zoothorn
    3
Everything posted by zoothorn
  1. I know its a 7.5kW Peter. I'd say they all get warm same, you'd expect the 1st in the queue to happen a bit before, as I find. Rads btms are all cold-warm, top you could say only warm now/ defo going down in temp from before. House isn't warm at all. Bathroom is cold, kitchen cold, I'm still in wooly hat cold nose, feet, legs very nippy. Pretty infuriating considering how much I'm spending if its been on alot since 7.30am & I'm just never getting warm. Actually its almost pointless. Temp 19.5*
  2. Rads mostly fairly-hot, still just coming up to temp as some still cold-warm at btm: so I'd say takes 2 hrs (even with system on all day doing 18*) to get them all fully up to speed (another hour to get rooms warming 9pm, another hour to get rooms nicely warm.. prolly.. but had gone off at 9!). Afaik they only go to fairly-hot @ max. Now, whether this has taken longer tonight -it seems so- I'm not sure.. but I'm bloody cold is all I know!
  3. No trv's (thank god- hateful things). Its showing 19*.
  4. @PeterW ok so I ramped it up to 25* at 6pm. 50mins ago. Outside temp 5.5*. All day its been set to 18*. What would you expect me to find at the rads by now? (is that a legitimate Q?)
  5. Ramped up to 25* at 6pm (been at 18* all day. Im in my kitchen, hat & coat on, cold nose & legs. This bloody house is absurdly cold! nothing to do with the system). What am I meant to be telling here-?
  6. Ok so is my plan to push the rebate inwards/ re-rout it, any good.. I'm not missing a trick? Also it says 'inc stops'.. pic suggests stops are fixed in place: can that be, or unlikely? thanks zoot
  7. Actually this is the only thing in town, in stock.. 27mm (x130mm) whitewood, is that too thin? https://www.jewson.co.uk/p/pefc-whitewood-lining-set-bwf-cert-32-x-138-act-size-27-x-132mm-PPL93214
  8. @Onoff very neatly done. I do get the rout idea too, & like your router doodle! But one difference yours to mine: you've fashioned the opening to accomodate a frame lining kit, with specific rebated positions, to accomodate a regular 2'6 or 2'9 door. Plus a regular door H too. I assume. Me here I'm designated by my 800mm opening (actually 790mm cos its got a midrift hump). This will equate to a 2'4 door more or less. And the H likely different too (but here I guess its just a Q of nipping off two ends of the jams, even in your case there). So as it seems better quality, & has the slightly bigger D @ 33mm, & has one side rebated already.. could I not buy a kit & just rout either header rebate 'inwards' 2"? then I know I have correct wood guages for a casing/ lining, one side rebated I could 'copy' (and also hasn't it got the planty bits inc too?) Or am I missing something? thanks.
  9. @PeterW Ok I'll ramp up the temp later.. but how this can be at all conclusive, just doing it on one occasion, is strange to me (and what else I could possibly say other than 'the rad & therefore the room gets hotter', Ive no idea: am I expected to be noting the time it takes to reach a particular temp or something? taking a note of outside temp too? repeating it on at least 2 days with a similar outside temp difference-?). But what else could it plausibly be? this rads/ room temp discrepency I find one morning to the next, with the outside temp different? you say it 'could be one of many' things other than its temp compensation off kilter..
  10. @Onoff ok look are you suggesting that I just buy a lining kit? If so could you please just say? Im really struggling to find suitable wood here. And to do this by making it. IE If I do find it, then I have to fashion these rebates -perfectly- 90* which isnt easy at all. Afaik, I have to measure the narrowest part of the opening, which is by 8mm, the middle, measure up/ mark a point.. & pack out all the area above & below. Is this right? Ive no idea. Or am I meant to hack away at the wall until I have a perfectly upright side? the clip assumes a perfect opening/ surely most aren't so.
  11. Ok am I following the way here then, or doing it any differently because I don't have a 'regular' opening.. seems a decent clip..
  12. How so if its got 'temp compensation' & I'm cold @ 9am one morning (outside temp mild), but warm the next morning at 9am (outside temp a few degrees colder)? Has my perception of cold changed in 24hrs & its actually working correctly?? or.. is it cos the temp compensation ain't working right?? I mean- come now.
  13. Ok thanks for the explanation/ at last a reason, above. Unless its explained "just turn it up!" makes no sense & my time also is wasted asking and asking why I should be doing such a seemingly meaningless test. But surely, my findings/ what Ive outlined as is happening, are reason-enough to conclude the 'temperature compensation' needs adjusting? All I really need do now I have these two words to hand, is call someone & pester them to adjust it. Maybe installers.
  14. Cos I use it alot for my work- sounds great as its light & the only 275mm I can get, but a sod to work with as its dreadful quality: not an assumpion, rather a finding. Ok I'm off to see what wood I can find for it. thx zoot
  15. "Temperature compensation". Aha, I missed these words before as I was distractedly frazzled trying to understand the turn it up test. Ok now this surely is the nub of what needs adjusting: at last I can see the wood for the trees. Its pretty obvious this is where the minor issue lies, if I find what I've repeatedly said I find. No need for any 'turn it up' (.. is there?) I didn't even know there was such a thing/ area/ section as 'temperature compensation'. If I knew where this was, heck I could probably tweak it myself, maybe in 5mins. But finding it, in that manual?? no flaming chance. Thanks- useful info then from ProDave (obviouslyI needed joe90's calm manner to get me to it!). Appreciated chaps- zH
  16. Somewhat clearer- thanks ProDave. I'm totally confused still though. "If you find with the temperature set way up high, the rooms warm up quicker, then this suggests the temperature compensation might need adjusting to make normal operation warm up quicker." I just don't understand this. Surely if I find the room warms up quicker doing this, that is -exactly- what I would expect, & therefore, could conclude it -doesn't- need adjusting. I think its too much- if I can't make sense of you kindly explaining why the experiment is being asked of me, there's no way I can understand how, if, its (what- if I cannot even figure this out too) needing adjusting, it can be done, let alone by whom. I'm getting such a headache trying to understand the suggestions & info. The system is just too complicated, & there's too much to go wrong with it (& so far has done) so your never sure if its working right, & the manual is incomprehensible. This much is a certainty. At least it seems to be working when the outside temp drops: if it was the other way round I'd be up a gum tree- so I'll leave it at that.
