max 0.35 W/m2K above non-conditioned space. Building Control needs to be involved.
  11. Doesn’t read well when they knock the competition, by name/type so much.
  12. It's all in Appr Doc F in England. Do you currently have background (trickle) vents and intermittent extract fans to 'wet' rooms? If your air pressure test comes in at less than 3 you will need to upgrade this to continuous extract or a mech vent system. Get the test done and see what the result is. If you get less than 3 I am sure there 'ways' of increasing this to above 3 (open a trickle vent???). Your testing guy may be able to offer some simple 'advice'!.
  13. Those numbers look to be the standard recommendations the SAP software generates and they are absolute rubbish - do you have a copy of the SAP report you could post? A good consultant should have the knowledge of construction technology, sensitivities of the SAP calculation and suitable cost effective upgrades.
  14. PUR, PIR & polystyrene have no acoustic properties. Mineral wool should help here but if this is a beam supporting a wall above and bearing on another wall below flanking transmission may be in issue.
  15. The exception is for masonry walls only - 2 leaves at least 75mm thick. Note this is only the English Regs - there is no similar exemption in Scotland, Wales or Ireland that I am aware of. Timber or steel framed construction is NOT included. The issue with a fully filled cavity (hence no cavity!) is covered by not having to seal the top of the cavity. I'm sure this guidance is based on risk and the fire 'engineering' related to single houses and fire/smoke in masonry cavity walls. I wonder if the above diagram may have been better if it called them 'cavity closers' with a nod to the thermal requirements of AD L. I note it does not use the phrase 'cavity barriers'.
  16. AD B gives definitions of 'cavity barrier' and 'fire stopping' but not 'cavity closer'! Diag 5.3, Note 1, in the current AD B is quite specific about there being no particular fire performance requirement for the materials used to close the cavity. This note was included only in recent versions of AD B (post 2019?) and is not in the technical guidance for Wales, Scotland & Ireland. I have own my thoughts on why this was changed!! There is also no restriction on the fire performance of materials used in the cavity - mineral wool will be non-combustible, polystyrene and PUR/PIR will be classed as combustible.
  17. If this is the case why are there so many products on the market for use around door and window openings that are based on polystyrene or PUR insulation that have no fire resistance properties quoted.
  18. @Jammy5 you will need photo evidence of this junction. Be very careful of using an alternative (though outwardly similar) detail!!! @ETC if the detail complies with Diagram 5.3 above there is no fire resistance requirement for the cavity closer around openings so no need for CS board.
  19. That’s the one!
  20. SAP is not particularly sensitive to elemental U-values so hopefully OK - only your SAP assessor can give a definitive answer
  21. The SAP assessor will rerun the calculation with the revised insulation details. Hopefully all will be OK if some flexibility built into the design otherwise they should advise on options to get a pass (improved air test number?). I don't think photo evidence was required under the old, 2013, version of Appr Doc L.
  22. Since retiring I no longer have the inclination to write lengthy reports on this issue. Headlines are; A masonry cavity wall with cavity insulation only (full or partial fill) is normally very safe from harmful condensation. Adding a layer of internal insulation to the above may move the dew point too far inwards. A view must then be taken if any potential condensation risk is is acceptable or if the design needs to be changed. Building material manufacturers will be able to provide calculations. I think we are in agreement here. My other comment was in reply to your assertion, gleaned from cavity wall insulation installers, that insulation must not allow any condensate to ‘wick’ across the insulation. The amount of liquid water from condensation is negligible compared to that from wind driven rain and this latter point is the basis for testing on full size representative walls (not computer modelling/simulation). It is also the reason that the Approved Documents, NHBC guidance, BRE Report 262 etc give guidance on maximum exposure zones with full fill cavity insulation and measures (including external render) that can be adopted to reduce the risk.
  23. @Gus Potter I’ve spent a long time testing and designing cavity wall systems and know the difference between the issues with moisture from condensation and/or wind driven rain. When I have referred to the ‘cavity’ face of the outer leaf I assumed this would be understood to be the inner surface irrespective of a cavity or cavity insulation being present. Condensation may be predicted in a standard insulated cavity wall however it be at the internal face of the outer leaf - it may be considered as inconsequential as there is only masonry in the general wall area, the amount of condensate will be minimal, the outer leaf will be saturated at times following periods of wind driven rain. Adding further internal insulation to an already insulated cavity wall may move the dew point inwards depending upon material used and thickness. If steel/timber studs are used and condensation is predicted adjacent to them then a review of the design is needed. I stand by my comments. See BS 5250, insulation manufacturer details & BBA certificates. The BRE did work many years on ‘reverse condensation’ and it was considered not to be an issue.
  24. There are exemptions for the cavity barrier requirement/performance - please see the section on ‘compartmentation’ in Approved Doc B
  25. Condensation occurring on the cavity face of the outer masonry leaf is irrelevant. There is a much greater amount of liquid water at this point following periods of wind driven rain. As part of the certification process (BBA for example) cavity wall insulation, built-in or retrofit, is tested to ensure it does not allow water from wind driven rain to cross the cavity, this water should still drain down the ‘cavity’ face of the outer masonry. Again not condensation related. Adding cavity insulation does not move the dew point ‘inwards’. Condensation, if it does occur, will still be on the inner face of the outer masonry leaf and may be considered as inconsequential.
