Everything posted by Iceverge
Combining EWI and Cavity wall construction on a New build
Iceverge replied to Iceverge's topic in Brick & Block
Thanks for that Gus. Never heard of that truss before. Every day is a school day. My friend is actually a SE so really well versed in making stuff stay up, just trying to help with some pointers I learned building our passivhouse. In any case I modelled a block external leaf in THERM supported by an internal steel beam and provided you take care to insulate the rising block work externally it isn't actually too bad. I'll try to post if it I can get 5 mins at my laptop. -
Thanks @nod What about the case where it was timber framed with a block wall external except the shown area with cement board instead . Would the greater differential movement be an issue? -
A friend came to me recently asking for advice on their new build . Its a nice design but, as they wish to push as far as possible towards passivhaus performance, there are some problems with thermal bridging. Specifically as shown below (hatched) where the architect drew external walls that would require internal support, steels and thus lots of thermal bridging. ( Some architects don't believe in physics....) The windows and long span ( >9m) prevent a long Steel support holding up the external leaf independently from the internal wall. It wouldn't be very stable in any case. Internally insulating the steel has been suggested but it would still compromise the performance with high levels of insulation elsewhere. Would there be any issue with EWI only on this area and cavity walls elsewhere? I have suggested TF or EWI for the whole house but their preference is really leaning toward cavity walls for cost, durability and familiarity reasons. I assume they could be interfaced satisfactorily with a few appropriate plastering beads and applying the same acrylic render to both sides of the joint. Has anyone any experience of this? Maybe @nod or @Gus Potter are two that pop to mind.
https://youtu.be/qyUZ3SgNvfY?si=oUlP9rCa8zV_Wwch Nice video here although he screws though to the subfloor. I'd prefer to leave it floating.
Yup glued and screwed to itself. All joints broken between the layers. If you tape the foil faces of the PIR then another layer of a material of low permeability is pointless as far as I can see. In fact there's a risk with two layers of impermeability materials as any construction moisture will be trapped permanently. As the battens and PIR have different compression strengths I would worry moreso that they would compress differently over time and sags would be more obvious. You could have very closely spaced battens I suppose but then you're really eating into the insulative effects. Also you'll have to rip 25mm battens from larger materials as they come typically in 22mm so all the weight will be on the insulation anyway if you use them.
You could consider fiber cement like Hardi board or Eternit cedral.
Fun and joy with a thermal camera, part I: Attic
Iceverge replied to Garald's topic in Heat Insulation
I blew EPS beads back into the wall where they fell out with a cheap fireplace vacuum from Lidl. Put a mesh material over the vacuum side of the hose. Fill the hose with beads. Swap the hose to the blower outlet and blow into the hole. Repeat. It was slow but it worked. -
Cork. We've had highs of about 30 deg and the house didn't get above 26deg. Like you say, smaller windows, especially to the west. It would have been much cooler if my family didn't insist on leaving the windows and doors open while wandering in and out of the garden all day. A single A2A unit is a fraction of the price of a full ASHP and UFH setup. A passive house is like a canal boat. Once it's moving a tiny amount of power can keep it steady state.
I did a payback on cost vs paybacktime. I picked 25 years for all the insulation improvements. I picked this as at the time it coincided nicely with the passivhaus targets, plus a bit for mum. Hence the best spend for us was 200mm eps in the floor, 250mm eps beads in the wall and 450mm cellulose in the attic. Thermally 275mm everywhere might have had the same heating load but the cellulose was cheaper than the eps boards so I put more in the roof. In your case, if you can afford it, get the twinwall with cellulose. It'll be much quieter and more airtight. You might even save money if you don't bother with a central heating system like we did.
There's no rocket science with damp. It just needs to be able to dry faster than it can get wet. In this case you can't prevent it getting wet. An external french drain would be ideal but alas, not possible. You need to let it dry faster that it's getting wet. Heat and ventilate internally, remove any internal paint and or plaster of low vapour permeability. Cement based plaster or emulsion based paints etc. Assuming the floor is also of low vapour permeability the moisture will be all drying via the wall as it has nowhere else to go. If you were to dig out the floor and install an internal perimeter drain to a sump/pump it would relieve much of the moisture pressure from the wall too and it wouldn't be evident above floor level.
I think you're massively over engineering this. 25mm PIR sheets taped at the seams, and foamed to the walls. 2* layers of OSB floating on top, glued and screwed. Leave an expansion gap at the perimeter. Laminate flooring. I can't see a DPM or VCL achieving anything in this case.
Pitched Roof Thermal vs Acoustic insulation trade off
Iceverge replied to Nye's topic in Heat Insulation
Stayed in an airport hotel recently. They had 2 windows. One at the a building external face and another at the room side. Dead silent. It wouldn't be an too expensive an option for domestic houses to put 2x double glazed windows in. It should be thermally magnificent too. -
Slates/tiles to match the roof.
As I see it you can stop noise by: 1. Blocking airpaths for sound to travel. 2. Decoupling 3. Adding an absorbent layer to stop resonance. 4. Adding mass. There's no secret sauce to sound block plasterboard or mass loaded vinyl. Its just a trade off of mass Vs thickness Vs cost. More standard plasterboard is probably more economical. What U value do you need? -
Maybe I'm late to the battle here but have you considered if an ASHP is a good idea? They work well at low flow temps and prolonged operation periods and good building fabric. UFH and solid uninsulated floors shouts high flow temperatures and intermittent heating to me. To get the desired output from a heat pump you will have it run it at higher flow temps (bad for COP) for long periods. This means very high electricity bills. Maybe I'm missing something?
Go elsewhere, you'll be lightly to hit screws etc there. Its not too hard. Bang a screwdriver through it and use a bread knife if you don't have any tools. Otherwise a 20mm hole saw would do nicely. -
What's more important for comfort U value or 'thermal mass'
Iceverge replied to Gone West's topic in Boffin's Corner
And Solar PV, ASHPs and EV's. -
Just put up the cost of gas. People would figure it out themselves. -
Looks like it's just behind the plasterboard which is fine Cut a 80 X 20mm hole horizontally near the top of the wall in the plasterboard. If you can't see any cellulose shove your phone in with the video and flashlight on and have a look. JUST DON'T DROP YOUR PHONE!!!!!!! -
Do you have any pics of the outside?
There may have been some slimpjg of the cellulose. Can you describe the build up? Is it behind the plasterboard or a membrane too? -
Garden Room - Insulated plasterboard, yay or nay?
Iceverge replied to Amelia Winters's topic in Heat Insulation
There's often debate about this on here but I'm certainly in the camp of avoiding Rigid insulation between studs. Pl Perhaps you could do a wall of each if you're curious and report back.