  17. Ah yes.. didn't think of this! that's an idea but I was thinking best way to get this bit super-tight was fit L & R 1st, whittle down the header bit until I get it super tight. I'll never be able to get it super tight screwing it onj 1st. Rebating that bit.. not easy either. Anyway I'm truly stuck on what timber- I seem to have only 1 option available, & poor quality 'whitewood'. 27mm x 130mm actual size. I'm wondering now if I were to buy a frame kit thing, then just narrow the header piece, I'll have good straight timber @ correct thickness like this. ?
  18. Ok. Can someone explain why I'm continually being asked to turn it up. It is totally unintuitive to me. Just turn it UP! turn it UP! Just shut up & just do it! but never any explanation as to why. What on earth is the point to this? If I turn it up.. the rads get hotter, the room gets hotter. So what? Is that what I'm then meant to put here as a finding?? then what, someone says "yes!! there you go!!"?? (so what would this proove? nothing I don't already know). I'm not saying "the system isn't working at all" (in which case just turning it UP & it getting hotter would disproove me). I'm saying the system doesn't appear to be working in a rational way if one day the rads are warm-only-they-do-not-go-any-hotter-for-3-hours-solid when it says 12* outside, & the room isn't warm/ I'm not warm. And the next day the rads are hot-good-as-expected-go-on-and-off-but-mostly-fairly-hot-for-3-hours when it says 10* outside, & the room is warm/ I'm warm. Its this discrepency I am enquiring about. Only this. It appears to me inconsistant with a system working normally. Turn it UP! is totally meaningless excercise, unless I'mmistaken (& so if someone can explain why I'm being asked to do it then), & on a totally different tangent to the avenue I'm asking about.
  19. Im having trouble finding the timber. I thought this was the easy bit. Is it 'redwood' planed timber, as opposed to 'whitewood'? The nearest I can find is this.. https://www.jewson.co.uk/p/pefc-standard-whitewood-pse-32-x-138mm-act-size-27-x-132mm-PWP32138 .. but I think whitewood isn't very good quality? certainly the 25x275 stuff I use is generally very light & often cracked/ cupped. I need to buy the right stuff for this, if my structure its fixing to isn't great.
  20. @joe90 ok understood, but isn't getting a header piece tight between though, effectively the same principle.. but easier to do-?
  21. There's no lintel at all above here, just a poxy bit of stud across.. so I could fix up into this maybe: I was thinking I had to fix it just to the upright L& R. I thought the door load was pulling inwards on the Rhs upright, which is braced/ pushing on the header: I thought alot of the load therefore was intrinsically onto the header 'across' as it were. Anyway- yes I'm forgetting the door-on-outside idea. Simpler not doing this. thanks zH
  22. I measure my kitchen (internal) door as same W as mine will be, if I go the standard way & it sits on the plant-on added pieces, like your sketch. Narrow @ 28" opening (measured plant to plant) but never feels 'restricted' in kitchen. So back to this idea. Its just the fixing in of the header that concerns me/ if the load is taken by this essentially/ how to get right.
  23. Hi Joe- Ok great I'm doing this then. One thing that springs to mind before I start, is the fairly narrow W I have to play with. Ideally if I undid the pB each side I could gain 1" overall.. but logistics of doing/ tidying up adds a day's work for me. The carpeter is chasing me/ got to just get frame in > so he can work. Do I have the option of putting the door opening instead of 'within' the two 5x1 uprights, on the 'face' of them instead? meaning a wider door by 1" or so, it sort of like a lid closing onto the short sides of the 5x1. Im just wondering if there actually is any benefit from this, if the opening you go through, remains the same, as its governed by the 5x1 in the same position whichever way. The only difference in the opening being the plant-on bit is awol on my 'lid' idea.. still is less the plant's 1/2" either side tho.
  24. Just to recap- I'll be going as per Joe's sketch (terrific- really helps). IE I'm going to leave the pB in place/ fix timbers over it. So the horizontal header bit.. just a friction-fit shaped piece? no need to rebate each end/ joint it to the uprights? and this the same 130x40mm planed square edge I assume (I guess this is same as Peter's 5x1 All Round planed). The only way of fixing horizontal, is diagonal big f-o screws: is the the only viable way? Its gotta be spot-on flush to the verticals the only prob.. Im rarely good at diagonal fixing/ jointing perfectly. A bit of a sod tbh. thx zH
  25. Hi PeterW I'm back over here. Respite- a bit simpler than a CH system, I hope! I'm planning my frame job: so far Ive got ticked to get today '5x1 Planed All Round timber'. So referring back to Joe's Rebate or Plant-on sketch (understand the difference in design) the Plant-on looks the simpler to do, I assume, meaning no big rebate to rout: not easy to do for me here tbh. Is Plant-on sufficient here, with regards to my perhaps not-ideal structure I'm fixing the frame uprights to-? thanks- zoot.
